06 Ranger leans on PASSENGER side???
turbozeke418
Although I'm new to TRS, I'm not new to Rangers. I recently purchased a 2006 XLT 4x4 extra cab 4.0 and specifically wanted a manual.
The entire passenger side of the truck front and rear sits 3/4 to an inch lower than the driver side. i've found tons of postings about the driver side but not the passenger site. All of the bushings look good, the shocks are new. I measured from the center of the wheel wells and both front and rear on passenger side are lower. I even swapped the tires front and rear and side to side and it didn't make a difference. I'm stumped!!!
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Someone big and heavy could have driven the truck and they cranked the torsion bar up on the driver side to compensate for the sag of the truck from the weight. I know this has been done before.
ericbphoto
Overlander in development
16,598
Wellford, SC
3.0L
6"
eat more until your weight is equal to the weight of your passenger. :icon_rofl: :icon_twisted:
Craig0320
225
Mississppi
McDonald's grease will get you there fast
kimcrwbr1
46
maplevalley WA
2.8l
For the next year only take right turns it will eventually wear out the left springs equally?
Craig0320
225
Mississppi
Wow, we are absolutely no help.
ericbphoto
16,598
Wellford, SC
3.0L
6"
That's it!!!! The first owner was a NASCAR driver! He only made high speed left turns. Right side suspension is "wore slap out".
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Well, to add something useful here, :) I would suggest check for any broken leaves within the passengerside rear leaf spring.
Finding none, I would agree with comments above, you probably just need to crank up the passengerside torsion bar key a couple turns (or alternately lower the driverside one).
Check that the front axle half-shafts slope downward toward the wheels at no more than approx 10° or so on both sides (more angle than this can potentially shorten the life of the CV joints and other components).
Welcome to TRS.
Gotta calerbrate that brake fluid.
ericbphoto
16,598
Wellford, SC
3.0L
6"
Just as soon as I finish adjusting the cooter flappers.
This message composed solely of recycled electrons. Go green!
alwaysFlOoReD
5,100
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Hey, @turbozeke418
Don't take the ribbing to hard, there are some people on this site that will help....
Take a look at the body mount bushings.
best I could do....
ericbphoto
16,598
Wellford, SC
3.0L
6"
Have you measured from the frame to the ground to see how much difference is there? If frame is level and body is not, then it's body mounts. Make sure tire pressures are equal, too. My truck leans a bit to the driver side without anyone in it. But I decided not to pursue that issue.
