If
your 4WD Ranger has a push button 4wd system (automatic, no manual
lever), than it's going to have a 4WD Shift Module mounted somewhere in
the cab. The photo above shows one mounted under the jumpseat on the
drivers side of an extended cab. For some reason, some people confuse
these with factory amplifiers for the stereo. Maybe it's because of the
aluminum fins that protrude from it.
Here's
a better view:
They
can generally be found located:
Here
is an article written by Chris1044 in our forums that will help you
diagnose 4WD problems involving this module:
Originally
Posted by Chris1044:
I
made the specifics of this apply to a 1994 Ranger with a BW1354 case,
but I’m sure that the basic concepts can be applied to other years.
I
can’t cover every practical situation that you’ll encounter with the
4x4 not working. This is written to be a guide for most
situations……its going to be long, and assumes that you can
1)
use a test light to check fuses and
2)
use a volt meter to check for power/grounds/resistance in different
circuits.
DO
NOT JAM A TEST LIGHT / THICK VOLT METER LEADS INTO ANY CONNECTOR.
You will ruin that connector or its ability to maintain a solid
connection with the other pin. Go to the store and pick up a pack of
small T-pins (look in the sewing department). They work great for this
sort of thing or back probing connectors.
If you can’t use a volt meter, you can still do some basics – just
don’t expect to find something like a corroded wire at some connection
that’s causing your 4x4 system failure.
First, are you sure that you’ve got no 4x4? This article is going to
cover the electrical shifting system, and will not touch on your 4x4
hubs and how to fix them.
Before you get in over your head, and realize you’ve got bad hubs and
not a bad 4x4 shift system, do yourself a favor and put the truck up on
jack stands (all 4 tires off the ground). Shift the truck into 4x4, and
with the motor running put the trans into drive. Let out on the brake,
and let the truck idle in drive…..check to see if both drive shafts
are turning. If they are, yet you’ve got no front wheels spinning,
you’ve got a hub issue. If one is spinning it’s because you’ve got
an open differential.
Assuming
that your front drive shaft is not spinning, you’ve got a 4x4
engagement problem…….now you’ve got to do some diagnostics.
1.
Check to make sure all fuses for the system are good. There are two
fuses that supply power to your 4x4 shift system – one located under
the hood, the other under the dash. The fuse under the hood is a 20 amp
maxi fuse. The fuse under the dash is a 15 amp ATO fuse. On the 1994
Rangers its located in fuse position 7.
a.
If they’re good, go to step 2.
b.
If they’re bad, you’ve got a short somewhere in the system. Try to
replace the fuse, and see what happens. If it blows, you’ve got
something shorted to ground in the circuit. If you know how to use a
volt meter, you should know how to find a short in the circuit, and will
need a wiring diagram to do so.
2.
If all the fuses are good, the next step is to run the 4x4 module self
diagnostic. The 4x4 module is located behind the driver’s side rear
jump seat on super-cab models, but as far as the other locations I
don’t really know. This module will have three connectors going to it
– one will be a pig tail, the other two will be located on the right
side of it (side towards the front of the truck). These two connectors
must be removed to diagnose the module.
With
the key in the off position, remove these two connectors from the
module.
Next,
turn the key on with the engine off. On top of the module is a white
rectangular button located next to a red LED….push the button and
watch the LED.
a.
If it flashes, this indicates the module is working properly. Go to step
3.
b.
If it lights up and stays on, it indicates that the module is likely
bad.
c.
If nothing happens, it means the module is either bad, or has no
ground/power.
In
either of these instances (b or c) power and ground should be verified
before scrapping a 4x4 module.
The
4x4 module receives its power/ground through the 8 pin pigtail
connector.
Pin
Position 1 = Open, no wire
Pin Position 2 = Solid Black = Ground
Pin Position 3 = Orange/Black = Logic Ground
Pin Position 4 = Orange = Transfer Case Motor Control (Clockwise)
2H-4H-4L
Pin Position 5 (across from position 4) = Yellow = Transfer Case Motor
Control (Counterclockwise) 4L-4H-2H
Pin Position 6 = Brown = Electromagnetic Clutch (Feed)
Pin Position 7 = White/Purple = Ignition Run and Crank (Start) Feed
(Fused)
Pin Position 8 = Dark Green/Light Green = 20A Maxi-Fuse in Power Network
Box (under hood fuse)
3.
