04 ranger t-case strength
Diesel_brad
Gilbert PA
Hey guys, I am in the process of putting together parts for my 4bt swap
So far I have the engine and zf5. Next up is the t-case
But what t-case in in my 04 currently(electric shift) and would it be strong enough behind a 250hp 450tq engine? Will it even bolt up to my ZF5(4wd)
If not is there any aluminum t-case that will fit between my frame rails? I am trying to stay away from the cast 205
BW1354 case, might take 250 horse, doubt it will take 450 ft.lb, and def won't bolt right up to a ZF5.
Diesel_brad
Gilbert PA
Damit, ok.
Any suggestions on a aluminum t-case that will fit between the frame rails and bolt to a zf?
rustywrench
Hey Brad, fancy meeting you here! Why are you shying away from the NP 205??? Weight issues? I know that an aluminum 1356 out of a Full size truck is about 50 lbs. lighter than a NP205. That aint much considering the big picture.......
Diesel_brad
Gilbert PA
I dont like the idea of a cast Iron t-case hanging off an already "weak" aluminum tail housing
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
you are wise to avoid the 205 if 450 pounds of torque and abuse is in the scenario.
one thing about the zf5 that most people dont know, is they suck with big power and crack and bust with a retarded heavy doubler combination hanging off of them. many a big block guy has shit canned these (bullet proof transmissions) to go back to a c6 after fanagling the mounting situation and repeatedly being let down. dragging your junk off the trail 3 times in a season after you "upgraded" to a big block 5 speed sux.
for typical smallblock power level they are pretty good. but that is sub 350 pounds of torque territory.
making a custom foot to mount these should be a given if you drive like you stole it. i can fit that description from time to time....its why with a big power sbf i would run a built aod or 4r70....or with a bbf a e4od. both of those will whoop a c6's assss in any event. and are stronger case wise then the zf5.
conversely, your talking 250 hp 4bt....well....that will be 500 plus torque if you spend the jack to actually get an honest 250 hp...
so.
your fawked. 205 it is.
you want to make a bad ass foot to mount the np 205 to as it is the only logical cost effective choice. it fits great and will take an ass whoopin the best out of what is out there.
if i was to do this i would do a divorced setup and use a 2wd trans.. if i was going to drive it on the road and needed od.
otherwise i would save for a ried case t400 and run the th400 till i got cash for the ried case...
Diesel_brad
Gilbert PA
It is getting a ZF5-s42 or s47(I have both). I dont drive autos
at 250hp it should be 450tq
The s42 is rated at 420ft/lb the s47 is rated at 470ft/lbs
I have never had a problem with any ZF strength wise other than the trans mount foot and I have a supercharged 460 in front of one and a 600ft/lb power stoke in front of another. Neither is driven lightly
Does anyone know if a 208 from an 80s ford would fit in the frame rails?
Diesel_brad
Gilbert PA
How about a 4406 from a newer F150? Can that take the power and will that bolt up to a ZF5?
Blown
I ran a ZF5spd with 205/Atlas II doubler and a blown 393. 480ftlbs of torque! That was in a fullsize bronco rock crawler. No issue with that set-up, but it is harder to crawl coordinating shifting, clutch action, and skinny pedal vs an auto tranny.
I made transfer case mounts coming off both sides of the 205 case to the frame. There are many examples of how to do it and the 205 has the bolts and surfaces on the case to do such. I wanted lower gearing than the 1.96 to 1 low in the 205 and added the Atlas.
I do not see where the 4406 would be any stronger than a 1356 or 208. All offer a lower low range around 2.6:1.
This is one of my old links for ford cases: http://www.blueovaltrucks.com/tech/transfer_cases.htm
Diesel_brad
Gilbert PA
Thanks for the feed back and the link. I like the 4406 idea to keep it electric shift and MAYBE it os small enough to fit between the frame rails
