Usage:
The Ford 7.5-Inch axle came in a few different vehicles including the:
- Ford Aerostar (1985-1997)
- Ford Bronco II (1984-1990)
- Ford Mustang (1979-2011)
- Ford Ranger (1983-2011)
For the purpose of this article, we’re only going to discuss the Ford Ranger and Bronco II.
All Ford Bronco II’s (1984-1990) came with a 7.5-Inch rear axle.
All Ford Rangers came with a 7.5-Inch axle from 1983-1989.
From 1990-2011, all 4.0L Ford Rangers came equipped with a 8.8-Inch axle.
1990-2011 Ford Rangers without a 4.0L V6 came with a 7.5-Inch rear Axle, but the 1998-2011 super cabs 4×4 models came with a 8.8-Inch axle regardless of engine size.
Axle Width Differences:
People have asked about the widths of axle shafts to swap shafts from one axle to another.
The early 1983-1992 Ranger axles are 1-inch shorter than the 1993-up pieces (Both sides). This means that the an entire Ranger axle assembly from 1993-up is 2-inches wider than 1983-1992.
The right side Bronco II axle shaft is 1-5/8″ wider than the 1983-1992 Ranger shaft. All of this additional width is on the passenger side. The drivers side shaft is the same length in either axle assembly.
On ALL Ranger/Bronco II’s the drivers side axle shaft is longer than the passenger side.
There is no difference between 7.5 & 8.8 axle shaft lengths provided you stay in the same year window.
Mustang Note: If you go to a salvage yard, you may find that the left side shafts have been removed from 1983-1992 Rangers and Bronco II’s. These axle shafts are the same length as the axle shafts in the “Fox” (1979-1993) Mustangs EXCEPT that Ranger/Bronco II shafts are five-lug and Mustangs are four lug. Ranger/Bronco II shafts are frequently “pillaged” for use in converting a Mustang to five-lug wheels.
Specifications:
Ford 7.5-Inch Axle – Specifications – Ring Gear & Differential | |
Ring Gear Diameter | 7.5 (7-1/2) Inches |
Ring Gear Bolts | (10) 7/16″ x 20 |
Differential Cover Bolts | 10 |
Pinion Stem | 1.626 Inches |
Pinion Splines | 28 |
Pinion Bearing Preload (New) | 14-19 in lb |
Pinion Bearing Preload (Used) | 8-10 in lb |
Back Lash | .011″-.016″ |
Ring Gear Bolt Torque | 70-85 ft lb |
Bearing Cap Bolt Torque | 70-85 ft lb |
Fluid Type | Use hypoid gear lubricant SAE 75W80 or 80W90 (Add 2 oz. friction modifier to axles with limited slips) |
Fluid Capacity | 5 pints (expect to use 2-3 quarts if changing the fluid. More if you have an aftermarket heavy duty cover. |
Ford 7.5-Inch Axle – Specifications – Axle Shaft | ||||
Vehicle | Side | Spline / Diameter | Length | Bearing |
1983-1992 Ford Ranger | Right Hand | 28-Spline / 1.21 Inch | 26.25 Inch | 1.4 Inch |
1983-1992 Ford Ranger | Left Hand | 28-Spline / 1.21 Inch | 29.125 Inch | 1.4 Inch |
1993-1997 Ford Ranger | Right Hand | 28-Spline / 1.21 Inch | 27.25 Inch | 1.4 Inch |
1993-1997 Ford Ranger | Left Hand | 28-Spline / 1.21 Inch | 30.125 Inch | 1.4 Inch |
1984-1990 Ford Bronco II | Right Hand | 28-Spline / 1.21 Inch | 27.6875 Inch | 1.4 Inch |
1984-1990 Ford Bronco II | Left Hand | 28-Spline / 1.21 Inch | 29.125 Inch | 1.4 Inch |
The Ford 7.50-Inch axle has a 5 x 4-1/2 Inch wheel bolt pattern.