With the two connectors still unplugged from the module, the next step
is to verify the 4x4 dash switch input. Take the 5-wire connector, the
one with the gray connector color, and check the following:
a.
Connect an ohmmeter between terminals 1 (White/Light blue wire) and 2
(Dark Blue wire). Then depress the 4x4 (2H-4H) switch. The ohmmeter
should indicate a low resistance value (less than 50 ohms) while the
switch is being depressed. If this occurs, the switch feed to and from
the module is good.
b.
Connect an ohmmeter between terminals 1 and 3 (orange/light blue wire).
Then depress the LOW RANGE switch. The ohmmeter should indicate a low
resistance value (less than 50 ohms) while the switch is being
depressed. Again, if this occurs, the 4 low switch is good.
c.
Connect a test lead between terminal 4 (brown/white wire) and ground.
Turn the ignition switch to RUN and observe the indicator lights. The
LOW RANGE light in the instrument panel and LOW RANGE indicator light on
the switch should illuminate. This indicates the 4x4 lo switch/dash
lights are good.
d.
Connect a test lead between terminal number 5 (grey wire) and ground.
4x4 light in the instrument panel and 4x4 light on the switch should
illuminate. This indicates the 4x4 hi lights/dash lights are good.
e.
If any of these tests fail, you will have to check the wires from the
module to the back of the switch for continuity. This is done easily by
removing the dash switch and connecting an ohmmeter between the same
color wires, with one lead at the module and the other at the switch. A
resistance value of 10 ohms or less is good, any more indicates
excessive circuit resistance. If all 5 wires have low resistance between
the switch and module, the switch is bad and must be replaced.
4.
The next step will check the circuitry to the shift motor. Your shift
motor must be hooked up for this to work. Grab the 8 wire connector that
is unplugged from the 4x4 module. It will be tan in color. Check the
following:
a.
Connect an ohmmeter between terminal 1 (red/light blue for manual trans
vehicles, red/white for auto trans vehicles) and ground. On a vehicle
equipped with a manual transmission, depress the clutch pedal and
observe the ohmmeter. The ohmmeter should indicate a low resistance
(less than 50 ohms) while the clutch pedal is being depressed. If the
vehicle is equipped with an automatic transmission, shift the
transmission into NEUTRAL and observe the ohmmeter. The ohmmeter should
indicate a low resistance (less than 50 ohms) while the transmission
selector lever is in the NEUTRAL position. This ensures that the
Park/Neutral switch or Clutch pedal switch is good (needed for 4 lo
shifts).
b.
Connect an ohmmeter between terminals 2 (light green) and 3 (light
blue). The ohmmeter should indicate a low resistance reading (235-470
ohms). This will check the continuity of the speed sensor that is
located in the transfer case. The speed sensor picks up the rotating
speed of the transfer case rear output shaft from two notches that are
cut in opposite sides of the outer ring of the clutch housing.
c.
Connect an ohmmeter between terminal 8 (yellow/white) and terminals 4
(violet), 5 (white), 6 (brown/white) and 7 (orange/white), respectively.
Refer to the following chart for the appropriate ohmmeter readings in
each transfer case position.
OHMMETER
READINGS FOR SHIFT MOTOR POSITION SENSOR |
Pin
8 Wire Color Y/W To: |
TRANSFER
CASE MOTOR POSITION
2 High |
Edge 1 |
2H-4H |
Edge 2 |
4 High |
Edge 3 |
4H-4L |
Edge 4 |
4 Low |
Pin 4 |
Wire
Color P/Y |
Short |
Short |
Short |
Short |
Open |
Open |
Open |
Short |
Short |
Pin 5 |
Wire
Color W |
Open |
Open |
Open |
Open |
Open |
Short |
Short |
Short |
Short |
Pin 6 |
Wire
Color BR/W |
Short |
Short |
Open |
Short |
Short |
Short |
Short |
Short |
Open |
Pin 7 |
Wire
Color O/W |
Open |
Short |
Short |
Short |
Short |
Short |
Open |
Open |
Open |
NOTE: Edge positions and Mid-Shift positions are valid motor codes that
the module will respond to; however, any motor found in one of these
positions should be replaced/torn apart and cleaned/inspected to prevent
the overshooting of shift points.
