02 4x4 torsion bar “insulator” pads
Ohhnulix
6
Dade city
Ford ranger
I recently went to put lifted Torsion keys on my 02 4x4, but due to a few issues I couldn’t get the keys in so I decided to wait. When I took the old keys out, the rubber pads under the stock keys fell apart, is it going to hurt anything riding without them? I cranked the keys back tk where they where and it did have to go a little further then before but I would figure it was because of the pad missing. So once again; do I really need the rubber pads? And if it’s really needed does anyone have part numbers? Because I can’t find them anywhere
superj
2,714
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i didn't even know there are pads in there
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
I would think that IF the rubber pads crumbled when you touched them, they were not doing much to begin with. You're probably OK to run without them.
don4331
1,354
Calgary, AB
5.3
I thought those pads were indestructible, so not surprised there aren't part numbers for them (not a wear item, so shouldn't ever need replacing.
If you weren't on opposite side of country, I'd send you one of spare sets I have.​
They are to provide cushion, so you don't have direct metal to metal contact. It will be noisier, and you may notice slightly poorer ride. But it isn't dangerous to drive without them.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,796
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You might have to go to a junk yard to get replacements. I don't remember there being a part number listed for them. You could try looking on the Tasca site and see if they have anything. They seem to be the best to navigate but they are still limited by the OEM illustrated parts break down drawings that Ford gives them.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
This is one of the things on my list of stuff I need to find for my 09. Mine have not fallen apart yet but the metal backing has separated. I am going to do some research as well.
pjtoledo
3,006
Toledo Ohio
Fords
3.0 2.3
5B335 isolator
listed as 2004-2011 Ranger, also 2001+ Sport tracs/Sports.
Ford listings don't go back to 2002
considering the pressure that the keys put against them, they are not "just rubber" but rather some very tough polymer stuff.
Steve83
ASE Certified Tech
Memphis, TN, USA, Earth, Milky Way
XLT FX4 OffRoad
265/70R16
Walk softly, and carry a BIG SIX!!!
I've been digging, but couldn't find this until I found this thread. Lakeland says it doesn't fit my '03, but Tasca says it does, and shows a photo that includes the cast-Iron plate that the key pushes against.
https://www.tascaparts.com/oem-parts/ford-adjust-cover-insulator-6l5z5b335aa
I haven't found the plastic/rubber part alone, but I might make one from a sheet of poly.
