Introduction:
Once you start modifying your truck for off-road you eventually get to the point where you want to modify your gearing. This page will help you figure out what gears you need when adding larger tires, how to calculate a gear ratio, or calculate your final crawl ratio.
Calculators:
Also check out Gear Ratio & RPM Guide For Larger Tires.
