The 2019 Ford Ranger returned to the North American market with Spicer (Dana) AdvanTek axles. Gone is the Ford 8.8-Inch rear axle that we knew for so long.
Spicer® AdvanTEK® high-efficiency axles deliver more miles per gallon, enhanced vehicle performance, and maximum durability for the complete spectrum of light vehicles. Even with its compact design, these axles provide greater power density than similar offerings while reducing driveline weight with lighter, higher strength materials and advanced gearing. Spicer AdvanTEK axles make it possible for vehicles to handle today’s high-torque engines.
Standard Features:
Pinion features to enhance reliability:
Larger diameter pinion stem
Narrow pinion bearing spread
Two-stage pinion preload setting
Pinion mate spherical torus shape
Pinion features that reduce vibration:
Pinion built to position rather than pattern
Major diameter pinion spline fit
Reduced pinion nut backface runout
Gearing features to improve durability:
Gearing features that maximize efficiency:
Thrust washer features for a quieter ride:
Dynamic backlash measurement
Belleville side gear thrust washers
Thrust washer lubrication holes
Ford Ranger Front Axle:
The 2019 Ford Ranger uses 190 mm axle in the independent front suspension:
The 190 mm axle measures out to 7.48 inches.
Ford Ranger Rear Axle:
The 2019 Ford Ranger uses the 220 mm Salisbury beam axle in the rear:
The 220 mm measures out to 8.66 inches.
This axle is available with or without an electric locker.
