Differences in test mode noted as:
(O) = Key On Engine Off test
(R) = Key On Engine Running test
(M) = Memory code
Code |
Definitions |
111 | System checks OK |
112 | (O,M) Intake Air Temperature (IAT) sensor is/was low or grounded – IAT |
113 | (O,M) IAT sensor is/was high or open – IAT |
114 | (O,R) IAT sensor out of range – IAT |
116 | (O,R) Engine Coolant (ECT) sensor out of range – ECT |
117 | (O,M) ECT sensor is/was low or grounded – ECT |
118 | (O,M) ECT sensor is/was high or open – ECT |
121 | (O,R,M) Throttle Position (TP) sensor out of range – TPS |
122 | (O,M) TP low (possibly grounded or open circuit) – TPS |
123 | (O,M) TP is/was high or short to power – TPS |
124 | (M) TP voltage was higher than expected – Fuel control |
125 | (M) TP voltage was lower than expected – Fuel control |
126 | (O,R,M) MAP or BARO sensor out of range – “>MAP |
128 | (M) MAP vacuum has not been changing – check vacuum lines – “>MAP |
129 | (R) No MAP or Mass Air Flow sensor change during “goose” test – MAP MAF |
136 | (R) Oxygen sensor not switching/system lean Left or Front HO2S – Fuel control |
137 | (R) Oxygen sensor not switching/system rich Left or Front HO2S – Fuel control |
138 | (R) Fault in Cold Start Injector circuit – Fuel control |
139 | (M) Oxygen sensor not switching Left or Front HO2S – Fuel control |
144 | (M) Oxygen sensor not switching Single, Right or Rear HO2S – Fuel control |
157 | (R,M) Mass Air Flow signal is/was low or grounded – MAF |
158 | (O,R,M) MAF sensor is/was high or short to power – MAF |
159 | (O,R) MAF sensor is/was out of range – MAF |
167 | (R) No Throttle Position sensor change in “goose” test (must get at least 25% rotation) – TPS |
171 | (M) Oxygen sensor not switching – system was at adaptive limits – Single, Right or Rear HO2S – Fuel control |
172 | (R,M) Oxygen sensor not switching – system is or was lean – Single, Right or Rear HO2S – Fuel control |
173 | (R,M) Oxygen sensor not switching – system is or was rich – Single, Right or Rear HO2S – Fuel control |
174 | (M) Oxygen sensor was slow in switching Single, Right or Rear HO2S – Fuel control |
175 | (M) Oxygen sensor not switching – system was at adaptive limits – Left or Front HO2S – Fuel control |
176 | (M) Oxygen sensor not switching – system is or was lean Left or Front HO2S – Fuel control |
177 | (M) Oxygen sensor not switching – system was rich Left or Front HO2S – Fuel control |
178 | (M) Oxygen sensor was slow in switching Left or Front HO2S – Fuel control |
179 | (M) Fuel system was rich at part throttle Single, Right or Rear HO2S – Fuel control |
181 | (M) Fuel system was lean at part throttle Single, Right or Rear HO2S – Fuel control |
182 | (M) Fuel system was rich at idle Single, Right or Rear HO2S – Fuel control |
183 | (M) Fuel system was lean at idle Single, Right or Rear HO2S – Fuel control |
184 | (M) Mass Air (MAF) output higher than expected – Fuel control |
185 | (M) Mass Air (MAF) output lower than expected – Fuel control |
186 | (M) Injector pulse width longer than expected or Mass Air Flow (MAF) lower than expected – Fuel control |
187 | Injector pulse width shorter than expected or Mass Air Flow (MAF) higher than expected – Fuel control |
188 | (M) Fuel system was rich at part throttle – Left or Front HO2S – Fuel control |
189 | (M) Fuel system was lean at part throttle – Left or Front HO2S – Fuel control |
191 | (M) Fuel system was rich at idle – Left or Front HO2S – Fuel control |
192 | (M) Fuel system was lean at idle – Left or Front HO2S – Fuel control |
193 | Failure in Flexible Fuel (FF) sensor circuit – Fuel control |
194 | (M) Perform cylinder balance test to check for inoperative injectors |
195 | (M) Perform cylinder balance test to check for inoperative injectors |
211 | (M) Ignition PIP signal was erratic or missing – Ignition Systems |
212 | (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault – Ignition Systems |
213 | (R) Ignition SPOUT or SAW circuit open or shorted – Ignition Systems |
214 | (M) Error in Cylinder ID (CID) circuit or signal – Ignition Systems |
