You’ll need a Code Reader to read the trouble codes.
DTC Codes – P0100-P0199 – Fuel and Air Metering |
P0100 | Mass or Volume Air Flow Circuit Malfunction |
P0101 | Mass or Volume Air Flow Circuit Range/Performance Problem |
P0102 | Mass or Volume Air Flow Circuit Low Input |
P0103 | Mass or Volume Air Flow Circuit High Input |
P0104 | Mass or Volume Air Flow Circuit Intermittent |
P0105 | Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction |
P0106 | Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem |
P0107 | Manifold Absolute Pressure/Barometric Pressure Circuit Low Input |
P0108 | Manifold Absolute Pressure/Barometric Pressure Circuit High Input |
P0109 | Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent |
P0109 | Intake Air Temperature Circuit Malfunction |
P0111 | Intake Air Temperature Circuit Range/Performance Problem |
P0112 | Intake Air Temperature Circuit Low Input |
P0113 | Intake Air Temperature Circuit High Input |
P0114 | Intake Air Temperature Circuit Intermittent |
P0115 | Engine Coolant Temperature Circuit Malfunction |
P0116 | Engine Coolant Temperature Circuit Range/Performance Problem |
P0117 | Engine Coolant Temperature Circuit Low Input |
P0118 | Engine Coolant Temperature Circuit High Input |
P0119 | Engine Coolant Temperature Circuit Intermittent |
P0120 | Throttle/Petal Position Sensor/Switch A Circuit Malfunction |
P0121 | Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem |
P0122 | Throttle/Petal Position Sensor/Switch A Circuit Low Input |
P0123 | Throttle/Petal Position Sensor/Switch A Circuit High Input |
P0124 | Throttle/Petal Position Sensor/Switch A Circuit Intermittent |
P0125 | Insufficient Coolant Temperature for Closed Loop Fuel Control |
P0126 | Insufficient Coolant Temperature for Stable Operation |
P0130 | 02 Sensor Circuit Malfunction (Bank I Sensor 1) |
P0131 | 02 Sensor Circuit Low Voltage (Bank I Sensor I) |
P0132 | 02 Sensor Circuit High Voltage (Bank I Sensor 1) |
P0133 | 02 Sensor Circuit Slow Response (Bank 1 Sensor 1) |
P0134 | 02 Sensor Circuit No Activity Detected (Bank I Sensor 1) |
P0135 | 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) |
P0136 | 02 Sensor Circuit Malfunction (Bank I Sensor 2) |
P0137 | 02 Sensor Circuit Low Voltage (Bank I Sensor 2) |
P0138 | 02 Sensor Circuit High Voltage (Bank I Sensor 2) |
P0139 | 02 Sensor Circuit Slow Response (Bank 1 Sensor 2) |
P0140 | 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2) |
P0141 | 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) |
P0142 | 02 Sensor Circuit Malfunction (Bank I Sensor 3) |
P0143 | 02 Sensor Circuit Low Voltage (Bank I Sensor 3) |
P0144 | 02 Sensor Circuit High Voltage (Bank I Sensor 3) |
P0145 | 02 Sensor Circuit Slow Response (Bank 1 Sensor 3) |
P0146 | 02 Sensor Circuit No Activity Detected (Bank I Sensor 3) |
P0147 | 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3) |
P0150 | 02 Sensor Circuit Malfunction (Bank 2 Sensor I) |
P0151 | 02 Sensor Circuit Low Voltage (Bank 2 Sensor I) |
P0152 | 02 Sensor Circuit High Voltage (Bank 2 Sensor 1) |
P0153 | 02 Sensor Circuit Slow Response (Bank 2 Sensor 1) |
P0154 | 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1) |
P0155 | 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1) |
P0156 | 02 Sensor Circuit Malfunction (Bank 2 Sensor 2) |
P0157 | 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2) |
P0158 | 02 Sensor Circuit High Voltage (Bank 2 Sensor 2) |
P0159 | 02 Sensor Circuit Slow Response (Bank 2 Sensor 2) |
P0160 | 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) |
P0161 | 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) |
P0162 | 02 Sensor Circuit Malfunction (Bank 2 Sensor 3) |
P0163 | 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3) |
P0164 | 02 Sensor Circuit High Voltage (Bank 2 Sensor 3) |
P0165 | 02 Sensor Circuit Slow Response (Bank 2 Sensor 3) |
P0166 | 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3) |
P0167 | 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3) |
P0170 | Fuel Trim Malfunction (Bank 1) |
P0171 | System too Lean (Bank 1) |
P0172 | System too Rich (Bank 1) |
P0173 | Fuel Trim Malfunction (Bank 2) |
P0174 | System too Lean (Bank 2) |
P0175 | System too Rich (Bank 2) |
P0176 | Fuel Composition Sensor Circuit Malfunction |
P0177 | Fuel Composition Sensor Circuit Range/Performance |
P0178 | Fuel Composition Sensor Circuit Low Input |
P0179 | Fuel Composition Sensor Circuit High Input |
P0180 | Fuel Temperature Sensor A Circuit Malfunction |
P0181 | Fuel Temperature Sensor A Circuit Range/Performance |
P0182 | Fuel Temperature Sensor A Circuit Low Input |
P0183 | Fuel Temperature Sensor A Circuit High Input |
P0184 | Fuel Temperature Sensor A Circuit Intermittent |
P0185 | Fuel Temperature Sensor B Circuit Malfunction |
P0186 | Fuel Temperature Sensor B Circuit Range/Performance |
P0187 | Fuel Temperature Sensor B Circuit Low Input |
P0188 | Fuel Temperature Sensor B Circuit High Input |
P0189 | Fuel Temperature Sensor B Circuit Intermittent |
P0190 | Fuel Rail Pressure Sensor Circuit Malfunction |
P0191 | Fuel Rail Pressure Sensor Circuit Range/Performance |
P0192 | Fuel Rail Pressure Sensor Circuit Low Input |
P0193 | Fuel Rail Pressure Sensor Circuit High Input |
P0194 | Fuel Rail Pressure Sensor Circuit Intermittent |
P0195 | Engine Oil Temperature Sensor Malfunction |
P0196 | Engine Oil Temperature Sensor Range/Performance |
P0197 | Engine Oil Temperature Sensor Low |
P0198 | Engine Oil Temperature Sensor High |
P0199 | Engine Oil Temperature Sensor Intermittent |
DTC Codes – P0200-P0299 – Fuel and Air Metering (Injector Circuit) |
P0200 | Injector Circuit Malfunction |
P0201 | Injector Circuit Malfunction – Cylinder 1 |
P0202 | Injector Circuit Malfunction – Cylinder 2 |
P0203 | Injector Circuit Malfunction – Cylinder 3 |
P0204 | Injector Circuit Malfunction – Cylinder 4 |
P0205 | Injector Circuit Malfunction – Cylinder 5 |
P0206 | Injector Circuit Malfunction – Cylinder 6 |
P0207 | Injector Circuit Malfunction – Cylinder 7 |
P0208 | Injector Circuit Malfunction – Cylinder 8 |
P0209 | Injector Circuit Malfunction – Cylinder 9 |
P0210 | Injector Circuit Malfunction – Cylinder 10 |
P0211 | Injector Circuit Malfunction – Cylinder 11 |
P0212 | Injector Circuit Malfunction – Cylinder 12 |
P0213 | Cold Start Injector 1 Malfunction |
P0214 | Cold Start Injector 2 Malfunction |
P0215 | Engine Shutoff Solenoid Malfunction |
P0216 | Injection Timing Control Circuit Malfunction |
P0217 | Engine Overtemp Condition |
P0218 | Transmission Over Temperature Condition |
P0219 | Engine Overspeed Condition |
P0220 | Throttle/Petal Position Sensor/Switch B Circuit Malfunction |
P0221 | Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem |
P0222 | Throttle/Petal Position Sensor/Switch B Circuit Low Input |
P0223 | Throttle/Petal Position Sensor/Switch B Circuit High Input |
P0224 | Throttle/Petal Position Sensor/Switch B Circuit Intermittent |
P0225 | Throttle/Petal Position Sensor/Switch C Circuit Malfunction |
P0226 | Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem |
P0227 | Throttle/Petal Position Sensor/Switch C Circuit Low Input |
P0228 | Throttle/Petal Position Sensor/Switch C Circuit High Input |
P0229 | Throttle/Petal Position Sensor/Switch C Circuit Intermittent |
P0230 | Fuel Pump Primary Circuit Malfunction |
P0231 | Fuel Pump Secondary Circuit Low |
P0232 | Fuel Pump Secondary Circuit High |
