General Specifications (at curb weight)
NOTE: Measurements listed at curb load. Curb load is defined as “full service fluids, full fuel tank(s), no passengers and no cargo”.
Item | Specification |
Ball Joint Deflection | |
Upper | 0-0.2 mm (0-0.008 in) |
Lower | 0-0.8 mm (0-0.032 in) |
Front Ride Height (All Vehicles) | |
4WD | 111 mm ± 12 mm |
RWD | 93.5 mm ± 12 mm |
Rear Ride Height (All Vehicles) | |
4WD / RWD | 319 mm ± 12 mm |
Side-to-Side Variation (All Vehicles) | |
Front | ± 8 mm |
Rear | ± 8 mm |
Alignment Specifications (at curb weight) 4WD – vehicles Super Cab/ Crew Cab
Item | Left | Right | Tolerance (side to side) |
Camber Front | 0.03° ± 0.75° | 0.03° ± 0.75° | 0.00° ± 0.75° |
Camber Rear | — | — | — |
Caster Front | 2.72° ± 0.75° | 2.72° ± 0.75° | 0.00° ± 0.75° |
Caster Front – Bridgestone 255/70R16 and 265/60R18 | 2.47° ± 0.75° | 2.97° ± 0.75° | -0.50° ± 0.75° |
Caster Rear | — | — | — |
Toe @ curb ride height (positive value is toe in, negative value is toe out) | 0.00° ± 0.10° | 0.00° ± 0.10° | 0.00° ± 0.20° |
Toe @ curb ride height (positive value is toe in, negative value is toe out) | — | — | — |
Thrust Angle | — | — | 0.00° ± 0.50° |
Alignment Specifications (at curb weight) RWD – vehicles Super Cab/ Crew Cab
Camber Front | -0.44° ± 0.75° | -0.44° ± 0.75° | 0.00° ± 0.75° |
Caster Front | 2.90° ± 0.75° | 2.90° ± 0.75° | 0.00° ± 0.75° |
Caster Front – Bridgestone 255/70R16 and 265/60R18 | 2.65° ± 0.75° | 3.15° ± 0.75° | -0.50° ± 0.75° |
