Submitted By: JLSteadman_b2
These are all the wires and their correct corresponding colors for the gauges and indicator lights in 1993-1994 Rangers. The labels are just the ones that I came up with. You can label each wire on the connector what you want. This was necessary to trace the circuits on the instrument cluster.
Gauge | Instrument Cluster Label | Wire Color | Purpose |
Voltmeter | EG | BR/Y | GroundIgnition Wire (Signal) |
Oil Pressure | HG
F |
B/WR/Y
W/R |
GroundIgnition Wire
Signal |
Water Temp. | CCBB
AA |
B/WR/W
R/Y |
GroundSignal
Ignition Wire |
Fuel Level | CCAA 3 |
B/WR/Y
Y/W, R/Y, B/W |
Ground Ignition Wire
Signal (Through circuit board on side of cluster) |
Tachometer | NS
XM (not used) |
T/Y
R/YDB/Y B/Y |
SignalIgnition Wire
Ground8 Cyl. (Not Used) |
Wire Color Codes | ||
B | Black | |
BR | Brown | |
DB | Dark Blue | |
DG | Dark Green | |
GY | Gray | |
LB | Light Blue | |
LG | Light Green | |
N | Natural | |
O | Orange | |
P | Purple | |
PK | Pink | |
R | Red | |
T | Tan | |
W | White | |
Y | Yellow | |
Cluster Label | Wire Color | Purpose | |
Left Turn Signal | EJ | BLG/W | GroundSignal |
Check Engine | AAEE | R/YPK/DG | Common (Ignition Wire)Signal |
Check Oil | AADD | R/YGY | CommonSignal |
Charge Indicator | KL | GY/YLG/R | Ignition WireSignal |
4-Wheel High | SP | R/YDB | CommonSignal |
4-Wheel Low | SQ | R/YBR/W | CommonSignal |
ABS | SR | R/YDG | CommonSignal |
Right Turn Signal | ZE | W/LBB | SignalGround |
High Beams | EV | BGY/W | GroundSignal |
Seat Belt | EW | BDG/LG | GroundSignal |
Anti-Theft | UT | — | Not Used |
Parking Brake | SO | R/YPK/W | CommonSignal |
Wire Connectors