P0233 | Fuel Pump Secondary Circuit Intermittent |
P0234 | Engine Overboost Condition |
P0235 | Turbocharger Boost Sensor A Circuit Malfunction |
P0236 | Turbocharger Boost Sensor A Circuit Range/Performance |
P0237 | Turbocharger Boost Sensor A Circuit Low |
P0238 | Turbocharger Boost Sensor A Circuit High |
P0239 | Turbocharger Boost Sensor B Malfunction |
P0240 | Turbocharger Boost Sensor B Circuit Range/Performance |
P0241 | Turbocharger Boost Sensor B Circuit Low |
P0242 | Turbocharger Boost Sensor B Circuit High |
P0243 | Turbocharger Wastegate Solenoid A Malfunction |
P0244 | Turbocharger Wastegate Solenoid A Range/Performance |
P0245 | Turbocharger Wastegate Solenoid A Low |
P0246 | Turbocharger Wastegate Solenoid A High |
P0247 | Turbocharger Wastegate Solenoid B Malfunction |
P0248 | Turbocharger Wastegate Solenoid B Range/Performance |
P0249 | Turbocharger Wastegate Solenoid B Low |
P0250 | Turbocharger Wastegate Solenoid B High |
P0251 | Injection Pump Fuel Metering Control “A” Malfunction (Cam/Rotor/Injector) |
P0252 | Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/Injector) |
P0253 | Injection Pump Fuel Metering Control “A” Low (Cam/Rotor/Injector) |
P0254 | Injection Pump Fuel Metering Control “A” High (Cam/Rotor/Injector) |
P0255 | Injection Pump Fuel Metering Control “A” Intermittent (Cam/Rotor/Injector) |
P0256 | Injection Pump Fuel Metering Control “B” Malfunction (Cam/Rotor/Injector) |
P0257 | Injection Pump Fuel Metering Control “B” Range/Performance (Cam/Rotor/Injector) |
P0258 | Injection Pump Fuel Metering Control “B” Low (Cam/Rotor/Injector) |
P0259 | Injection Pump Fuel Metering Control “B” High (Cam/Rotor/Injector) |
P0260 | Injection Pump Fuel Metering Control “B” Intermittent Injector) |
P0261 | Cylinder I Injector Circuit Low |
P0262 | Cylinder I Injector Circuit High |
P0263 | Cylinder I Contribution/Balance Fault |
P0264 | Cylinder 2 Injector Circuit Low |
P0265 | Cylinder 2 Injector Circuit High |
P0266 | Cylinder 2 Contribution/Balance Fault |
P0267 | Cylinder 3 Injector Circuit Low |
P0268 | Cylinder 3 Injector Circuit High |
P0269 | Cylinder 3 Contribution/Balance Fault |
P0270 | Cylinder 4 Injector Circuit Low |
P0271 | Cylinder 4 Injector Circuit High |
P0272 | Cylinder 4 Contribution/Balance Fault |
P0273 | Cylinder 5 Injector Circuit Low |
P0274 | Cylinder 5 Injector Circuit High |
P0275 | Cylinder S Contribution/Balance Fault |
P0276 | Cylinder 6 Injector Circuit Low |
P0277 | Cylinder 6 Injector Circuit High |
P0278 | Cylinder 6 Contribution/Balance Fault |
P0279 | Cylinder 7 Injector Circuit Low |
P0280 | Cylinder 7 Injector Circuit High |
P0281 | Cylinder 7 Contribution/Balance Fault |
P0282 | Cylinder 8 Injector Circuit Low |
P0283 | Cylinder 8 Injector Circuit High |
P0284 | Cylinder 8 Contribution/Balance Fault |
P0285 | Cylinder 9 Injector Circuit Low |
P0286 | Cylinder 9 Injector Circuit High |
P0287 | Cylinder 9 Contribution/Balance Fault |
P0288 | Cylinder 10 Injector Circuit Low |
P0289 | Cylinder 10 Injector Circuit High |
P0290 | Cylinder 10 Contribution/Balance Fault |
P0291 | Cylinder 11 Injector Circuit Low |
P0292 | Cylinder 11 Injector Circuit High |
P0293 | Cylinder 11 Contribution/Balance Fault |
P0294 | Cylinder 12 Injector Circuit Low |
P0295 | Cylinder 12 Injector Circuit High |
P0296 | Cylinder 12 Contribution/Range Fault |
DTC Codes – P0300-P0399 – Ignition System or Misfire |
P0300 | Random/Multiple Cylinder Misfire Detected |
P0301 | Cylinder 1 Misfire Detected |
P0302 | Cylinder 2 Misfire Detected |
P0303 | Cylinder 3 Misfire Detected |
P0304 | Cylinder 4 Misfire Detected |
P0305 | Cylinder 5 Misfire Detected |
P0306 | Cylinder 6 Misfire Detected |
P0307 | Cylinder 7 Misfire Detected |
P0308 | Cylinder 8 Misfire Detected |
P0309 | Cylinder 9 Misfire Detected |
P0311 | Cylinder 11 Misfire Detected |
P0312 | Cylinder 12 Misfire Detected |
P0320 | Ignition/Distributor Engine Speed Input Circuit Malfunction |
P0321 | Ignition/Distributor Engine Speed Input Circuit Range/Performance |
P0322 | Ignition/Distributor Engine Speed Input Circuit No Signal |
P0323 | Ignition/Distributor Engine Speed Input Circuit Intermittent |
P0325 | Knock Sensor 1 Circuit Malfunction (Bank I or Single Sensor) |
P0326 | Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor) |
P0327 | Knock Sensor 1 Circuit Low Input (Bank I or Single Sensor) |
P0328 | Knock Sensor 1 Circuit High Input (Bank I or Single Sensor) |
P0329 | Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor) |
P0330 | Knock Sensor 2 Circuit Malfunction (Bank 2) |
P0331 | Knock Sensor 2 Circuit Range/Performance (Bank 2) |
P0332 | Knock Sensor 2 Circuit Low Input (Bank 2) |
P0333 | Knock Sensor 2 Circuit High Input (Bank 2) |
P0334 | Knock Sensor 2 Circuit Intermittent (Bank 2) |
P0335 | Crankshaft Position Sensor A Circuit Malfunction |
P0336 | Crankshaft Position Sensor A Circuit Range/Performance |
P0337 | Crankshaft Position Sensor A Circuit Low Input |
P0338 | Crankshaft Position Sensor A Circuit High Input |
P0339 | Crankshaft Position Sensor A Circuit Intermittent |
P0340 | Camshaft Position Sensor Circuit Malfunction |
P0341 | Camshaft Position Sensor Circuit Range/Performance |
P0342 | Camshaft Position Sensor Circuit Low Input |
P0343 | Camshaft Position Sensor Circuit High Input |
P0344 | Camshaft Position Sensor Circuit Intermittent |
P0350 | Ignition Coil Primary/Secondary Circuit Malfunction |
P0351 | Ignition Coil A Primary/Secondary Circuit Malfunction |
P0352 | Ignition Coil B Primary/Secondary Circuit Malfunction |
P0353 | Ignition Coil C Primary/Secondary Circuit Malfunction |
P0354 | Ignition Coil D Primary/Secondary Circuit Malfunction |
P0355 | Ignition Coil E Primary/Secondary Circuit Malfunction |
P0356 | Ignition Coil F Primary/Secondary Circuit Malfunction |
P0357 | Ignition Coil G Primary/Secondary Circuit Malfunction |
P0358 | Ignition Coil H Primary/Secondary Circuit Malfunction |
P0359 | Ignition Coil I Primary/Secondary Circuit Malfunction |
P0360 | Ignition Coil J Primary/Secondary Circuit Malfunction |
P0361 | Ignition Coil K Primary/Secondary Circuit Malfunction |
P0362 | Ignition Coil L Primary/Secondary Circuit Malfunction |
P0370 | Timing Reference High Resolution Signal A Malfunction |
P0371 | Timing Reference High Resolution Signal A Too Many Pulses |
P0372 | Timing Reference High Resolution Signal A Too Few Pulses |
P0373 | Timing Reference High Resolution Signal A Intermittent/Erratic Pulses |
P0374 | Timing Reference High Resolution Signal A No Pulses |
P0375 | Timing Reference High Resolution Signal B Malfunction |
P0376 | Timing Reference High Resolution Signal B Too Many Pulses |
P0377 | Timing Reference High Resolution Signal B Too Few Pulses |
P0378 | Timing Reference High Resolution Signal B Intermittent/Erratic Pulses |
P0379 | Timing Reference High Resolution Signal B No Pulses |
P0380 | Glow Plug/Heater Circuit “A” Malfunction |
P0381 | Glow Plug/Heater Indicator Circuit Malfunction |
P0382 | Exhaust Gas Recirculation Flow Malfunction |
P0385 | Crankshaft Position Sensor B Circuit Malfunction |
P0386 | Crankshaft Position Sensor B Circuit Range/Performance |
P0387 | Crankshaft Position Sensor B Circuit Low Input |
P0388 | Crankshaft Position Sensor B Circuit High Input |
P0389 | Crankshaft Position Sensor B Circuit Intermittent |
DTC Codes – P0400-P0499 – Auxiliary Emissions Controls |
P0400 | Exhaust Gas Recirculation Flow Malfunction |
