ISSUE:
Some
vehicles may exhibit intermittent or no 4X4 engagement, even while the
4X4 lamp is illuminated, and/or a clunking noise may be heard
while shifting into 4X4 on the fly. This may be caused by:
Electrical connection at the vacuum solenoid
Vacuum connections
Front axle shaft retainers not seated
Vacuum sealing in wheel ends
Hub locks
Front driveline component damage
ACTION:
Diagnose
and repair the vehicle using the following Pulse Vacuum Hub Lock (PVH)
Diagnostics and Repair Procedure.
NOTE:
THE
PVH 4X4 SYSTEM IS LOCKED AND UNLOCKED USING TWO (2) DIFFERENT VACUUM
LEVELS TO ACTIVATE 4X4 SOLENOID. THE HIGH VACUUM ENGAGES THE HUB LOCK
SYSTEM, WHILE THE LOW, REGULATED VACUUM LEVEL DISENGAGES THE HUB LOCK
SYSTEM. THESE ACTIONS ARE NOT LINKED WITH THE 4X4 LAMPS. THEREFORE, WHEN
DIAGNOSING A 1998 RANGER 4X4 ISSUE, 4X4 INSTRUMENT PANEL LAMP
ILLUMINATION AND FRONT DRIVE SHAFT ROTATION DO NOT INDICATE THAT THE
SYSTEM IS OPERATING PROPERLY (AS IN PRIOR MODEL YEAR RANGER 4X4s). THE
FRONT HUB SYSTEM MUST BE SERVICED USING THE FOLLOWING PROCEDURE.
NOTE:
SIMPLY
REPLACING THE FRONT HUB LOCKS IS NOT A PROPER FIX FOR MOST PVH 4X4
SYSTEM ISSUES. MOST ROOT CAUSES OF NON-ENGAGEMENTS AND NOISE ARE FOUND
ELSEWHERE IN THIS NEW 4X4 SYSTEM. THE PROPER HUB LOCK REMOVAL TOOLS AND
PROCEDURES NEED TO BE USED TO AVOID DAMAGING THE PARTS. THESE PARTS ARE
TO BE REUSED IF ALL ATTACHING LEGS ARE INTACT. REPLACE HUB LOCKS ONLY IN
THE EVENT OF BREAKAGE OF THE PLASTIC BODY OR RETAINING LEGS (SEE THE
1998 RANGER WORKSHOP MANUAL, PAGE 204-01B-4).
PULSE
VACUUM HUB LOCK (PVH) DIAGNOSTICS AND REPAIR PROCEDURE:
1.
Place the vehicle in 4X2 mode and drive for 1.6 kilometers (1 mile) at
road speeds.
2.
Stop the vehicle, turn the wheels to full lock, and exit the vehicle. By
hand, manually attempt to rotate both the front drive axle shafts in the
hub ends. If the shafts are NOT locked, proceed to Step 3, If the shafts
are locked, proceed to Step 5.
3.
Shift into 4X4 HIGH and drive around slowly for 1.6 kilometers (1 mile).
Be sure 4X4 HIGH light illuminates.
4.
Perform tight steering turns on dry pavement and check for front wheel
hop/binding. If wheel hop/binding occurs, the front hubs did engage and
the system is fully functional. If not, follow Steps 5-11.
5.
Be sure the solenoid electrical connector and all solenoid vacuum
connections are secured properly to the 4X4 solenoid valve located below
RH head lamp on the frame.
6.
Be sure all vacuum connections are seated on top of both front frame
rails and into the front wheel ends.
7.
Be sure all vacuum connections are seated at the vacuum reservoir
canister and back to the engine manifold.
8.
Check both the RH and LH front axle shafts axial free play at the
outboard shaft joint prior to removing any parts. Perform this step by
grabbing the outer metal portion of the shaft joint and pulling back and
forth toward and away from the front differential. The free play is
excessive (greater than 1/8″), then the front axle shaft retainer
ring(s) is not properly seated or is missing.
NOTE:
THE
PVH 4X4 SYSTEM USES FRONT AXLE SHAFT RETAINER RINGS (A PLASTIC PART
WITH A METAL CIRCLIP) TO HOLD THE HALFSHAFTS FROM MOVING INWARD TOWARD
THE DIFFERENTIAL. IF A RING IS MISSING OR NOT SEATED, THE SHAFT FACE
WILL LOSE CONTACT WITH THE MAIN KNUCKLE VACUUMSEAL (DIRT
EXCLUDER/VACUUM SEAL) AND LOSS OF 4X4 FUNCTION MAY OCCUR. ALSO, THE
FRONT WHEEL END MAY INGEST MUD, WATER, AND OTHER DEBRIS, DUE TO
INSUFFICIENT PROTECTION FROM THE ENVIRONMENT. THIS ISSUE MAY CAUSE AN
INTERMITTENT 4X4 FAILURE TO ENGAGE OR DISENGAGE, BECAUSE THE SHAFT MAY
MOVE IN AND OUT AGAINST THE SEAL DURING CERTAIN ROAD EVENTS, ALLOWING
FOR INTERMITTENT VACUUM SEALING.
9.
If excessive axial free play is observed, remove the hub lock, remove
and discard the wheel hub O-ring, and discard the axle shaft retainer.
Pull the front axle shaft carefully out and away from the knuckle
assembly and clean and inspect the main knuckle vacuum seal and the axle
shaft metal surfaces. If any parts appear worn, corroded, or
contaminated, replace them as necessary per the Workshop Manual, Pages
204-01B-27 and 28. Replace the retainer ring, and wheel hub O-ring with
grease, and reuse the hub lock if not broken or cracked (refer to the
Workshop Manual, Pages 204-01B-4, 5, and 8 through 12).
