Product |
Photo |
Performance |
Description |
ARB CKSA12
ARB CKSA12 - Check Price
ARB CKSA12 Reviews
![](../tech_library/images/compressor-arb-CKSA12.JPG) |
0.47
CFM @ 29 PSI |
CKSA12
- This compact vehicle mounted Air Locker Air Activation System has
been specifically designed to provide on-board air for activating ARB
Air Locker locking differentials. A smaller unit, it comes with a
mounting bracket that allows versatile positioning and is sealed for
moisture and dust resistance with quality components used for reliable
compressed air and extra long life. |
ARB
CKMA12
ARB CKMA12 - Check Price
ARB CKMA12 Reviews
![](../tech_library/images/compressor-arb-CKMA12.PNG) |
2.18
CFM @ 29 PSI |
CKMA12
- Permanently mounted, this compressor is installed into your truck
and includes a full wiring loom with Air Locker solenoid plug in
contacts, mounting hardware with reinforcing bracket and quality
compressor isolating switch. This compressor can be used to activate
Air Lockers, and can perform other functions such as inflating camping
gear with an optional inflation kit sold separately. |
ARB
CKMP12
ARB CKMP12 - Check Price
ARB CKMP12 Reviews
![](../tech_library/images/compressor-arb-CKMP12.JPG) |
2.18
CFM @ 29 PSI |
This
portable 12 Volt air compressor comes in a durable polypropylene carry
case for added versatility and uses quality components for quiet
operation and extra long life. Including a 19 feet air hose, it also
comes with all the necessary fittings for tire inflation and camping
or leisure gear. |
ARB
CKMTA12
ARB CKMTA12 - Check Price
ARB CKMTA12 Reviews
![](../tech_library/images/compressor-arb-CKMTA12.JPG) |
4.65
CFM @ 29 PSI |
CKMTA12
- This compact vehicle mounted compressor has been designed to do
everything! Activate your ARB Air Locking Differentials, air up a
35" tire in less than a minute and run air tools. This 100% duty
cycle, 6.16 CFM compressor is built to support all of your compressed
air needs. |
ARB
CKMTP12
ARB CKMTP12 - Check Price
ARB CKMTP12 Reviews
![](../tech_library/images/compressor-arbCKMTP12.JPG) |
4.65
CFM @ 29 PSI |
CKMTP12
- ARB Air Compressors are also available in a complete portable
solutions. Kits come complete with a 19ft air hose and also all the
necessary fittings for tire inflation and camping or leisure gear.
CKMTA12 comes with a built-in 1 gallon tank and capable of powering
air tools. |
Want
more details? Click on the ARB chart to the right to enlarge it.
![](../tech_library/images/compressor-arb-chart.PNG) |
Product
Photo |
Performance |
Description |
Oasis XD3000
Oasis XD3000 - Check Price
![](../tech_library/images/compressor-oasis.JPG) |
9 CFM
@ 50 PSI
8 CFM @ 100 PSI
Max Pressure 200 PSI
2.2 Horsepower
Duty Cycle 100% @ 100 PSI
With
its dual-ring, oil control pistons, our XD3000 extended-duty DC air
compressor significantly reduces oil bypass into the air supply. This
DC air compressor model also employs a commercial grade 12 VDC motor
equipped with a cooling fan that dramatically extends run-time by
reducing heat buildup in the motor.
Designed for extended run cycles, our
XD3000 extended-duty DC air compressors are GSA approved and work well
for applications requiring heavy-duty, continuous use. |
Oasis XD4000
Oasis XD4000 - Check Price
![](../tech_library/images/compressor-oasis-xd4000.JPG) |
9 CFM
@ 50 PSI
8 CFM @ 100 PSI
2.2 Horsepower
Duty Cycle 100% @ 200 PSI
The
XD4000 continuous-duty DC air compressor model possesses dual fans: a
100 cfm fan built into a housing shroud, which works to cool the body
and motor of the machine, while providing added protection to the
unit, and an internal fan which also cools the modified 5 hp electric
motor. This unique cooling combination, found exclusively on our
high-quality XD4000 continuous-duty DC air compressor, provides
superior operating temperature reduction resulting in an unrivaled 100
percent duty-cycle at 200 psi.
Our XD4000 continuous-duty DC air
compressors are built to handle the most rugged commercial service and
tow truck project requirements, as well as military applications,
off-road vehicles, and air suspension systems. |
Product
Performance
Description
Smittybilt 2780
Smittybilt 2780
- Check Price
Smittybilt 2780 Reviews
2.54 CFM
- Easy twist screw-on brass inflator
top.
- Quick release 16-foot coil
hose
- Anti-vibration rubber feet.
- Can be permanently mounted and
hard-wired.
- Auto-thermal cutoff switch --
protects motor against damage.
