Submitted By: BlackBII
Vacuum Diagram Definitions |
Abbreviation | Description |
A/CL | Located in the air cleaner |
A/CL DV | Air Cleaner Diverter Valve |
A/CL BI MET | Air Cleaner Bi-Metallic Valve |
A/CL CWM | Air Cleaner Cold Weather Modulator |
ACT | Air Charge Temperature Sensor, prior to 1992 |
ACTS | Air Cleaner Temperature Sensor |
ACV | Air Control Valve |
AIR | Thermactor, short for Thermal Reactor. CA vehicles are installed with it as standard. Air Injection Reaction is what it stands for. |
AIR BPV | AIR Bypass (AIRB) Valve; also called the TAB (Thermactor Air Bypass) Valve |
BV | Bowl Vent (on top of the float tanks) |
CARB | Carburetor |
CBD | Closed Bowl Distributor |
CPRV | Canister Purge Valve |
DIST | Distributor |
DPFE | Differential Pressure Feedback |
DV-TW | Two Way Delay Valve |
EFCA | Electronic Fuel Control Assembly/ (Fuel Pressure Regulator (FPR) |
EGR | Exhaust Gas Recirculation |
EGRC/EGRV | EGR Vent/EGR Control |
EXH HCV | Exhaust Heat Control Valve |
EVP | EGR Valve Position |
EGR | Valve Position |
EVR | EGR Vacuum Regulator; also called EGR Vacuum Solenoid |
FLTR | Filter |
FPR | Fuel Pressure Regulator (check vacuum line) |
HEAT VLV INT | Heat Vacuum Control Valve Intake, (next to carb) |
HICV | Hot Idle Control Valve |
IAT | Intake Air Temperature Sensor (Air Charge Temperature (ACT), prior to 1992 |
IVV | Thermactor Idle Vacuum Valve |
LCV | EGR Load Control |
MAN VAC | Manifold vacuum-Vacuum source; usually ref. to as Vacuum Tree atop intake manifold |
MAP | Manifold Absolute Pressure |
PCV | Positive Crankcase Ventilation |
PURGE | Vapor Canister Purge Valve |
PV | Ported Vacuum |
PVS | Ported Vacuum Switch (PVS) Valve |
S | Spark port |
SA-FV | Separator Assembly Fuel/Vacuum |
SOLV | Thermactor Solenoid Valve |
SV CBV | Carborator Fuel Bowl Solenoid Vent Valve |
TCAC | Thermostatically Controlled Air Cleaner |
TCP | Temperature Compensated Accelerator Pump |
TK | Throttle Kicker |
TVS | Throttle Valve Solenoid (aka Solepot, Dashpot) OR Temperature Vacuum Switch |
TVV | Thermal Vacuum Valve OR Thermostatic Vacuum Valve (aka Ported Vacuum Switches; Thermal Vacuum Valve) |
VAC | Vacuum |
VCKV | Vacuum Check Valve |
VCV | Vacuum Control Valve |
VDV | Vacuum Delay Valve |
V CK V or VCV | Vacuum Check Valve |
VOTM | Vacuum Operated Throttle Modulator |
VRDV | Distributor Vacuum Delay Valve (VDV, VRDV, DV-TW) |
VRDV | Vacuum Delay Valve (VDV, VRDV, DV-TW) |
VRESER | Vacuum Reservoir (coffee can style in earlier years; replaced by plastic style) |
VRESV REST | on earlier years such as SEABRONC’s 83 is a Vacuum Restictor/delay valve, it delays vacuum for a certain amount of time |
VRV | Vacuum Regulator Valve |
WOT | Wide Open Throttle Valve |