All have 1/2-inch wheel studs. |
Axle Dimensions | ||||
Ranger 1983-1992 7.5-Inch Axle |
Ranger 1993-2009 7.5-Inch Axle |
Bronco II 1984-1990 |
Ranger 2010-2011 7.5-Inch Axle With Disc brakes |
Width WMS-WMS | 56-1/2 inches | 58-1/2 inches | 58 inches | unk |
Axle tube diameter (1983-2009 models): | 2.80 inches | 2.80 inches | 2.80 inches | 3.25 inches |
Pinion Offset Right Of Center | unk | unk | 1-1/4 Inches | unk |
Pinion Offset Below Centerline | unk | unk | unk | unk |
Pinion length (axle centerline to u-joint centerline): | 11-5/8 inches | 11-5/8 inches | 11-5/8 inches | 11-5/8 inches |
Bottom Of Housing From Centerline | 5-inches | 5 inches | 5 inches | 5 inches |
38-1/2 inches | 38-1/2 inches | 40-1/2 inches | 38-1/2 inches | |
Axle Spline / Diameter | 28 / 1.21 inches |
28 / 1.21 inches | 28 / 1.21 inches | 28 / 1.21 inches |
Pinion Stem Diameter | 1.626 inches | 1.626 inches | 1.626 inches | 1.626 inches |
Ring Gear Diameter | 7.50 inches | 7.50 inches | 7.50 inches | 7.50 inches |
(1) The Bronco II 7.5 inch rear axle is ~1-5/8 inches wider than the Ranger 7.5 inch axle.
All the additional width is in the passenger side. |
Identify Your Axle:
You can identify which axle you have by the tag attached to the inspection cover.
Here is an example of an axle tag:
Looking at that tag, you can see the gear ratio stamped on the lower left, and the axle size (ring gear diameter) stamped in the bottom middle.
So looking at the axle tag above, you can see it’s a 3.73 gear ratio in a 7.5 inch axle.
Axle Codes:
Rear axle codes can be found on the Safety Standard Certification label attached to the left drivers side door lock post. The code appears as a number or letter/number combination in the ‘Axle’ column of the label.
If you look at the ‘AXLE’ section on the label above, you’ll see that this Ranger has a ‘F7’ axle code. Using the chart below, we know that this axle is a 7.5-Inch axle with a 4.10 limited slip.
Axle codes for Ranger, Bronco II, Explorer and Aerostar (included because 4.10 gears and limited slips are more common than you’d expect).
Aerostar | |||
Code | Description | Capacity | Ratio |
22 | open 7.5″ | 2950 | 4.10 |
23 | open 7.5″ | 2950 | 3.45 |
24 | open 7.5″ | 2950 | 3.73 |
25 | open 8.8″ | 2950 | 3.27 |
29 | open 8.8″ | 2950 | 3.55 |
B2 | L/S 7.5″ | 2950 | 4.10 |
B4 | L/S 7.5″ | 2950 | 3.73 |
B5 | L/S 8.8″ | 2950 | 3.55 |
B9 | L/S 8.8″ | 2950 | 3.55 |
(Note: Aerostars with axle codes starting with “1” are Spicer/Dana 30 axles with Aluminum housings) |
Bronco II | |||
42 | open 7.5″ | 2640 | 3.45 |
44 | open 7.5″ | 2640 | 3.73 |
47 | open 7.5″ | 2640 | 4.10 |
D2 | L/S 7.5″ | 2640 | 3.45 |
D4 | L/S 7.5″ | 2640 | 3.73 |
D7 | L/S 7.5″ | 2640 | 4.10 |
Ranger | |||
72 | open 6-7/8″ | 2200 | 3.08 |
74 | open 6-7/8″ | 2200 | 3.45 |
82 | open 7.5″ | 2750 | 3.08 |
84 | open 7.5″ | 2750 | 3.45 |
85 | open 7.5″ | 2750 | 3.55 |
86 | open 7.5″ | 2750 | 3.73 |
87 | open 7.5″ | 2750 | 4.10 |
89 (1992-1998) | open 7.5″ | 4.10 | |
89 (1999-2001) | open 7.5″ | 4.56 | |
91 | open 8.8″ | 2750 | 3.27 |
92 | open 8.8″ | 2750 | 3.08 |
95 | open 8.8″ | 2750 | 3.55 |
96 | open 8.8″ | 2750 | 3.73 |
97 | open 8.8″ | 2750 | 4.10 |
98 | open 8.8″ | 2750 | 4.56 |
F4 | L/S 7.5″ | 2750 | 3.45 |
F5 | L/S 7.5″ | 2750 | 3.55 |
F6 | L/S 7.5″ | 2750 | 3.73 |
F7 | L/S 7.5″ | 2750 | 4.10 |
K6 | L/S 8.8″ | 4.10 | |
R5 | L/S 8.8″ | 2750 | 3.55 |
R6 | L/S 8.8″ | 2750 | 3.73 |
R7 | L/S 8.8″ | 2750 | 4.10 |
R8 | L/S 8.8″ | 2750 | 4.56 |
(Note 4.56 geared axles ’99-up are 31-spline) |