- Built-on cleanable airfilter
- Maximum voltage - 13.8 volts
- Maximum continuous cycle time (Duty
cycle) - 40 minutes @ 40 psi @ 75 def F
- Integrated 150 PSI - Easy to read
pressure gauge
Smittybilt 2781 Smittybilt 2781
- Check Price
Smittybilt 2781 Reviews![](https://ir-na.amazon-adsystem.com/e/ir?t=therangerstation-20&l=ur2&o=1)
5.65 CFM
top.
- Quick release 24-foot coil
hose
hard-wired.
pressure gauge
Smittybilt MV50
(Q Industries)
Smittybilt
MV50 - Check Price
Smittybilt MV50 Reviews
![](../tech_library/images/compressor-smittybilt-mv50.JPG) |
2.54
CFM |
top.
hard-wired.
pressure gauge
Product
Photo |
Performance |
Description
VIAIR 88P
Viair 88P - Check Price
VIAIR 88P Reviews
![](../tech_library/images/compressor-viair-88P.JPG) |
120
PSI / 1.94 CFM |
- 12-Volt
- Duty cycle = 45% @ 100 PSI
- Max working pressure = 120 PSI
- Dimensions = 9.8"L x 3.1"W
x 5.6"H
- Inflates 33" tires
VIAIR 300P
VIAIR 300P - Check Price
VIAIR 300P Reviews
![](../tech_library/images/compressor-viair-300P.JPG) |
150
PSI / 2.40 CFM |
This small but powerful compressor is able
to fill 33 tires from 15 to 30 PSI in about three minutes.
Kit includes:
- Compressor
- 8’ power cord with battery clamps
- 25’ coiled hose
- Water resistant double compartment
carrying bag
VIAIR 400P
VIAIR 400P - Check Price
VIAIR 400P Reviews
![](../tech_library/images/compressor-viair-400P.JPG) |
150
PSI / 2.54 CFM |
The 400P Portable Air Compressor is the
most powerful portable compressor in the VIAIR lineup and is designed
to fill 35 tires from 15 to 30 PSI in just over two minutes.
Kit includes:
- Compressor
- 35’ coiled hose
carrying bag.
- Inflates 35" tires
VIAIR 440P
VIAIR 440P - Check Price
VIAIR 440P Reviews
![](../tech_library/images/compressor-viair-440P.JPG) |
150
PSI / 3.00 CFM |
440P is the ultimate portable compressor
kit. It can inflate a 37-inch tire from 0 to 30 PSI in less than 5
minutes. The 440P is the largest and most powerful portable compressor
kit available today.
Kit includes:
- Vibration-Resistant Diamond-Plate
Sand Tray
- 5-in-1 Inflator/Deflator with Inline
120 PSI Gauge
- Deluxe Dual Compartment Carry Bag
- 50-amp Inline Fuse Holder
- Dual Battery Clamps
- 3 pc. Inflation Tips Kit
- Power Cord: 8 ft.
- Air Hose: 25 ft.
- Inflates 37" tires
Product
Photo |
Performance |
Description
VIAIR 20003
VIAIR 20003 - Check Price
VIAIR 20003 Reviews
![](../tech_library/images/compressor_viair-20003.JPG) |
120
PSI / 2.03 CFM |
120 PSI Air Source Kits come with a low
amp-draw, 25% duty cycle, 275C VIAIR compressor mounted on a 150 PSI-rated
1.5 gallon air tank with 5 ports.
All Air Source kits come with a
pre-wired pressure switch (P/N 20003 / 90-120 PSI). The 120 PSI Air
Source Kit comes complete with a 1/4” NPT brass drain cock, 1/4”
NPT ASME coded and certified safety valve, 1/2” NPT port compression
fitting for 3/8” air line pre-installed. To use, simply connect the
pressure switch to fused power, make a solid ground and connect an air
line to the compression fitting. The use of a 40-amp relay and an
appropriately-rated fuse is strongly recommended to preserve the life
of the pressure switch.
VIAIR 20005
VIAIR 20005 - Check Price
VIAIR 20005 Reviews
![](../tech_library/images/compressor_viair-20005.JPG) |
150
PSI / 1.31 CFM |
150 PSI Air Source Kits come with a
powerful, 30% duty cycle, 280C VIAIR compressor mounted on a 150 PSI-rated
2.0 gallon air tank with 5 ports.
pre-wired pressure switch (P/N 20005 / 110-150 PSI). The 150 PSI Air
Source Kit comes complete with a 1/4" NPT brass drain cock,
1/4" NPT ASME coded and certified safety valve, 1/2" NPT
port compression fitting for 3/8" air line pre-installed. To use,
simply connect the pressure switch to fused power, make a solid ground
and connect an air line to the compression fitting. The use of a
40-amp relay and an appropriately-rated fuse is strongly recommended
to preserve the life of the pressure switch.
VIAIR 20007
VIAIR 20007 - Check Price
VIAIR 20007 Reviews
![](../tech_library/images/compressor_viair-20007.JPG) |
200
PSI / 1.34 CFM |
Fast-Fill 200 PSI Air Source Kits come
with a powerful, low amp-draw 380C VIAIR compressor mounted on a 200
PSI-rated 2.0 gallon air tank with 5 ports.