215 | (M) Primary circuit failure – ignition coil 1 – Ignition Systems |
216 | (M) Primary circuit failure – ignition coil 2 – Ignition Systems |
217 | (M) Primary circuit failure – ignition coil 3 – Ignition Systems |
218 | (M) IDM signal open or high or left coil pack failure – Ignition Systems |
219 | (M) SPOUT circuit failure, timing defaulted to 10 degrees – follow code 213 diagnosis |
222 | (M) IDM open or high or right coil pack failure – Ignition Systems |
223 | (M) Dual Plug (DPI), SPOUT or IDM circuit fault – Ignition Systems |
224 | (M) Failure in ignition coil primary circuit – Ignition Systems |
225 | (R) Knock sensor not tested (ignore if not pinging) – KS |
226 | (O) Ignition Diagnostic Monitor (IDM) signal fault – Ignition Systems |
232 | (M) EI primary coil circuit failure – Ignition Systems |
238 | (M) EI primary circuit failure – ignition coil 4 – Ignition Systems |
311 | (R) AIR system not working – Single, Right or Rear HO2S – Air Injection |
312 | (R) AIR not diverting – Air Injection |
313 | (R) AIR not bypassing – Air Injection |
314 | (R) AIR inoperative, Left or Front HO2S – Air Injection |
326 | (R,M) Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittently – PFE |
327 | (O,R,M) EGR feedback signal is/was low – EVR or PFE |
328 | (O,R,M) EGR Valve Position (EVP) is/was low – EVR |
332 | (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly – EVR or PFE |
334 | (O,R,M) EVP sensor is/was high – EVR |
335 | (O) EGR feedback signal is/was out of range – EVR or PFE |
336 | (O,R,M) PFE sensor signal is/was was high – “>PFE |
337 | (O,R,M) EGR feedback signal is/was was high – EVR |
338 | (M) Cooling system did not heat up (check cooling system / thermostat operation) |
339 | (M) Cooling system overheated (check cooling system / thermostat operation) |
341 | (O) Octane jumper installed (information only code to notify you if it is installed) |
411 | (R) Idle speed system not controlling idle properly (generally idle too high) – ISC |
412 | (R) Idle speed system not controlling idle properly (generally idle too low) – ISC |
452 | (M) Vehicle Speed Sensor (VSS) problem |
511 | (O) No power to PCM pin 1 or bad PCM (processor) |
512 | (M) Memory power (PCM pin 1) was interrupted – Was battery disconnected ? |
513 | (O) Replace processor (PCM) (internal failure) |
519 | (O) PSP switch/circuit open – PSP |
521 | (R) Wheel not turned during test or PSP problem – PSP |
522 | (O) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault – PNP |
transmission MLP sensor out of range in park – Transmissions | |
524 | Problem in low speed fuel pump circuit – Power / Fuel Pump Circuits |
525 | (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault – PNP |
528 | (M) System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) – PNP |
529 | (M) Data Communications Link to processor failure |
Service any EEC codes, erase memory and retest. If code is still present refer to instrument cluster diagnosis manual. | |
533 | (M) Data Communications Link to instrument cluster failure – see 529 |
536 | (O,R,M) Brake On Off open or shorted to ground – BOO |
538 | (R) System did not receive “goose” test – TESTS |
539 | (O) System shows voltage at PCM pin 10. Is A/C on ? |
542 | (O,M) Fuel pump open, bad ground or always on – – Power / Fuel Pump Circuits |
543 | (O) Fuel pump monitor circuit shows no power – Power / Fuel Pump Circuits |
(M) (Service 556 code first if present) Fuel pump relay or battery power feed was open – Power / Fuel Pump Circuits | |
551 | Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit – Solenoids |
552 | (O) AIRB solenoid/circuit failure – Solenoids |
553 | (O) AIRD solenoid/circuit failure – Solenoids |
554 | (O) Fuel Press Regulator Control solenoid/circuit fault – Power / Fuel Pump Circuits |
556 | (O,M) Fuel pump relay primary circuit fault – Power / Fuel Pump Circuits |
557 | (O,M) Low speed pump relay primary circuit fault – Power / Fuel Pump Circuits |
558 | (O) EGR vacuum regulator solenoid/circuit failure – EVR or PFE or Solenoids |
