Story by 4x4Junkie
If you like to push your rig to its limits, you’re probably familiar with the sight at right. You’ve probably just thought: “Yeah, that’s what happens when you push things too hard”. Well, you may be surprised to find out, sheer abuse is not always the culprit here.
Your stock Dana 35 axle shafts are equipped from the factory with Spicer 5-297X u-joints, and are retained by small half-round C-clips in the yoke. When pushed real hard with locking differentials & oversized tires, the joint’s bearing caps often will try to ‘spin’ in the yoke as the joint operates. As it rotates, it often “spits” off it’s clip and then the cap is free to walk out of the yoke, departing from the axle (if it doesn’t get crushed by the balljoint stud first). The u-joint trunnion then rips apart the axle yokes, causing a catastrophic failure like above (you can be sure this is what happened if you find the joint’s cross (main body) is not broken).
A full-round clip that fully encircles the joint’s bearing cap can quickly put a halt to this type of failure.
Unfortunately, just putting a full-round snapring on the cap isn’t possible to do without a bit of work to the axle yoke. Read on for how to make this possible (If you have a swapped-in Dana 44 axle, this modification will still provide the same benefits, as the joints are identical 🙂
Start by removing the clips and pressing out the old joint (a shop press makes real quick work of pressing them out (<even a homemade one lol). You can also purchase or rent a C-frame press (balljoint press) from some retailers that will do the same job. It basically looks like a large C-clamp, but has a receiving cup on one side for the bearing cap to press into.
If the joint is stubborn from rust, a good smack with a hammer while it’s under pressure will usually pop it free.
Here you can see why a round clip won’t fit, this shoulder on the yoke is in the way. This is primarily to blame for the c-clips coming off… As the cap spins, the clip wants to spin with it. The end of the clip hits against the shoulder, and basically ejects itself.
This shoulder has to be removed from the yoke.
Using an angle grinder, carefully grind down the shoulder, being careful not to grind below the level of the flat area on the yoke, until it is almost even.
Next, using a Dremel (or similar) hi-speed rotary tool, carefully dress up the yoke until a 1-3/16″, external-type snapring sits perfectly flat on the yoke.
While it is possible to do this with the angle grinder alone, I like the precision afforded here so that it’s much less likely you’ll whip off too much material at once and weaken (or ruin) the shaft.
You also want to make sure there are no high spots left, as this can create a stress point which could cause the cap to crack around the clip groove.
Keep checking your progress until you’ve determined that the clip sits down flat.
Here is the round snapring (aka, retaining ring) shown next to the original c-clip.
They can sometimes be found at auto parts stores, as well as some hardware stores.
Shown is a new Spicer 5-760X replacement joint next to the old 5-297X. These joints are an updated design and have a cold-forged cross which has repeatedly been shown to be much stronger than the 297’s hot-forged cross, with a much longer fatigue life. This should help to further put the brakes on broken u-joints.
I have found this cross is next to impossible to break, the needle bearings in the caps generally will crush and disintegrate before the cross itself fails (that is if the splined end of the shaft doesn’t twist off first).
Note the circular forging on it vs. the smooth center on the 297. These joints are currently priced around $25 or so each. Well worth the $$ over cheap “house” brand joints (which still use hot-forged parts)
Position the snaprings on the joint and install it into the axle yoke. Install the bearing cap over the trunnion, being careful none of the needle bearings fall out of place, and press the joint into place.
With the joint fully in place, use a set of snapring pliers to position the rings into their grooves. Using pliers with a 45° angled tip can make things a bit easier in some cases.
Repeat for the opposite shaft.
Your shaft is now ready to put the power to the ground!
With the full-round snapring clips, the caps can spin in the yoke all they want, and won’t ever come out.
While you have the grinder out, give the TTB center slip shaft a bit more clearance on it’s yoke as well.
I have found that this joint with it’s limited movement, can be prone to binding (and subsequent failure) on suspensions that have been modified for large amounts of travel.
A small amount of clearancing as shown below at right can help to eliminate failures at this joint as well.
Whatever you do though, never grind on the ENDS of the yoke to gain clearance (the loop part). This will weaken it..
Left shows the additional operating angle that can be obtained (top shaft) next to an unmodified shaft (bottom). While it may not look like a whole lot, it adds up to having several more inches of available bind-free suspension travel, and can easily make the difference between busting, and flogging it with ease.
The simple modification of adding round clips to the caps (combined with using the 5-760X joint) can add 10-15% or more durability to your stock shafts (to put that into a better perspective, that’s about the difference in torque your shafts see when running 35″ tires vs. 31″ tires). This could be enough to eliminate the need for costly aftermarket alloy shafts in some cases.
Some guys will often just tack-weld their caps to the axle yoke. While this effectively accomplishes the same thing (and is much quicker/easier to do, if you have a welder), you are no longer left with the option of servicing or replacing the joint in the future. The snaprings will not hinder serviceability of the shafts should the need arise. ~TRS
