TRS Tech Library Side Menu
will not rotate when attempting to start
Battery
terminal connections loose or corroded. Check the cable terminals at
the battery. Tighten the cable or remove corrosion as necessary.
Battery
discharged or faulty. If the cable connections are clean and tight
on the battery posts, turn the key to the On position anti switch on
the headlights and/or windshield wipers. If they fail to function,
the battery is discharged.
transmission not completely engaged in Park or Neutral or clutch
pedal not completely depressed.
Broken,
loose or disconnected wiring in the starting circuit. Inspect all
wiring and connectors at the battery, starter solenoid and ignition
switch.
Starter
motor pinion jammed in flywheel ring gear. If manual transmission,
place transmission in gear and rock the vehicle to manually turn the
engine. Remove starter and inspect pinion and flywheel at earliest
convenience
Starter
solenoid faulty
Starter
relay faulty
Starter
motor faulty
Ignition
switch faulty
rotates, but will not start
Fuel
tank empty.
Fault
in the fuel injection system
Battery
discharged (engine rotates slowly). Check the operation of
electrical components
Battery
Fuel
pump faulty
Excessive
moisture on, or damage to, ignition components
Worn,
faulty or incorrectly gapped spark plugs
Broken,
Broken,
loose or disconnected wires at the ignition coil pack or faulty coil
'pack
Broken,
loose or damaged timing belt
Starter
motor operates without rotating engine
Starter
pinion sticking. Remove the starter and inspect.
Starter
pinion or flywheel teeth worn or broken. Remove the flywheel/driveplate
access cover and inspect.
hard to start when cold
Battery
discharged or low
Fault
in the fuel or electrical systems
hard to start when hot
Air
filter clogged
Fault
Fuel
not reaching the injectors
Starter
noisy or rough in engagement
Pinion
or flywheel gear teeth worn or broken. Remove the cover at the rear
of the engine (if equipped) and inspect.
Starter
motor mounting bolts loose or missing.
starts, but stops immediately
Loose
or faulty electrical connections at distributor, coil or alternator.
Fault
Vacuum
leak at the gasket surfaces of the intake manifold or throttle body.
Make sure all mounting bolts/nuts are tightened securely and all
vacuum hoses connected to the manifold are positioned properly and
in good condition.
lopes at idle, or idles erratically
Vacuum
leakage. Check the mounting bolts/nuts at the throttle body and
intake manifold for tightness. Make sure all vacuum hoses are
connected and in good condition. Use a stethoscope or a length of
fuel hose held against your ear to listen for vacuum leaks while the
engine is running. A hissing sound will be heard. A soapy water
solution will also detect leaks.
Fault
Plugged
PCV valve
Air
filter clogged
Fuel
pump not delivering sufficient fuel to the fuel injectors
Leaking
head gasket. Perform a compression check
Camshaft
lobes worn
misses at idle speed
Spark
plugs worn, fouled or not gapped properly
Fault
Faulty
spark plug wires
Vacuum
leaks at intake or hose connections.
Uneven
or low cylinder compression. Check compression