10.
Check both the RH and LH wheel end vacuum sealing (as assembled) with a
hand vacuum pump per the Workshop Manual, Pages 308-07A-95 through 103.
If you find a leak, repair per the pinpoint vacuum leak test
recommendations. Note the following KEY aspects of the PVH wheel end:
a.
When removing a hub lock, always use the correct tools and reuse the
hub lock unless broken or cracked.
b.
ALWAYS replace and regrease (using High Temperature 4X4 Wheel Bearing
And Axle Grease (E8TZ-19590-A)) the 0.035 wheel hub O-ring seal when a
hub lock is removed and reassembled. This is a sealing point for the
hub vacuum system.
c.
The front axle shaft retainers MUST be fully seated in their grooves
and oriented with the metal circlip facing outward. Never reuse a
front axle shaft retainer.
d.
If the front axle halfshaft is pulled out of the wheel end, clean and
inspect the main vacuum seal and the halfshaft metal surfaces. If any
damage to either part is present, replace the part.
NOTE:
ALWAYS
REGREASE THE MAIN VACUUM SEAL WITH 3 GRAMS (0.1 OZ) OR MORE OF HIGH
TEMPERATURE 4X4 WHEEL BEARING AND AXLE GREASE (E8TZ-19590-A) PER THE
WORKSHOP MANUAL, PAGES 204-01B-27 AND 28.
e.
If the wheel hub and wheel bearing pack are ever unbolted from the
knuckle, replace and regrease the 0.044 O-ring in the wheel bearing
groove. This is a sealing point for the hub vacuum system.
NOTE:
NEVER ATTEMPT TO REMOVE OR REPAIR THE IN-BOARD WHEEL BEARING
RETAINER NUT. REFER TO THE WORKSHOP MANUAL, PAGES 204-01B-6 THROUGH
8.
f.
In addition to the wheel hub 0.035 O-ring, the wheel bearing 0.044
O-ring, and the main knuckle vacuum seal, other sealing points in the
wheel end assembly include:
the steel vacuum line into the knuckle
the wheel bearing seals
the Anti-lock Brake System (ABS) sensor on the wheel bearing (if
equipped)
Follow
the pinpoint vacuum leak tests for proper diagnostic procedures.
g.
Upon reassembling the front wheel end system, ALWAYS recheck the
vacuum sealing per the Workshop Manual, Page 308-07A-95.
11.
Upon completion of all repairs, road test the 4X4 system function by
carefully following Steps 1-4.
NOTE:
DURING
ALL DIAGNOSTICS (HOIST OR ROAD TESTS), NOTE THAT THE ENGAGEMENT VACUUM
PULSE LASTS FOR APPROXIMATELY 50 SECONDS. WHEN DIAGNOSING THE TRUE STATE
OF THE HUB LOCK SYSTEM, LET THIS AMOUNT OF TIME PASS BEFORE CHECKING FOR
ACTUAL SHAFT ENGAGEMENT. THE DISENGAGEMENT VACUUM TIMER LASTS FOR
APPROXIMATELY 15 SECONDS. AGAIN, LET THIS AMOUNT OF TIME PASS BEFORE
CHECKING FOR ACTUAL SHAFT DISENGAGEMENT.
NOTE:
THE
ENGAGEMENT VACUUM FROM THE SOLENOID IS THE HIGH VACUUM LEVEL AND
CORRESPONDS TO THE MAXIMUM CHARGED LEVEL, FROM THE ENGINE MANIFOLD, IN
THE VACUUM CANISTER. THE DISENGAGEMENT VACUUM FROM THE SOLENOID IS
REGULATED AND SHOULD MEASURE BETWEEN 6 AND 7″ HG OF VACUUM. THE
HUB LOCKS ENGAGE AT VALUES AROUND 7-1/2 TO 8-1/2″ HG.
4X4
SHIFT-ON-THE-FLY "CLUNKS":
When
a customer states the vehicle exhibits noise when shifting into 4X4 HIGH
on the fly, certain areas should be diagnosed. Remember that 4X4
instrument panel light illumination and front driveshaft/front axle
shaft rotation are not the sole indicators of 4X4 engagement. Target
areas to examine here are:
Transfer case clutch relay and wiring connections
Transfer case shift motor (related Generic Electronic Module (GEM)
codes)
Front driveshaft CV joint damage
Front axle bolts missing or loose
Front axle half shaft CV joint damage
NOTE:
NOISY
HUB LOCKS ARE FREQUENTLY A SYMPTOM OF OTHER 4X4 SYMPTOM ISSUES AND ARE
SELDOM THE CAUSE FOR SHIFT NOISE. IN THESE CASES, SIMPLY REPLACING THE
HUB LOCKS DOES NOT FIX THIS CONCERN.
4X4
LOW RANGE OPERATION
The
4X4 LOW function can only be engaged or disengaged by doing the
following:
1.
Zero vehicle speed.
2.
Foot on brake.
3.
Transmission in Neutral (clutch depressed).
4.
Move the 4WD control to the 4X4 LOW position.
Many
1998 Ranger 4X4 customers have reported 4X4 LOW issues when they have
not met all four requirements. Review these requirements with customers
to determine whether they have followed the proper engagement
procedures.
OTHER
APPLICABLE ARTICLES: NONE
WARRANTY
STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty
Coverage.