All 200 PSI Air Source kits come with a
pre-wired 165/200 PSI pressure switch. Both kits not only come with
the industry’s leading 200 PSI compressors but also come with a
drain cock, safety valve, 1/2-inch port compression fitting for
3/8-inch air line pre-installed! To use, simply connect the pressure
switch to fused power, make a solid ground and connect an air line to
the compression fitting. A 40-amp relay and an appropriately-rated
fuse is recommended for use with this unit.
VIAIR 20008
VIAIR 20008 - Check Price
VIAIR 20008 Reviews
![](../tech_library/images/compressor_viair-20008.JPG) |
200
PSI / 1.76 CFM |
High-Flow 200 PSI Air Source Kits come
with a powerful, low amp-draw 480C VIAIR compressor mounted on a 200
unit.
Product
Photo |
Performance |
Description
VIAIR 10000 VIAIR
10000 - Check Price VIAIR 10000 Reviews
![](../tech_library/images/compressor_viair-10000.JPG) |
105
PSI / 1.53 CFM |
Ultra-Light Duty - For Air Horns & Air
Lockers.
Ultra Light Duty Onboard Air System can
be used to pressurize the included 1.0 gallon air tank for air horn
use, off road air locking differential use, and a host of other light
duty pneumatic needs.
While not intended to inflate tires,
this onboard air system provides a reliable smaller volume, in a cost
effective package.
VIAIR 10002 VIAIR
10002 - Check Price
![](../tech_library/images/compressor_viair-10002.JPG) |
120
PSI / 2.03 CFM |
Quarter Duty - For Air Horns & Air
Lockers
Quarter Duty Cycle Onboard Air System
is a smaller, 120 psi onboard air system, suitable for many pneumatic
needs, including smaller inflation tasks (not including the inflation
of automotive tires), air horns and more. The 25% Duty Cycle Onboard
Air System will provide enough service time to operate for about 10
minutes of continued use, providing you give the system 30 minutes to
cool down afterwards.
VIAIR 10003
VIAIR 10003 - Check Price
VIAIR 10003 Reviews
![](../tech_library/images/compressor_viair-10003.JPG) |
150
PSI / 1.38 CFM |
Medium Duty - For up to 33" Tires
VIAIR’s Medium Duty Onboard Air
System is a pre-packaged compressed air solution that provides a 33%
duty cycle 325C compressor, 2.5 gallon air tank, and all components
needed to install basic vehicle-based pneumatics.
VIAIR
10005
VIAIR 10005 - Check Price
VIAIR 10005 Reviews
![](../tech_library/images/compressor_viair-10005.JPG) |
150
PSI / 2.54 CFM |
Heavy Duty - For up to 35" Tires
VIAIR’s Heavy Duty Onboard Air System
is a pre-packaged compressed air solution that provides a faster 33%
duty cycle 400C compressor, 2.5 gallon air tank, and all components
needed to install a working system capable of inflating tires right
out of the box.
VIAIR
10007
VIAIR 10007 - Check Price
VIAIR 10007 Reviews
![](../tech_library/images/compressor_viair-10007.JPG) |
150
PSI / 1.66 CFM |
Constant Duty - For up to 37" Tires
VIAIR’s Constant Duty Onboard Air
System is a pre-packaged compressed air solution that provides a 100%
duty cycle 450C compressor, 2.5 gallon air tank, and all components
needed to install a working system capable of inflating tires.
VIAIR
10008
VIAIR 10008 - Check Price
![](../tech_library/images/compressor_viair-10008.JPG) |
150
PSI / 3.21 CFM |
Super Duty - For up to 35" Tires
VIAIR’s Super Duty Onboard Air System
is a pre-packaged compressed air solution that provides two fast 325C,
33% duty cycle compressors, a 2.0 gallon air tank, inline pressure
regulation, and all components needed to install a working system
capable of inflating tires, managing air locking differentials, and
more.
VIAIR
10009
VIAIR 10009 - Check Price
VIAIR 10009 Reviews
![](../tech_library/images/compressor_viair-10009.JPG) |
150
PSI / 2.68 CFM |
X'Treme Duty - For up to 37" Tires
VIAIR’s X’treme Duty Onboard Air
System is a pre-packaged compressed air solution that provides two
350C, 100% duty cycle compressors, a 2.0 gallon air tank, inline
pressure regulation, and all components needed to install a working
system capable of inflating tires, managing air locking differentials,
and more.
VIAIR
20001
VIAIR 20001 - Check Price
VIAIR 20001 Reviews
![](../tech_library/images/compressor_viair-20001.JPG) |
200
PSI / 1.76 CFM |
Ultra Duty - For up To 37" Tires
VIAIR’s Ultra Duty Onboard Air System
is a pre-packaged compressed air solution that provides an
industry-leading, 200 PSI rated, 100% duty cycle 480C compressor, 2.5
gallon air tank, and all components needed to install a working system
capable of inflating tires of virtually any size.
More....
VIAIR has tons of compressors and air
systems. Click HERE
for more.