P0401 | Exhaust Gas Recirculation Flow Insufficient Detected |
P0402 | Exhaust Gas Recirculation Flow Excessive Detected |
P0403 | Exhaust Gas Recirculation Circuit Malfunction |
P0404 | Exhaust Gas Recirculation Circuit Range/Performance |
P0405 | Exhaust Gas Recirculation Sensor A Circuit Low |
P0406 | Exhaust Gas Recirculation Sensor A Circuit High |
P0407 | Exhaust Gas Recirculation Sensor B Circuit Low |
P0408 | Exhaust Gas Recirculation Sensor B Circuit High |
P0410 | Secondary Air Injection System Malfunction |
P0411 | Secondary Air Injection System Incorrect Flow Detected |
P0412 | Secondary Air Injection System Switching Valve A Circuit Malfunction |
P0413 | Secondary Air Injection System Switching Valve A Circuit Open |
P0414 | Secondary Air Injection System Switching Valve A Circuit Shorted |
P0415 | Secondary Air Injection System Switching Valve B Circuit Malfunction |
P0416 | Secondary Air Injection System Switching Valve B Circuit Open |
P0417 | Secondary Air Injection System Switching Valve B Circuit Shorted |
P0418 | Secondary Air Injection System Relay .A” Circuit Malfunction |
P0419 | Secondary Air Injection System Relay “B. Circuit Malfunction |
P0420 | Catalyst System Efficiency Below Threshold (Bank 1) |
P0421 | Warm Up Catalyst Efficiency Below Threshold (Bank 1) |
P0422 | Main Catalyst Efficiency Below Threshold (Bank 1) |
P0423 | Heated Catalyst Efficiency Below Threshold (Bank 1) |
P0424 | Heated Catalyst Temperature Below Threshold (Bank 1) |
P0430 | Catalyst System Efficiency Below Threshold (Bank 2) |
P0431 | Warm Up Catalyst Efficiency Below Threshold (Bank 2) |
P0432 | Main Catalyst Efficiency Below Threshold (Bank 2) |
P0433 | Heated Catalyst Efficiency Below Threshold (Bank 2) |
P0434 | Heated Catalyst Temperature Below Threshold (Bank 2) |
P0440 | Evaporative Emission Control System Malfunction |
P0441 | Evaporative Emission Control System Incorrect Purge Flow |
P0442 | Evaporative Emission Control System Leak Detected (small leak) |
P0443 | Evaporative Emission Control System Purge Control Valve Circuit |
P0444 | Evaporative Emission Control System Purge Control Valve Circuit |
P0445 | Evaporative Emission Control System Purge Control Valve Circuit Shorted |
P0446 | Evaporative Emission Control System Vent Control Circuit Malfunction |
P0447 | Evaporative Emission Control System Vent Control Circuit Open |
P0448 | Evaporative Emission Control System Vent Control Circuit Shorted |
P0449 | Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction |
P0450 | Evaporative Emission Control System Pressure Sensor Malfunction |
P0451 | Evaporative Emission Control System Pressure Sensor Range/Performance |
P0452 | Evaporative Emission Control System Pressure Sensor Low Input |
P0453 | Evaporative Emission Control System Pressure Sensor High Input |
P0454 | Evaporative Emission Control System Pressure Sensor Intermittent |
P0455 | Evaporative Emission Control System Leak Detected (gross leak) |
P0460 | Fuel Level Sensor Circuit Malfunction |
P0461 | Fuel Level Sensor Circuit Range/Performance |
P0462 | Fuel Level Sensor Circuit Low Input |
P0463 | Fuel Level Sensor Circuit High Input |
P0464 | Fuel Level Sensor Circuit Intermittent |
P0465 | Purge Flow Sensor Circuit Malfunction |
P0466 | Purge Flow Sensor Circuit Range/Performance |
P0467 | Purge Flow Sensor Circuit Low Input |
P0468 | Purge Flow Sensor Circuit High Input |
P0469 | Purge Flow Sensor Circuit Intermittent |
P0470 | Exhaust Pressure Sensor Malfunction |
P0471 | Exhaust Pressure Sensor Range/Performance |
P0472 | Exhaust Pressure Sensor Low |
P0473 | Exhaust Pressure Sensor High |
P0474 | Exhaust Pressure Sensor Intermittent |
P0475 | Exhaust Pressure Control Valve Malfunction |
P0476 | Exhaust Pressure Control Valve Range/Performance |
P0477 | Exhaust Pressure Control Valve Low |
P0478 | Exhaust Pressure Control Valve High |
P0479 | Exhaust Pressure Control Valve Intermittent |
P0480 | Cooling Fan I Control Circuit Malfunction |
P0481 | Cooling Fan 2 Control Circuit Malfunction |
P0482 | Cooling Fan 3 Control Circuit Malfunction |
P0483 | Cooling Fan Rationality Check Malfunction |
P0484 | Cooling Fan Circuit Over Current |
P0485 | Cooling Fan Power/Ground Circuit Malfunction |
DTC Codes – P0500-P0599 – Vehicle Speed Controls and Idle Control System |
P0500 | Vehicle Speed Sensor Malfunction |
P0501 | Vehicle Speed Sensor Range/Performance |
P0502 | Vehicle Speed Sensor Low Input |
P0503 | Vehicle Speed Sensor Intermittent/Erratic/High |
P0505 | Idle Control System Malfunction |
P0506 | Idle Control System RPM Lower Than Expected |
P0507 | Idle Control System RPM Higher Than Expected |
P0510 | Closed Throttle Position Switch Malfunction |
P0520 | Engine Oil Pressure Sensor/Switch Circuit Malfunction |
P0521 | Engine Oil Pressure Sensor/Switch Circuit Range/Performance |
P0522 | Engine Oil Pressure Sensor/Switch Circuit Low Voltage |
P0523 | Engine Oil Pressure Sensor/Switch Circuit High Voltage |
P0530 | A/C Refrigerant Pressure Sensor Circuit Malfunction |
P0531 | A/C Refrigerant Pressure Sensor Circuit Range/Performance |
P0532 | A/C Refrigerant Pressure Sensor Circuit Low Input |
P0533 | A/C Refrigerant Pressure Sensor Circuit High Input |
P0534 | Air Conditioner Refrigerant Charge Loss |
P0550 | Power Steering Pressure Sensor Circuit Malfunction |
P0551 | Power Steering Pressure Sensor Circuit Range/Performance |
P0552 | Power Steering Pressure Sensor Circuit Low Input |
P0553 | Power Steering Pressure Sensor Circuit High Input |
P0554 | Power Steering Pressure Sensor Circuit Intermittent |
P0560 | System Voltage Malfunction |
P0561 | System Voltage Unstable |
P0562 | System Voltage Low |
P0563 | System Voltage High |
P0565 | Cruise Control On Signal Malfunction |
P0566 | Cruise Control Off Signal Malfunction |
P0567 | Cruise Control Resume Signal Malfunction |
P0568 | Cruise Control Set Signal Malfunction |
P0569 | Cruise Control Coast Signal Malfunction |
P0570 | Cruise Control Accel Signal Malfunction |
P0571 | Cruise Control/Brake Switch A Circuit Malfunction |
P0572 | Cruise Control/Brake Switch A Circuit Low |
P0573 | Cruise Control/Brake Switch A Circuit High |
P0574 | Cruise Control Related Malfunction |
P0575 | Cruise Control Related Malfunction |
P0576 | Cruise Control Related Malfunction |
P0578 | Cruise Control Related Malfunction |
P0579 | Cruise Control Related Malfunction |
P0580 | Cruise Control Related Malfunction |
DTC Codes – P0600-P0699 – Computer Output Circuit |
P0600 | Serial Communication Link Malfunction |
P0601 | Internal Control Module Memory Check Sum Error |
P0602 | Control Module Programming Error |
P0603 | Internal Control Module Keep Alive Memory (KAM) Error |
P0604 | Internal Control Module Random Access Memory (RAM) Error |
P0605 | Internal Control Module Read Only Memory (ROM) Error |
P0606 | PCM Processor Fault |
P0608 | Control Module VSS Output “A” Malfunction |
P0609 | Control Module VSS Output “B” Malfunction |
P0620 | Generator Control Circuit Malfunction |
P0621 | Generator Lamp “L” Control Circuit Malfunction |
P0622 | Generator Field “F” Control Circuit Malfunction |
P0650 | Malfunction Indicator Lamp (MIL) Control Circuit Malfunction |
P0654 | Engine RPM Output Circuit Malfunction |
P0655 | Engine Hot Lamp Output Control Circuit Malfunction |
P0656 | Fuel Level Output Circuit Malfunction |
DTC Codes – P0700-P0899 – Transmission |
