1983-2011 Ford Ranger Bulb Guide:
Need to change a bulb in your Ford Ranger, but don’t know what bulb it takes? Here are the bulbs used by the 1983-2011 Ford Ranger. This is for reference only. You may want to check your Owners Manual to confirm which bulb you need.
Or, you could check the Bulb Replacement Guide to identify the bulbs in your vehicle.
Exterior:
​High beam headlight & Low beam headlight: 9007
Headlight for 1983-1988 Ford Ranger: H6054
Fog light for 1993-1997 Ford Ranger: H3 or 893
Fog light for 1998-2000 Ford Ranger: 9006
Fog light bulb for 2000-2004 Ford Ranger: 9145
Fog light for 2005-2007 Ford Ranger FX4, Sport, XL & XLT: 9145
Fog light bulb for 2005-2007 Ford Ranger STX: H11 / H11LL
Fog light for 2008-2011 Ford Ranger: 9145
Front turn signal light ( blinker light) for 1988-2011: 3457 / 3457K  / 3157 / 3157K  / 3157A  / 3157AK  / 3157-SCK ( parking light)
Front turn signal for 1983-1987 Ford Ranger: 1157 / 1157A
Front side marker light for 1983-1994: 194 / 194NA
Front side marker light for 2001-2011 Ford Ranger: 194NA  / 194
Rear turn signal light / Brake Tail light: 4157 / 4157K  / 3157 / 3157K  / 3156 / 3156K
Rear turn signal light / Brake light for 1983-1988 Ford Ranger: 1157
Back-up reverse light for 1989-2011: 3156 / 3155 / 3156K
Back-up reverse light for 1983-1988 Ford Ranger: 1156
3rd Brake light / Center high mount stop light: 921 / 912 / 906
License plate light / Tag light: 194
Interior:
Interior map light​ for 1990 Ford Ranger: 1816
Interior map light for 1994-1997 Ford Ranger: 906 or 212-2
Interior map light for 1997-2011 Ford Ranger: 168 / 912 / 904
Interior Dome light: 912
Instrument panel / gauge illumination for 1983 Ford Ranger: 161 / 89 / 1815 / 194
Instrument panel / gauge illumination for 1988 Ford Ranger: 89
Instrument panel / gauge illumination: 194
LED Bulbs:
You can get LED bulbs to replace your halogen bulbs. They will share the same number.
I upgraded the dome light, map lights, and dash lights in my 1996 Ford Ranger with Sylvania LED bulbs. I avoided the cheap Amazon LED bulbs. Some of those cheap LED’s don’t have a record of lasting very long before they start to go bad and flicker. The last thing I want to do is have to take my instrument cluster back out to replace them. Here is a comparison between a 192 dome light bulb and a 192 LED bulb.