559 | (O) A/C relay primary circuit fault – A/C and Fan Circuits |
563 | (O) High Fan Control (HFC) circuit failure – A/C and Fan Circuits |
564 | (O) Fan Control (FC) circuit failure – A/C and Fan Circuits |
565 | (O) Canister Purge 1 solenoid/circuit failure – Solenoids |
566 | (O) transmission 3/4 shift solenoid/circuit – Transmissions |
569 | (O) Canister Purge 2 solenoid/circuit failure – Solenoids |
578 | (M) A/C pressure sensor VREF short to ground – A/C and Fan Circuits |
579 | (M) ACP sensor did not change with A/C on – A/C and Fan Circuits |
581 | (M) Cooling fan current was excessive – A/C and Fan Circuits |
582 | (O) Open cooling fan circuit – A/C and Fan Circuits |
583 | (M) Fuel pump current was excessive – Power / Fuel Pump Circuits |
584 | (M) Open power ground circuit – Power / Fuel Pump Circuits |
585 | (M) A/C clutch current was excessive – A/C and Fan Circuits |
586 | (M) Open circuit in A/C clutch – A/C and Fan Circuits |
587 | (O, M) Communication problem between PCM and Variable Control Relay Module (VCRM) – Power / Fuel Pump Circuits |
617 | (M) Transmission shift failure (1/2 shift) – Transmissions |
618 | (M) Transmission shift failure (2/3 shift) – Transmissions |
619 | (M) Transmission shift failure (3/4 shift) – Transmissions |
621 | (O) Solenoid/circuit failure – shift solenoid 1 – Transmissions |
622 | (O) Solenoid/circuit failure – shift solenoid 2 – Transmissions |
624 | (O,M) Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high – Transmissions |
625 | (O,M) Solenoid/circuit failure – Electronic Pressure Control (EPC) current is low – Transmissions |
626 | (O) Transmission Coast Clutch (CCS) Solenoid/circuit fault – Transmissions |
627 | (O) Torque Converter Clutch circuit fault – Transmissions |
628 | (M) Excessive converter clutch slippage – Transmissions |
629 | (O,M) Torque Converter Clutch circuit fault – Transmissions |
631 | (O) Overdrive Cancel Light circuit problem – Transmissions |
632 | (R) E4OD – Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test |
633 | (O) 4x4L switch should be in 4×2 or 4×4 high for the test |
634 | (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault |
Electronic shift transmission – Manual Lever Position (MLP) sensor out of range in PARK – Transmissions | |
636 | (O,R) Transmission Oil Temperature (TOT) sensor out of range – Transmissions |
637 | (O,M) TOT sensor is/was high or open – Transmissions |
638 | (O,M) TOT sensor is/was low or grounded – Transmissions |
639 | (R,M) Transmission Speed sensor (TSS) circuit fault – Transmissions |
641 | (O) Transmission solenoid/circuit failure Shift Solenoid 3 – Transmissions |
643 | (O)(M) Torque Converter Clutch (TCC) circuit – Transmissions |
645 | (M) Transmission 1st gear failure – Transmissions |
646 | (M) Transmission 2nd gear failure – Transmissions |
647 | (M) Transmission 3rd gear failure – Transmissions |
648 | (M) Transmission 4th gear failure – Transmissions |
649 | (M) Transmission EPC system failure – Transmissions |
651 | (M) Transmission EPC solenoid/circuit fault – Transmissions |
652 | (O) Torque Converter Clutch (TCC) circuit fault – Transmissions |
654 | (O) Transmission selector not in PARK – Transmissions |
656 | (M) Torque Converter Clutch (TCC) slip – Transmissions |
657 | (M) Transmission temperature was excessive – Transmissions |
998 | (R) Did not pass Key On Engine Off test yet (Get 111 in KOEO first) |
(O) Transmission Electronic Pressure Control (EPC) solenoid/circuit fault – Transmissions | |
Code |
Definitions: |
ACT | Air Charge Temperature Sensor |
BP | See MAP |
EEC | Electronic Engine Control System |
ECT | Engine Coolant Temperature Sensor |
EGR | Exhaust Gas Recirculation Valve |
EVP | EGR Valve Position Sensor |
HEGO | Heated Exhaust Gas Oxygen Sensor |
KOEO | Key On Engine Off |
KOER | Key On Engine Running |
MAF | Mass Air Flow Sensor |
MAP | Manifold Absolute Pressure Sensor |
MLP | Manual Lever Position |
PCM | Powertrain Control Module |
SPOUT | Distributor Jumper to Allow Initial Timing |
TP | Throttle Position Sensor |