P0700 | Transmission Control System Malfunction |
P0701 | Transmission Control System Range/Performance |
P0702 | Transmission Control System Electrical |
P0703 | Torque Converter/Brake Switch B Circuit Malfunction |
P0704 | Clutch Switch Input Circuit Malfunction |
P0705 | Transmission Range Sensor Circuit malfunction (PRNDL Input) |
P0706 | Transmission Range Sensor Circuit Range/Performance |
P0707 | Transmission Range Sensor Circuit Low Input |
P0708 | Transmission Range Sensor Circuit High Input |
P0709 | Transmission Range Sensor Circuit Intermittent |
P0710 | Transmission Fluid Temperature Sensor Circuit Malfunction |
P0711 | Transmission Fluid Temperature Sensor Circuit Range/Performance |
P0712 | Transmission Fluid Temperature Sensor Circuit Low Input |
P0713 | Transmission Fluid Temperature Sensor Circuit High Input |
P0714 | Transmission Fluid Temperature Sensor Circuit Intermittent |
P0715 | Input/Turbine Speed Sensor Circuit Malfunction |
P0716 | Input/Turbine Speed Sensor Circuit Range/Performance |
P0717 | Input/Turbine Speed Sensor Circuit No Signal |
P0718 | Input/Turbine Speed Sensor Circuit Intermittent |
P0719 | Torque Converter/Brake Switch B Circuit Low |
P0720 | Output Speed Sensor Circuit Malfunction |
P0721 | Output Speed Sensor Range/Performance |
P0722 | Output Speed Sensor No Signal |
P0723 | Output Speed Sensor Intermittent |
P0724 | Torque Converter/Brake Switch B Circuit High |
P0725 | Engine Speed input Circuit Malfunction |
P0726 | Engine Speed Input Circuit Range/Performance |
P0727 | Engine Speed Input Circuit No Signal |
P0728 | Engine Speed Input Circuit Intermittent |
P0730 | Incorrect Gear Ratio |
P0731 | Gear I Incorrect ratio |
P0732 | Gear 2 Incorrect ratio |
P0733 | Gear 3 Incorrect ratio |
P0734 | Gear 4 Incorrect ratio |
P0735 | Gear 5 Incorrect ratio |
P0736 | Reverse incorrect gear ratio |
P0740 | Torque Converter Clutch Circuit Malfunction |
P0741 | Torque Converter Clutch Circuit Performance or Stuck Off |
P0742 | Torque Converter Clutch Circuit Stock On |
P0743 | Torque Converter Clutch Circuit Electrical |
P0744 | Torque Converter Clutch Circuit Intermittent |
P0745 | Pressure Control Solenoid Malfunction |
P0746 | Pressure Control Solenoid Performance or Stuck Off |
P0747 | Pressure Control Solenoid Stuck On |
P0748 | Pressure Control Solenoid Electrical |
P0749 | Pressure Control Solenoid Intermittent |
P0750 | Shift Solenoid A Malfunction |
P0751 | Shift Solenoid A Performance or Stuck Off |
P0752 | Shift Solenoid A Stuck On |
P0753 | Shift Solenoid A Electrical |
P0754 | Shift Solenoid A Intermittent |
P0755 | Shift Solenoid B Malfunction |
P0756 | Shift Solenoid B Performance or Stock Off |
P0757 | Shift Solenoid B Stuck On |
P0758 | Shift Solenoid B Electrical |
P0759 | Shift Solenoid B Intermittent |
P0760 | Shift Solenoid C Malfunction |
P0761 | Shift Solenoid C Performance or Stuck Off |
P0762 | Shift Solenoid C Stuck On |
P0763 | Shift Solenoid C Electrical |
P0764 | Shift Solenoid C Intermittent |
P0765 | Shift Solenoid D Malfunction |
P0766 | Shift Solenoid D Performance or Stuck Off |
P0767 | Shift Solenoid D Stuck On |
P0768 | Shift Solenoid D Electrical |
P0769 | Shift Solenoid D Intermittent |
P0770 | Shift Solenoid E Malfunction |
P0771 | Shift Solenoid E Performance or Stuck Off |
P0772 | Shift Solenoid E Stuck On |
P0773 | Shift Solenoid E Electrical |
P0774 | Shift Solenoid E Intermittent |
P0780 | Shift Malfunction |
P0781 | 1-2 Shift Malfunction |
P0782 | 2-3 Shift Malfunction |
P0783 | 3-4 Shift Malfunction |
P0784 | 4-5 Shift Malfunction |
P0785 | Shift/Timing Solenoid Malfunction |
P0786 | Shift/Timing Solenoid Range/Performance |
P0787 | Shift/Timing Solenoid Low |
P0788 | Shift/Timing Solenoid High |
P0789 | Shift/Timing Solenoid Intermittent |
P0790 | Normal/Performance Switch Circuit Malfunction |
P0801 | Reverse Inhibit Control Circuit Malfunction |
P0803 | 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction |
P0804 | 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction |
P1000-P1999 – Codes Specific to Ford vehicles |
P1000 | OBD-II Monitor Testing Incomplete |
P1001 | KOER Test Cannot Be Completed |
P1039 | Vehicle Speed Signal Missing or Improper |
P1051 | Brake Switch Signal Missing or Improper |
P1100 | Mass Air Flow Sensor Intermittent |
P1101 | Mass Air Flow Sensor out of Self-Test? Range |
P1105 | Dual Alternator Upper Fault |
P1106 | Dual Alternator Lower Fault/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage |
P1107 | Dual Alternator Lower Circuit Malfunction/ Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage |
P1108 | Dual Alternator Battery Lamp Circuit Malfunction |
P1109 | IAT – B Sensor Intermittent |
P1111 | System Pass |
P1112 | Intake Air Temperature Sensor Intermittent |
P1114 | Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage/IAT – B Circuit Low Input |
P1115 | Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage/IAT – B Circuit High Input |
P1116 | Engine Coolant Temperature Sensor is out of Self-Test? Range |
P1117 | Engine Coolant Temperature Sensor Intermittent |
P1120 | Throttle Position Sensor out of range |
P1121 | Throttle Position Sensor Inconsistent with Mass Air Flow Sensor |
P1124 | Throttle Position Sensor out of Self-Test? Range |
P1125 | Throttle Position Sensor Intermittent |
P1126 | Heated Oxygen Sensor Heater not on During KOER Test |
P1127 | Exhaust Not Warm Enough – Downstream O2 Sensor Not Tested |
P1128 | Heated Oxygen Sensor Signals reversed |
P1129 | Heated Oxygen Sensor Signals reversed |
P1130 | Lack of Upstream Heated Oxygen Sensor Switch – Adaptive Fuel Limit – Bank No. 1 |
P1131 | Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1 |
P1132 | Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Rich – Bank No. 1 |
P1133 | Bank 1 Fuel Control Shifted Lean |
P1134 | Bank 1 Fuel Control Shifted Rich |
P1135 | Pedal Position Sensor A Circuit Intermittent |
P1135 | Ignition Switch Signal Missing or Improper |
P1137 | Lack of Downstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 1 |
P1138 | Lack of Downstream Heated Oxygen Sensor Switch – Sensor Indicates Rich – Bank No. 1 |
P1139 | Water In Fuel Indicator Circuit Malfunction |
P1140 | Water In Fuel Condition |
P1141 | Fuel Restriction Indicator Circuit Malfunction |
P1142 | Fuel Restriction Condition |
P1150 | Lack of Upstream Heated Oxygen Sensor Switch – Adaptive Fuel Limit – Bank No. 2 |
P1151 | Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 2 |
P1152 | Lack of Upstream Heated Oxygen Sensor Switch – Sensor Indicates Rich – Bank No. 2 |
P1153 | Bank 2 Fuel Control Shifted Lean |
P1154 | Bank 2 Fuel Control Shifted Rich |
P1155 | Alternative Fuel Controller |
P1157 | Lack of Downstream Heated Oxygen Sensor Switch – Sensor Indicates Lean – Bank No. 2 |
P1158 | Lack of Downstream Heated Oxygen Sensor Switch – Sensor Indicates Rich – Bank No. 2 |
P1169 | Fuel Rail Sensor In-Range High Failure |
P1170 | ESO – Engine Shut Off Solenoid Fault |
P1171 | Rotor Sensor Fault |
P1172 | Rotor Control Fault |
P1173 | Rotor Calibration Fault |
P1174 | Cam Sensor Fault |
P1175 | Cam Control Fault |
P1176 | Cam Calibration Fault |
P1177 | Synchronization Fault |
P1180 | Fuel Delivery System Malfunction – Low |
P1181 | Fuel Delivery System Malfunction – High |
P1183 | Engine Oil Temperature Circuit Malfunction |
P1184 | Engine Oil Temperature Out Of Self Test Range |