SHORT
is a "low" resistance reading on the ohmmeter (zero ohms).
OPEN
is a "high" resistance reading on the ohmmeter (infinity).
5.
Up to now, the following should have been verified:
a.
You verified that:
1)
All fuses are good
2)
The 4x4 module tested ok, and has power/ground (make sure the pigtail
connector isn’t corroded – is common among rust belt trucks)
3)
The 4x4 switch tested ok
4)
The shift motor circuitry tested ok
b.
With the key off, reconnect the two connectors. Make sure the key is
off.
c.
The next step is to verify that the module is supplying voltage to the
shift motor. To do this, you’ll either need a second person or long
volt meter leads. Crawl under the truck. Find the connector that
connects to the shift motor. Leave it connected. Back probe the solid
orange wire through the connector located on the shift motor side. You
are essentially checking for voltage at this pin to ensure that it is
getting voltage, and that the connector is good. Next, turn the key to
run and push the 4x4 switch. You should see 12 volts on the volt meter.
If not, ensure that the volt meter has a good ground and try again.
1)
If you’ve got a 12 volt signal, go to step d.
2)
If you’ve got nothing still, go to step 6.
d.
If you have a 12 volt signal, the next thing to do is verify that the
motor has a good ground as well. Back probe the solid orange wire on the
connector as well. Again, check for a 12 volt signal using the yellow
wire. This ensures that the module is grounding the other side of the
motor, allowing for current to flow through the motor. If the shift
motor still doesn’t work (you can’t hear/feel it spin) then it’s
probably bad. You can remove it from the transfer case and make sure you
can spin the transfer case manually using a pair of pliers. If you can,
then it’s a good bet the motor is bad. If you can’t, you’ve got
other issues and the t-case probably needs some internal repair…..the
shift motor may be alright after all, and the major (internal) issue
must be repaired first.
1)
If you didn’t receive a 12 volt signal, then the module isn’t
grounding the motor for some reason, and could be bad. Continuity from
the orange/yellow wires at the shift motor connector to the 8 wire
pig-tail connector from the module must be checked.
6.
If in step five you had no power signal, even when you grounded the volt
meter to something other than the module itself, you need to 1) make
sure the wires have continuity between the 4x4 module and shift motor,
and 2) make sure that the module is sending a 12v supply to the 4x4
switch. To verify issue 1, see part d-I in step 5. To verify issue 2:
a.
With all connectors plugged into the module, back probe the dark blue
wire (terminal 2) on the 5 pin gray connector – the one on the lower
right side of the module. Make sure you DO NOT ground your back probe
out while doing this. With this pin back probed, turn the key on. Check
for a 12 volt signal there while pushing the 4x4 switch. If you have 12
volts there, your module is sending a 12 volt supply to the 4x4 switch.
1)
If no voltage is present there, turn the key off and back probe terminal
1 (white/light blue) on the same connector. Again, it is more crucial
here that this is not grounded. If you ground this pin out with the key
on, even for 1/16th of a second, your module could be ruined. Now that
you’ve ensured your back probe is not and cannot be grounded out,
check for voltage by simply turning the key on.
1.
If you have voltage here, but did not in part 6a you must verify
continuity between the module and 4x4 switch – refer to step 3.
2.
If you have no voltage here, make sure the module has power and ground.
If it does, it’s probably bad.
That
should be a fairly decent start on system diagnosis, and I’ll bet
completing those steps will tell you what is wrong with your system.
Again, there could be some weird issue, and you’ll have to make a post
for more info.
