Rear Leaf Spring Specs:
The chart below lists the leaf spring specs for the Ford Explorer, Ranger, Bronco, and Bronco II.
Leaf Spring Eye Bolts:
9/16″ Grade 8
- The 1991-2002 Ford Explorer and Explorer Sport uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
- The 2003-2006 Ford Explorer Sport Trac uses 9/16″ x 4-1/2″ Grade 8 bolts in the rear hanger
- The 1986-2003 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
- The 2004-2011 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the rear hanger
- The 1983-1985 Ford Ranger uses 9/16″ x 4-1/2″ Grade 8 bolts in the front hanger
- The 1984-1990 Ford Bronco II uses 9/16″ x 4-1/2″ Grade 8 bolts in the front and rear hanger
- The 1978-1996 Ford Bronco uses 9/16″ x 5″ Grade 8 bolts in the rear spring hanger
5/8″ Grade 8
- The 2003-2006 Ford Explorer Sport Trac uses 5/8″ x 4-1/2″ Grade 8 bolts in the front spring hanger
- The 1983-1985 Ford Ranger uses 5/8″ x 4-1/2″ Grade 8 bolts in the rear spring hanger
- The 2004-2011 Ford Ranger uses 5/8″ x 4-1/2″ Grade 8 bolts in the front spring hanger
- The 1978-1986 Ford Bronco uses 5/8″ x 5″ Grade 8 bolts in the front spring hanger
Ford Explorer |
Ford Part # |
Description |
1991-2001 Explorer 4DR (2wd & 4wd)
1991-2002 Explorer Sport (2wd & 4wd) Rear Code U |
F1TZ5560A & F17A5560DC |
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E), 3/1, (4-Leafs)
Grading, 3/.360 1/.590, Pack Thickness (1-7/8″) (1,250 Lbs) Capacity Each Rear Leaf Spring, Arch (4-13/16″) Uses 9/16″ x 4 1/2″ Grade 8 Leaf Spring Eye Bolt Front and Rear |
1995-2001 Explorer 4DR (2wd & 4wd)
1991-2002 Explorer Sport (2wd & 4wd) Includes Mazda Navajo 2wd & 4wd 1997-2001 Mercury Mountaineer 2DR & 4DR (2wd & 4wd) Rear Code F |
F57Z5560A & F57A5560FD |
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E), 3/1 (4-Leafs)
Grading, 2/.323, 1/.307, 1/.590, Pack Thickness (1-3/4″) (1,100 Lbs) Capacity Each Rear Leaf Spring, Arch (6-1/2″) Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Front and Rear
2001-2002 Explorer Sport Trac (2wd & 4wd) |
1L5Z5560BA & 1L545560BC |
2-1/2″ (W) x 25-3/4″ (S.E) x 31″ (L.E), 3/1,(4-Leafs)
Grading, 1/.341, 1/.307, 1/.291, 1/.590 (1200 Lbs) Capacity Each Rear Leaf Spring Pack Thickness (1-15/16″), Arch (8″) Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front and Rear |
2003-2006 Explorer Sport Trac (2wd & 4wd) |
4L2Z5560AA & 4L245560BA |
2-1/2″ (W) x 25-3/4″ (S.E) x 31″ (L.E), 3/1, (4-Leafs)
Grading, 1Lv @.341, 1Lv @.307, 1Lv @.291, 1Lv @.590 (1200 Lbs) Capacity Each Rear Leaf Spring Pack Thickness (1-15/16″), Arch (8″) Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Rear |
Ford Ranger |
Ford Part # |
Description |
1986-2003 Ranger (2wd & 4wd) |
E3TZ5560G & E2TA5560CA |
2-1/2″ (W) x 25-5/8″ (S.E) x 31″ (L.E), 3/1 (4-Leaf)
Grading, 2Lvs @.307, 1Lv @.291, 1Lv @.558 Pack Thickness (1-1/2″), Arch (6″) (1,250 Lbs) Capacity Each Rear Leaf Spring Front and Rear Leaf Spring Eye Bushings Included Uses 9/16″ x 4 1/2″ Grade 8 Leaf Spring Eye Bolts Front & Rear |
1983-1985 Ranger (2wd & 4wd) |
E4TZ-5560C & E47A-5560UA9 |
2-1/2″ (W) x 25-5/8″ (S.E) x 31″ (L.E), 3/1,(4-Leafs)
Grading, 3/.323, 1/.590, Pack Thickness (1-9/16″) (1,350 Lbs) Capacity Each Rear Leaf Spring, Arch (4-5/8″) Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Front Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Rear |
E6TZ5560M & E67A5560UB |
2-1/2″ (W) x 25-5/8″ (S.E) x 31″ (L.E), 3/1 (4-Leafs)
Pack Thickness (1-9/16″), Arch (4-3/8″) Grading, 3Lvs @.291, 1Lv @.662 (1350 Lbs) Capacity Each Rear Leaf Spring Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front & Rear |
F37Z5560A & F37A5560BB |
2-1/2″ (W) x 25-11/16″ (S.E) x 30-15/16″ (L.E) 2/1 (3-Leafs)
Grading, 1/.323, 1/.341, 1/558 Pack Thickness (1-3/8″), Arch (6-13/16″) (1,110 Lbs) Capacity Each Rear Leaf Spring Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front & Rear |
2004-2011 Ranger (2wd & 4wd) |
4L5Z5560EB & 4L545560EB |
2-1/2″ (W) x 25 3/4″ (S.E) x 31″ (L.E), 3/1 (4-Leafs)
Grading, 1Lv @.307, 2Lvs @.291, 1Lv @.558 Pack Thickness (1-11/16″) (1,200 Lbs) Capacity Each Rear Leaf Spring, Arch (6-1/8″) Uses 5/8″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Front Eyes Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolt Rear Eyes |
Ford Bronco, Bronco II |
Ford Part # |
Description |
1978-1979 Bronco – Full Size |
D8TZ5560B & D8TA5560DB |
3″ (W) x 24″ (S.E) x 31-1/2″ (L.E), 4/1, (5-Leafs)
Grading, 2/.291, 2/.262, 1/’625, Pack Thickness, (1.78″) (1,650 Lbs) Capacity Each Rear Leaf Spring, Arch (7-3/4″) Uses 5/8″ x 5″ Grade 8 Leaf Spring Eye Bolt Front Eyes Uses 9/16″ x 5″ Grade 8 Leaf Spring Eye Bolt Rear Eyes |
1980-1996 Bronco – Full Size |
EOTZ5560AD & EOTA5560AZC |
3″ (W) x 25″ (S.E) x 31″ (L.E), 4/1 (5-Leafs)
Grading, 2/.307, 2/.291, 1/.625 Arch (6-5/8″), Pack Thickness (1-7/8″) (1,650 Lbs) Capacity Each Rear Leaf Spring Uses 5/8″ x 5″ Grade 8 Leaf Spring Eye Bolt Front Eyes Uses 9/16″ x 5″ Grade 8 Leaf Spring Eye Bolt Rear Eyes |
1984-1990 Bronco II (2wd & 4wd) |
E6TZ5560F & E67A5560JA |
2-1/2″ (W) x 25-3/4″ (S.E) x 30-7/8″ (L.E), (5-Leafs)
Grading, 1Lv @.323, 1Lv @.262, 3Lvs @.249 Pack Thickness (1-3/8″), Arch (6-5/8″) (1,020 Lbs) Capacity Each Rear Leaf Spring Uses 9/16″ x 4-1/2″ Grade 8 Leaf Spring Eye Bolts Front and Rear |
Looking for stock or heavy duty replacement leaf springs? Check out ATS Springs.