P1185 | FTS High – Fuel Pump Temperature Sensor High |
P1186 | FTS Low – Fuel Pump Temperature Sensor Low |
P1187 | Variant Selection |
P1188 | Calibration Memory Fault |
P1189 | Pump Speed Signal Fault |
P1190 | Calibration Resistor Out Of Range |
P1191 | Key Line Voltage |
P1192 | Voltage External |
P1193 | EGR Drive Overcurrent |
P1194 | ECU A/D Converter |
P1195 | SCP HBCC Failed To Initialize |
P1196 | Key Off Voltage High |
P1197 | Key Off Voltage Low |
P1198 | Pump Rotor Control Underfueling |
P1209 | Injector Control Pressure System Fault |
P1210 | Injector Control Pressure Above Expected Level |
P1211 | Injector Control Pressure Sensor Above / Below Desired |
P1212 | Injector Control Pressure Not Detected During Crank |
P1213 | Start Injector Circuit Malfunction |
P1214 | Pedal Position Sensor B Circuit Intermittent |
P1215 | Pedal Position Sensor C Circuit Low Input |
P1216 | Pedal Position Sensor C Circuit High Input |
P1217 | Pedal Position Sensor C Circuit Intermittent |
P1218 | CID High |
P1219 | CID Low |
P1220 | Series Throttle Control Fault |
P1221 | Traction Control System Malfunction |
P1222 | Traction Control Output Circuit Malfunction |
P1223 | Pedal Demand Sensor B Circuit High Input |
P1224 | Throttle Position Sensor B out of Self-Test? Range |
P1230 | Open Power to Fuel Pump circuit |
P1231 | High Speed Fuel Pump Relay activated |
P1232 | Low Speed Fuel Pump Primary circuit failure |
P1233 | Fuel Pump Driver Module off-line |
P1234 | Fuel Pump Driver Module off-line |
P1235 | Fuel Pump Control out of range |
P1236 | Fuel Pump Control out of range |
P1237 | Fuel Pump Secondary circuit fault |
P1238 | Fuel Pump Secondary circuit fault |
P1239 | Speed Fuel Pump Positive Feed Fault |
P1243 | Second Fuel Pump Faulty or Ground Fault |
P1244 | Alternator Load Input Failed High |
P1245 | Alternator Load Input Failed Low |
P1246 | Alternator Load Input Failed |
P1247 | Turbo Boost Pressure Low |
P1248 | Turbo Boost Pressure Not Detected |
P1249 | Wastegate Control Valve Performance |
P1250 | Lack of Power to FPRC Solenoid |
P1252 | Pedal Correlation PDS1 and LPDS High |
P1253 | Pedal Correlation PDS1 and LPDS Low |
P1254 | Pedal Correlation PDS2 and LPDS High |
P1255 | Pedal Correlation PDS2 and LPDS Low |
P1256 | Pedal Correlation PDS1 and HPDS |
P1257 | Pedal Correlation PDS2 and HPDS |
P1258 | Pedal Correlation PDS1 and PDS2 |
P1260 | Theft Detected – Engine Disabled |
P1261 | Cylinder #1 High To Low Side Short |
P1262 | Cylinder #2 High To Low Side Short |
P1263 | Cylinder #3 High To Low Side Short |
P1264 | Cylinder #4 High To Low Side Short |
P1265 | Cylinder #5 High To Low Side Short |
P1266 | Cylinder #6 High To Low Side Short |
P1267 | Cylinder #7 High To Low Side Short |
P1268 | Cylinder #8 High To Low Side Short |
P1288 | Cylinder Head Temperature Sensor out of Self-Test? Range |
P1289 | Cylinder Head Temperature Sensor Signal Greater Than Self-Test? Range |
P1290 | Cylinder Head Temperature Sensor Signal Less Than Self-Test? Range |
P1299 | Cylinder Head Temperature Sensor Detected Engine Overheating Condition |
P1309 | Misfire Detection Monitor not enabled |
P1351 | Ignition Diagnostic Monitor circuit Input fault |
P1352 | Ignition Coil A – Primary circuit fault |
P1353 | Ignition Coil B – Primary circuit fault |
P1354 | Ignition Coil C – Primary circuit fault |
P1355 | Ignition Coil D – Primary circuit fault |
P1356 | Loss of Ignition Diagnostic Module Input to PCM |
P1358 | Ignition Diagnostic Monitor Signal out of Self-Test? Range |
P1359 | Spark Output circuit fault |
P1364 | Ignition Coil Primary circuit fault |
P1380 | VCT Solenoid Valve circuit Short or Open |
P1381 | Cam Timing Advance is excessive |
P1383 | Cam Timing Advance is excessive |
P1390 | Octane Adjust out of Self-Test? Range |
P1400 | Diff Pressure Feedback EGR Circuit Low Input |
P1401 | Diff Pressure Feedback EGR Circuit High Input |
P1402 | Exhaust Gas Recirculation Metering Orifice Restricted |
P1403 | Diff Pressure Feedback Sensor Hoses Reversed |
P1404 | EGR Temperature Sensor Circuit |
P1405 | Diff Pressure Feedback Sensor Upstream Hose Off/Plugged |
P1406 | Diff Pressure Feedback Sensor Downstream Hose Off/Plugged |
P1407 | Exhaust Gas Recirculation No Flow Detected |
P1408 | Exhaust Gas Recirculation Flow Out Of Self Test Range |
P1409 | EGR Vacuum Regulator Solenoid Circuit |
P1410 | Auxiliary Air Cleaner Inlet Control Circuit |
P1411 | Sec Air Injection Incorrect Downstream Flow Detected |
P1412 | Exhaust Gas Recirculaton Valve Frozen |
P1413 | Sec Air Injection Monitor Circuit Low Input |
P1414 | Sec Air Injection Monitor Circuit High Input |
P1415 | Air Pump Circuit |
P1416 | Port Air Circuit |
P1417 | Port Air Relief Circuit |
P1418 | Split Air #`1 Circuit |
P1419 | Split Air #`2 Circuit |
P1420 | Catalyst Temperature Sensor |
P1421 | Catalyst Damage |
P1422 | Exhaust Gas Ignition Temperature Sensor |
P1423 | Exhaust Gas Ignition Functional Test |
P1424 | Exhaust Gas Ignition Plug Primary |
P1425 | Exhaust Gas Ignition Plug Secondary |
P1426 | Exhaust Gas Ignition mini-MAF Sensor Out of Range |
P1427 | Exhaust Gas Ignition mini-MAF Sensor Sensor Circuit Shorted |
P1428 | Exhaust Gas Ignition mini-MAF Sensor Sensor Circuit Open |
P1429 | Electric Air Pump Primary |
P1430 | Electric Air Pump Secondary |
P1431 | Misfire Monitor Disabled; unable to learn wheel profile |
P1432 | Thermostat Heater Control Circuit |
P1433 | A/C Refrigerant Temperature Circuit Low |
P1434 | A/C Refrigerant Temperature Circuit High |
P1435 | A/C Refrigerant Temperature Circuit Range/Performance |
P1436 | A/C Evaporator Air Temperature Circuit Low |
P1437 | A/C Evaporator Air Temperature Circuit High |
P1438 | A/C Evaporator Air Temperature Circuit Range/Performance |
P1439 | Floor Temperature Switch Circuit |
P1440 | Purge Valve Stuck Open |
P1441 | ELC System 1 |
P1442 | Evaporative Emission System Control Leak Detected |
P1443 | Evaporative Emission System Control Valve (low/no flow) |
P1444 | Evaporative Emission System Purge Flow Sensor Circuit Low Input |
P1445 | Purge Flow Sensor Circuit High Input |
P1446 | Evaporative Vacuum Solenoid Circuit |
P1447 | ELC System Closure Valve Flow |
P1448 | ELC System 2 |
P1449 | Evaporative Check Solenoid Circuit |
P1450 | Unable to Bleed Up Fuel Tank Vacuum |
P1451 | Evap Emission Control System Vent Control Circuit |
P1452 | Unable to Bleed Up Fuel Tank Vacuum |
P1453 | Fuel Tank Pressure Relief Valve Malfunction |
P1454 | Evaporative Emission System Vacuum Test |
P1455 | Evaporative Emission Control System Control Leak (gross leak/no flow) |
P1456 | Fuel Tank Temperature Sensor Circuit |
P1457 | Unable To Pull Fuel Tank Vacuum |
P1458 | Ignition Timing Control Solenoid |
P1459 | A/C Recirculation Switch Out of Self Test Range |
P1460 | Wide Open Throttle A/C Cutout Circuit |
P1461 | A/C Pressure Sensor Circuit High Input |
P1462 | A/C Pressure Sensor Circuit Low Input |
P1463 | A/C Pressure Sensor Insufficient Pressure Change |
P1464 | A/C On During KOER/CCT Test |
P1465 | A/C Relay Circuit |
P1466 | A/C Refrigerant Temperature Sensor Circuit |
P1467 | A/C Compressor Temperature Sensor |
P1468 | SSPOD Open Circuit of Closed Circuit |
P1469 | Rapid A/C Cycling |
P1470 | A/C Cycling Period Too Short |
P1471 | Electrodrive Fan 1 Operational Failure (Driver side) |
P1472 | Electrodrive Fan 2 Operational Failure (Passenger side) |
P1473 | Fan Circuit Open (VLCM |
