The Ford 2.8, 2.9 and 4.0 engines have the pilot bearing in the flywheel.
P/N F33126
Bore=0.5933″
Outer Diameter=0.8268″
Width=0.591″
The 2.3 and 3.0 engines have the pilot bearing in the crank.
P/N FC65354
Bore=0.5901″
Outer Diameter=0.827″
Width=0.591″
When replacing either, you need to remove the transmission from the vehicle.
Removal From 2.3 And 3.0 Engines:
To remove the pilot bearing from the Ford 2.3 and 3.0 engines:
(Ford 2.3 and 3.0 engines have the pilot bearing in the crank)
Having the right tool is key. Autozone has a blind hole puller set that you can buy or rent, Harbor Freight has a similar tool found HERE.
Or, check out these Pilot Bearing Pullers.
(blind hole puller – Use for 2.3l with the bearing in the crankshaft)
(Some parts stores may also carry a pilot bearing tool similar to this)
Removal From 2.8, 2.9 And 4.0 Engines:
To remove the pilot bearing from the Ford 2.8, 2.9 and 4.0 engines:
(Ford 2.8, 2.9 and 4.0 engines have the pilot bearing in the flywheel)
Harbor Freight has a pilot bearing removal tool better suited to removing pilot bearings from the flywheel.
Also check out these Pilot Bearing Removal Tools.
Another option:
Put the flywheel on two wood blocks and tap the bearing out with a socket and a light hammer (no bigger than a standard claw hammer) from the backside of the flywheel. Use the largest size socket that is smaller than the bearing ‘s outer diameter.
