ENGINE 2.3-liter EcoBoost® I-4 with Auto Start-Stop
Configuration |
Aluminum block and head |
Intake manifold |
Lightweight composite shell-welded |
Exhaust manifold |
High-flow three-port cylinder head with integrated exhaust manifold |
Valvetrain |
DOHC, four valves per cylinder, twin independent variable camshaft timing |
Valve diameter/lift |
Intake, 31 millimeters/8.31 millimeters; exhaust, 30 millimeters/7.42 millimeters |
Pistons |
Lightweight high-strength cast aluminum with low-friction skirt coating and steel ring carriers |
Connecting rods |
Forged steel with full floating pins |
Ignition |
Distributor-less with coil-on-plug |
Bore x stroke |
3.45 x 3.7 inches (87.5 x 94 millimeters) |
Displacement |
140 cubic inches (2,300 cubic centimeters) |
Compression ratio |
10.0:1 |
Engine control system |
Powertrain control module |
Recommended fuel |
87 octane |
Fuel capacity |
18 gallons |
Fuel delivery |
Direct injection |
Oil capacity |
6.2 quarts 5W-30 with filter (10,000-mile service interval) |
Power |
270 horsepower |
Torque |
310 lb.-ft. |