P1474 | Fan Control Primary Circuit |
P1475 | Fan Relay (Low) Circuit |
P1476 | Fan Relay (High) Circuit |
P1477 | Additional Fan Relay Circuit |
P1478 | Cooling Fan Driver |
P1479 | High Fan Control Primary Circuit |
P1480 | Fan Sec Low with Low Fan On |
P1481 | Fan Sec Low with High Fan On |
P1482 | SCP |
P1483 | Fan Circuit Shorted To Ground (VLCM) |
P1484 | Fan Dvr Circuit Open To Power Ground (VLCM) |
P1485 | Brake Pedal Input Short To Battery |
P1486 | EGRA Circuit |
P1487 | Exhaust Gas Recirculation Check Solenoid Circuit |
P1488 | Exhaust (muffler) Bypass Control Circuit |
P1489 | PCV Heater Control Circuit |
P1490 | Secondary Air Relief Solenoid Circuit |
P1491 | Secondary Switch Solenoid Circuit |
P1492 | APLSOL Solenoid Circuit |
P1493 | RCNT Solenoid Circuit |
P1494 | SPCUT Solenoid Circuit |
P1495 | TCSPL Solenoid Circuit |
P1496 | EGR Stepper Motor 1 Control Circuit Low/High |
P1497 | EGR Stepper Motor 2 Control Circuit Low/High |
P1498 | EGR Stepper Motor 3 Control Circuit Low/High |
P1499 | EGR Stepper Motor 4 Control Circuit Low/High |
P1500 | Vehicle Speed Sensor |
P1501 | Vehicle Speed Sensor Out Of Self Test Range |
P1502 | VSS Intermittent/Invalid Self Test – APCM Functioning |
P1503 | Auxiliary Speed Sensor |
P1504 | Idle Air Control Circuit |
P1505 | Idle Air Control System At Adaptive Clip |
P1506 | Idle Air Control Overspeed Error |
P1507 | Idle Air Control Underspeed Error |
P1508 | Idle Air Control Circuit Open |
P1509 | Idle Air Control Circuit Shorted |
P1510 | Idle Signal Circuit |
P1511 | Idle Switch (Electric Control Throttle) Circuit |
P1512 | Intake Manifold Runner Control Stuck Closed (bank1) |
P1513 | Intake Manifold Runner Control Stuck Closed (bank2) |
P1514 | high Load Neutral/Drive Fault |
P1515 | Electric Current Circuit |
P1516 | Intake Manifold Runner Control Input Error (bank1) |
P1517 | Intake Manifold Runner Control Input Error (bank2) |
P1518 | Intake Manifold Runner Control Stuck Open (bank1) |
P1519 | Intake Manifold Runner Control Stuck Closed (bank2) |
P1520 | Intake Manifold Runner Control Circuit |
P1521 | Variable Resonance Induction System Solenoid #1 Circuit |
P1522 | Variable Resonance Induction System Solenoid #2 Circuit |
P1523 | IVC Solenoid Circuit |
P1524 | Variable Intake Solenoid Circuit |
P1525 | Air Bypass Valve |
P1526 | Air Bypass System |
P1527 | Bypass Air Solenoid (Accelerate Warm-up) Circuit |
P1528 | Subsidiary Throttle Valve Solenoid |
P1529 | SCAIR Solenoid Circuit |
P1530 | A/C Clutch Circuit Open (VLCM) |
P1531 | Invalid Test -Accelerator Pedal Movement |
P1532 | Intake Manifold Communication Control Circuit (bank2) |
P1533 | Air Assisted Injector Circuit |
P1534 | Restraint Deployment Indicator Circuit |
P1535 | Blower Fan Speed Circuit Range/Performance |
P1536 | Parking Brake Applied Failure |
P1537 | Intake Manifold Runner Control Stuck Open (bank1) |
P1538 | Intake Manifold Runner Control Stuck Open (bank2) |
P1539 | A/C Clutch Circuit Overcurrent/Short (VLCM) |
P1540 | Air Bypass Valve Circuit |
P1541 | Intake Manifold Runner Control Circuit Range/Performance (see 2015) |
P1542 | Primary PCM ID Circuit (dual PCM application) |
P1543 | Engine Coolant heater A Control Circuit |
P1544 | Engine Coolant heater B Control Circuit |
P1545 | Exhaust Gas Recirculation High Side Control Circuit / Open |
P1546 | Exhaust Gas Recirculation High Side Control Circuit Low |
P1547 | Exhaust Gas Recirculation High Side Control Circuit High |
P1549 | Intake Manifold Communication Control Circuit (bank1) |
P1550 | Power Steering Pressure Sensor Out Of Self Test Range |
P1551 | Injector Circuit Range/Performance – Cylinder 1 |
P1552 | Injector Circuit Range/Performance – Cylinder 2 |
P1553 | Injector Circuit Range/Performance – Cylinder 3 |
P1554 | Injector Circuit Range/Performance – Cylinder 4 |
P1555 | Injector Circuit Range/Performance – Cylinder 5 |
P1556 | Injector Circuit Range/Performance – Cylinder 6 |
P1557 | Injector Circuit Range/Performance – Cylinder 7 |
P1558 | Injector Circuit Range/Performance – Cylinder 8 |
P1562 | PCM B+ Voltage Low (KAM power) |
P1563 | Injection Pump Control Module Requesting Engine Stop |
P1564 | Injection Pump Control Module Requesting Reduced Fueling |
P1565 | Speed Control Command Switch Out of Range High |
P1566 | Speed Control Command Switch Out of Range Low |
P1567 | Speed Control Output Circuit |
P1568 | Speed Control Unable to Hold Speed |
P1569 | Intake Manifold Runner Control Circuit Low |
P1570 | Intake Manifold Runner Control Circuit High |
P1571 | Brake Switch |
P1572 | Brake Pedal Switch Circuit |
P1573 | Throttle Position Not Available |
P1574 | Throttle Position Sensor Outputs Disagree |
P1575 | Pedal Position Out Of Self Test Range |
P1576 | Pedal Position Not Available |
P1577 | Pedal Position Sensor Outputs Disagree |
P1578 | ETC Power Less Than Demand |
P1579 | ETC In Power Limiting Mode |
P1580 | Electronic Throttle Monitor PCM Override |
P1581 | Electronic Throttle Monitor Error |
P1582 | Electronic Throttle Monitor Data Available |
P1583 | Electronic Throttle Monitor Cruise Disablement |
P1584 | Throttle Control Detected ETB Error |
P1585 | Throttle Control Error |
P1586 | Electronic Throttle to PCM Communication Error |
P1587 | Throttle Control Modulated Command Error |
P1588 | Throttle Control Detected Loss Of Return Spring |
P1589 | Throttle Control Unable To Control To Desired Throttle Angle |
P1590 | Cruise Control INCREASE DISTANCE Signal |
P1591 | Cruise Control DECREASE DISTANCE Signal |
P1592 | Vehicle Data Recorder Data Available |
P1600 | Loss Of KAM Power-Circuit Open |
P1601 | ECM/TCM Serial Communication Error |
P1602 | Immobilizer/ECM Communication Error |
P1603 | ID Number Unregistered |
P1604 | Code Word Unregistered |
P1605 | Keep Alive Memory Test Failure |
P1606 | ECM Control Relay Output Circuit |
P1607 | MIL Output Circuit |
P1608 | PCM Internal Circuit |
P1609 | Diagnostic Lamp Driver |
P1610 | SBDS Interactive Codes |
P1611 | SBDS Interactive Codes |
P1612 | SBDS Interactive Codes |
P1613 | SBDS Interactive Codes |
P1614 | SBDS Interactive Codes |
P1615 | SBDS Interactive Codes |
P1616 | SBDS Interactive Codes |
P1617 | SBDS Interactive Codes |
P1618 | SBDS Interactive Codes |
P1619 | SBDS Interactive Codes |
P1620 | SBDS Interactive Codes |
P1621 | Immobilizer Code Words Do Not Match |
P1622 | Immobilizer ID Does Not Match |
P1623 | Immobilizer Code Word/ID Number Write Failure |
P1624 | Anti-theft System |
P1625 | Fan Dvr Circuit Open to Power B+ (VLCM) |
P1626 | A/C Circuit Open to Power B+ (VLCM) |
P1627 | Module Supply Voltage Out Of Range |
P1628 | Module Ignition Supply Input |
P1629 | Internal Voltage Regulator |
P1630 | Alternator regulator #1 Control Circuit |
P1631 | Alternator regulator #2 Control Circuit |
P1632 | Smart Alternator Faults Sensor / Circuit |
P1633 | Keep Alive Power Voltage Too Low |
P1634 | Data Output Link Circuit |
P1635 | Tire/Axle Out of Acceptable Range |
P1636 | Inductive Signature Chip Communication Error |
P1637 | CAN link ECM/ABS Control Module Circuit/Network |
P1638 | CAN Link ECM/INSTM Circuit/Network |
P1639 | Vehicle ID Block Corrupted-Not Programmed |
P1640 | Powertrain DTCs Available In Another Control Module |
P1641 | Fuel Pump Primary Circuit |
P1642 | CAN Link Circuit |
P1643 | CAN Link Engine Control Module/Tran Control Module Circuit/Network |
P1644 | Fuel Pump Speed Control Circuit |
P1645 | Fuel Pump Resistor Switch Circuit |
P1646 | Linear 02 Sensor Control Chip (Bank 1) |
P1647 | Linear 02 Sensor Control Chip (Bank 2) |
P1648 | Knock Sensor Input Chip |
P1649 | Fuel Injection Pump Module |
P1650 | Power Steering Pressure Switch Out Of Self Test Range |
P1651 | Power Steering Pressure Switch Input |
P1652 | Idle Air Control Monitor Disabled By PSPS Failed On |
P1653 | Power Steering Output Circuit |
P1654 | recirculation Override Circuit |
P1655 | Starter Disable Circuit |
P1656 | CAN Link PCM/PCM Circuit/Network |
P1657 | CAN Link Chip Error |
P1658 | Injector Pump Control Module System Voltage |
P1659 | Injector Pump Control Module Power Circuit |
P1660 | Output Circuit Check Circuit High Input |
P1661 | Output Circuit Check Circuit Low Input |
P1662 | EDU_EN Output Circuit |
P1663 | Fuel Demand Command Signal Output Circuit Failure |
P1664 | Injector Pump Control Module Malfunction |
P1665 | Injector Pump Control Module Communications |
P1666 | Injector Pump Control Module/ECM Crank Reference Synchronization |
P1667 | Cylinder ID Circuit Failure |
P1668 | PCM/IDM Diagnostic Communication Error |
P1669 | Injector Pump Control Module Monitoring ECM Fault |
P1670 | EF Feedback Signal Not Detected |
P1671 | Secondary Fuel Pump Relay |
P1672 | CAN Link ECM / Suspension Control Module Circuit/Network |
P1673 | ABS Lamp Control Circuit |
P1674 | Control Module Software Corrupted |
P1675 | Injector Data Not Programmed |
P1676 | Injector Data Incompatible |
P1677 | Alternative Fuel Control Communication Circuit |
P1678 | Low Oil Pressure Lamp Control Circuit |
P1679 | Engine Oil Pressure Output Circuit |
P1680 | Metering Oil Pump Failure |
P1683 | Metering Oil Pump Temperature Sensor Circuit |
P1684 | Metering Oil Pump Position Sensor Circuit |
P1685 | Metering Oil Pump Stepping Motor Cont. Circuit |
P1689 | Oil Pressure Control Solenoid Circuit |
P1690 | Wastegate Control Valve Error |
P1691 | Turbocharger Pressure Control Solenoid Circuit |
P1692 | Turbocharger Control Solenoid Circuit |
P1693 | Turbocharger Charge Control Circuit |
P1694 | Turbocharger Charge Relief Circuit |
P1695 | CAN Link Injection Pump Control Module/Engine Control Module |
P1696 | CAN Link Engine Control Module/Cruise Control Module Circuit/Network |
P1697 | Cruise Control distance-Control Input Circuit |
P1700 | Tran Indeterminate Failure (Failed to Neutral) |
P1701 | Reverse Engagement Error |
P1702 | Tran Range Sensor Intermittent Circuit Error |
P1703 | Brake Switch Out Of Self Test Range |
P1704 | Transmission Range Circuit Not Indicating Park/Neutral During Self Test |
P1705 | Tran Range Circuit Not Indicating P/N in Self test |
P1706 | High Vehicle Speed Observed in Park |
P1707 | Transfer Case Neutral Indicator Hard Fault Present |
P1708 | Clutch Switch Circuit |
P1709 | Park Neutral Position Switch Out Of Self Test Range |
P1710 | Transmission Control Module Solenoid/Internal Ground Circuit |
P1711 | Tran Fluid Temperature Sensor Out Of Self Test Range |
P1712 | Tran Torque Reduction Request Signal |
P1713 | Tran Fluid Temperature Sensor In Range Failure(< 50 F) |
P1714 | Shift Solenoid A Inductive Signature |
P1715 | Shift Solenoid B Inductive Signature Error |
P1716 | Shift Solenoid C Inductive Signature |
P1717 | Shift Solenoid D Inductive Signature |
P1718 | TFT Stuck in Range High-25OF |
P1719 | Engine Torque Signal |
P1720 | Vehicle Speed (Meter) Circuit |
P1721 | Gear 1 Incorrect Ratio |
P1722 | Gear 1 Incorrect Ratio |
P1721 | Gear 2 Incorrect Ratio |
P1723 | Gear 3 Incorrect Ratio |
P1724 | Gear 4 Incorrect Ratio |
P1725 | Insufficient Engine Speed Increase During Self Test |
P1726 | Insufficient Engine Speed Decrease During Self Test |
P1727 | Coast Clutch Solenoid Inductive Signature |
P1728 | Tran Slip Error |
P1729 | 4x4L Switch Error |
P1730 | Gear Control Malfunction 2,3,5 |
P1731 | 1-2 Shift Error |
P1732 | 2-3 Shift Error |
P1733 | 3-4 Shift Error |
P1734 | 4-5 Shift Malfunction |
P1735 | First Gear Switch Circuit Failure |
P1736 | Second Gear Switch Circuit Failure |
P1737 | Lockup Solenoid |
P1738 | Shift Time Error |
P1739 | Slip Solenoid |
P1740 | Torque Converter Clutch Solenoid Inductive Signal |
P1741 | Torque Converter Clutch Solenoid Control Error |
P1742 | Torque Converter Clutch Solenoid Circuit Failed On |
P1743 | Torque Converter Clutch Solenoid Circuit Failed On* |
P1744 | Torque Converter Clutch System Performance |
P1745 | Line Pressure Solenoid |
P1746 | EPC Solenoid Open Circuit |
P1747 | EPC Solenoid Short Circuit |
P1748 | Pressure Control Solenoid A |
P1749 | Pressure Control Solenoid A Failed Low |
P1750 | Clutch Adaptive Learning Not Done |
P1751 | Shift Solenoid A Performance |
P1752 | Shift Solenoid A Circuit Short |
P1754 | Coast Clutch Solenoid Circuit Error |
P1755 | CAN ECM/Park Brake Control Module Circuit Malfunction |
P1756 | Shift Solenoid B Performance |
P1757 | Shift Solenoid B Circuit Short |
P1758 | Pressure Solenoid Control System Incorrect Current |
P1759 | 2-4 Brake Failsafe Valve Malfunction |
P1760 | EPC Solenoid Short Intermittent |
P1761 | Shift Solenoid C Performance |
P1762 | Overdrive Band Failed Off |
P1763 | Low and Reverse Brake Pressure Switch Circuit |
P1764 | Low and Reverse Brake Failsafe Valve Malfunction |
P1765 | Timing Solenoid Circuit |
P1766 | Shift Solenoid D Performance |
P1767 | Torque Converter Clutch Circuit |
P1768 | Performance/Normal/Winter Mode Input |
P1769 | AG4 Transmission Torque Modulation Fault (VW trans) |
P1770 | Clutch Solenoid Circuit |
P1771 | Sift Solenoid E Performance |
P1772 | Throttle Position Sensor Circuit Low Input |
P1773 | CAN Link PCM/Fuel Fied Heater Malfunction |
P1774 | CAN Link Gear Shift Module / TCM |
P1775 | Transmission System MIL Fault |
P1776 | Ignition Retard Request Duration |
P1777 | Ignition Retard Request Circuit |
P1778 | Transmission Reverse I/P Circuit |
P1779 | TCIL Circuit |
P1780 | TCS Circuit Out of self Test Range |
P1781 | 4x4L Circuit Out of Self Test Range |
P1782 | Performance/Economy Switch Circuit Out Of Self Test Range |
P1783 | Tran Overtemp Condition |
P1784 | Tran Mechanical Failure – 1st And Reverse |
P1785 | Tran Mechanical Failure – 1st And 2nd |
P1786 | 3-2 Downshift Error |
P1786 | 3-2 Downshift Error/td> |
P1787 | 2-1 Downshift Error |
P1788 | Pressure Control Solenoid B Open Circuit |
P1789 | Pressure Control Solenoid B Short Circuit |
P1790 | TP (Mechanical) Circuit |
P1791 | TP (Electric) Circuit |
P1792 | Barometer Pressure Circuit |
P1793 | Intake Air Volume Circuit |
P1794 | Battery Voltage Circuit |
P1795 | Inconsistent CAN Level |
P1796 | Kick Down Switch Circuit |
P1797 | Clutch Pedal Position Switch/Neutral Switch Circuit |
P1798 | Coolant Temperature Circuit |
P1799 | CAN TCM/ABS Circuit Malfunction |
P1800 | Transmission Clutch Interlock Safety Switch Circuit Failure |
P1801 | Transmission Clutch Interlock Safety Switch Open Circuit |
P1802 | Transmission Clutch Interlock Safety Switch Short Circuit To Battery |
P1803 | Transmission Clutch Interlock Safety Switch Short Circuit To Ground |
P1804 | 4WD High Indicator Circuit Open/Shorted To Ground |
P1805 | 4-Wheel Drive High Indicator Open Circuit |
P1806 | 4WD High Indicator Short To Battery |
P1807 | 4-Wheel Drive High Indicator Short Circuit to Ground |
P1808 | 4WD Low Indicator Circuit Open/Short To Ground |
P1809 | 4-Wheel Drive Low Indicator Open Circuit |
P1810 | 4WD Low Indicator Short To Battery |
P1811 | 4-Wheel Drive Low Indicator Short Circuit To Ground |
P1812 | 4WD Mode Select Switch Circuit Open |
P1813 | 4-Wheel Drive Mode Select Open Circuit |
P1814 | 4-Wheel Drive Mode Select Short Circuit To Battery |
P1815 | 4WD Mode Select Switch Circuit Short To Ground |
P1816 | Transmission Neutral Safety Switch Circuit Failure |
P1817 | Transmission Neutral Safety Switch Open Circuit |
P1818 | Transmission Neutral Safety Switch Short Circuit To Battery |
P1819 | Neutral Safety Switch Input Short To Ground |
P1820 | Transfer Case LO/HI Shift Relay Circuit Open/Short To Gnd |
P1821 | Transfer Case Clockwise Shift Relay Coil Open Circuit |
P1822 | Transfer Case LO/HI Shift Relay Coil Short To Battery |
P1823 | Transfer Case Clockwise Shift Relay Coil Short Circuit To Ground |
P1824 | 4-Wheel Drive Clutch Relay Open/Short To Ground |
P1825 | 4-Wheel Drive Clutch Relay Open Circuit |
P1826 | 4-Wheel Drive Clutch Relay Short To Battery |
P1827 | 4-Wheel Drive Low Clutch Relay Circuit To Ground |
P1828 | Transfer Case HI/LO Shift Relay Coil Circuit Open/Short to Gnd |
P1829 | Transfer Case Counter Clockwise Shift Relay Coil Open Circuit |
P1830 | Transfer Case HI/LO Shift Relay Coil Circuit Short To Battery |
P1831 | Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Ground |
P1832 | Transfer Case 4WD Solenoid Circuit Open/Short To Ground |
P1833 | Transfer Case Differential Lock-Up Solenoid Open Circuit |
P1834 | Transfer Case 4WD Solenoid Circuit Short To Battery |
P1835 | Transfer Case Differential Lock-Up Solenoid Short Circuit To Ground |
P1836 | Transfer Case Front Shaft Speed Sensor Circuit Failure |
P1837 | Transfer Case Rear Shaft Speed Sensor Circuit Failure |
P1838 | No Shift Motor Movement Detected |
P1839 | Transfer Case Shift Motor Open Circuit |
P1840 | Transfer Case Shift Motor Short Circuit To Battery |
P1841 | Transfer Case Shift Motor Short Circuit To Battery |
P1842 | Transfer Case Differential Lock-Up Feedback Switch Circuit Failure |
P1843 | Transfer Case Differential Lock-Up Feedback Switch Open Circuit |
P1844 | Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Battery |
P1845 | Transfer Case Differential Lock-Up Feedback Switch Short Circuit To Ground |
P1846 | Transfer Case Contact Plate ‘A’ Circuit Failure |
P1847 | Transfer Case Contact Plate ‘A’ Open Circuit |
P1848 | Transfer Case Contact Plate ‘A’ Short Circuit To Battery |
P1849 | Transfer Case Contact Plate ‘A’ Short Circuit To Ground |
P1850 | Transfer Case Contact Plate ‘B’ Circuit Failure |
P1851 | Transfer Case Contact Plate ‘B’ Open Circuit |
P1852 | Transfer Case Contact Plate ‘B’ Short Circuit To Battery |
P1853 | Transfer Case Contact Plate ‘B’ Short Circuit To Ground |
P1854 | Transfer Case Contact Plate ‘C’ Circuit Failure |
P1855 | Transfer Case Contact Plate ‘C’ Open Circuit |
P1856 | Transfer Case Contact Plate ‘C’ Short Circuit To Battery |
P1857 | Transfer Case Contact Plate ‘C’ Short Circuit To Ground |
P1858 | Transfer Case Contact Plate ‘D’ Circuit Failure |
P1859 | Transfer Case Contact Plate ‘D’ Open Circuit |
P1860 | Transfer Case Contact Plate ‘D’ Short Circuit To Battery |
P1861 | Transfer Case Contact Plate ‘D’ Short Circuit To Ground |
P1862 | Transfer Case Contact Plate Power Circuit Failure |
P1863 | Transfer Case Contact Plate Power Open Circuit |
P1864 | Transfer Case Contact Plate Power Short to Battery |
P1865 | Transfer Case Contact Plate Power Short to Ground |
P1866 | Transfer Case Cannot Be Shifted |
P1867 | Transfer Case Contact Plate General Circuit Failure |
P1868 | 4-Wheel Drive Indicator (Lamp) Circuit Failure |
P1869 | 4-Wheel Drive Indicator (Lamp) Circuit Short to Battery |
P1870 | Mechanical Transfer Case 4×4 Switch Circuit Failure |
P1871 | Mechanical Transfer Case 4×4 Switch Circuit Short To Battery |
P1872 | Mechanical 4-Wheel Drive Axle Lock Lamp Circuit Failure |
P1873 | Mechanical Transfer Case 4×4 Switch Circuit Short To Battery |
P1874 | Transfer Case Hall Effect Sensor Power Circuit Failure |
P1875 | Transfer Case Hall Effect Sensor Power Circuit Short To Battery |
P1876 | Transfer Case 2WD Solenoid Circuit Failure |
P1877 | Transfer Case 2WD Solenoid Circuit Short To Battery |
P1878 | Transfer Case Disengaged Solenoid Circuit Failure |
P1879 | Transfer Case Disengaged Solenoid Open Circuit |
P1880 | Transfer Case Disengaged Solenoid Short to Battery |
P1881 | Engine Coolant Level Switch Circuit |
P1882 | Engine Coolant Level Switch Circuit Short To Ground |
P1883 | Engine Coolant Level Switch Circuit |
P1884 | Engine Coolant Level Lamp Circuit Short To Ground |
P1885 | Transfer Case Disengaged Solenoid Short to Ground |
P1886 | 4×4 Initialization Failure |
P1887 | 4-Wheel Drive Control Solenoid Circuit Failure |
P1888 | Differential Oil temperature Sensor Circuit Failure |
P1889 | Oil Pressure Pump Performance |
P1890 | 4-Wheel Drive Mode Select Return Input Circuit Failure |
P1891 | Transfer Case Contact Plate Ground Return Open Circuit |
P1892 | Axle Disconnect Engagement Solenoid Circuit High |
P1893 | Axle Disconnect Engagement Solenoid Circuit Low |
P1894 | Axle Disconnect Disengagement Solenoid Circuit High |
P1895 | Axle Disconnect Disengagement Solenoid Circuit Low |
P1896 | Axle Disconnect Engagement Position Sensor Circuit High |
P1897 | Axle Disconnect Engagement Position Sensor Circuit Low |
P1898 | Axle Disconnect Indicator Circuit High |
P1899 | Axle Disconnect Indicator Circuit Low |
P1900 | Output Shaft Speed Sensor Circuit Intermittent |
P1901 | Turbine Shaft Speed Sensor Circuit Intermittent |
P1902 | Kickdown Solenoid Relay Control Circuit (Allison) |
P1903 | Kickdown Solenoid Circuit Low Voltage |
P1904 | Kickdown Solenoid Circuit High Voltage |
P1905 | Control Module Configured for End-of-Line Test Mode |
P1906 | Kickdown Pull Relay Open Or Short To Ground (A4LD) |
P1907 | Kickdown Hold Relay Open Or Short To Ground (A4LD) |
P1908 | Transmission Pressure Control Solenoid Open or Short (A4LD) |
P1909 | Transmission Fluid Temperature Sensor Circuit Open or Short (A4LD) |
P1910 | Reverse Lamp Control Circuit / Open |
P1911 | Reverse Lamp Control Circuit Low |
P1912 | Reverse Lamp Control Circuit High |
P1913 | Sensor Ground Reference A Circuit/Open |
P1914 | Sensor Ground Reference A Circuit Low |
P1915 | Sensor Ground Reference A Circuit High |
P1916 | Sensor Ground Reference B Circuit/Open |
P1917 | Sensor Ground Reference B Circuit Low |
P1918 | Sensor Ground Reference B Circuit High |
P1919 | Engine Coolant Temperature Signal |
P1920 | Engine Speed Signal |
P1921 | Transmission Range Signal |
P1922 | Fuel Additive Level Circuit |
P1923 | Fuel Additive Level Circuit Range/Performance |
P1924 | Fuel Additive Level Circuit Low |
P1925 | Fuel Additive Level Circuit High |
P1926 | Fuel Additive Level Circuit Intermittent/Erratic |
P1927 | Fuel Additive Level Circuit Too Low/Empty |
P1928 | Fuel Additive Pump Control Circuit / Open |
P1929 | Fuel Additive Pump Control Circuit Performance |
P1930 | Fuel Additive Pump Control Circuit Low |
P1931 | Fuel Additive Pump Control Circuit High |
P1932 | Fuel Additive Level Low |
P1933 | Fuel Level Signal |
P1934 | Vehicle Speed Signal |
P1935 | Brake Switch/Sensor Signal |
P1936 | Clutch Switch/Sensor Signal |
P1937 | Fuel Fired Heater Control Circuit / Open |
P1938 | Fuel Fired Heater Control Circuit Low |
P1939 | Fuel Fired Heater Control Circuit High |
