Conner Smith
- Oct 3, 2022
- 1
- Arizona
- Ford Ranger
Hello fellow ranger friends,
I’ve searched every where and cannot seem to find anyone that has experienced the same problem.
I have an 07 Ranger 2.3 liter and 5 speed with 307000 miles. It’s been running excellent since I’ve had it. In the last year, I’ve replaced the fuel pump and filter, ac compressor, clutch slave cylinder and pressure plate, fuel cutoff tilt switch, battery, and I’m sure a few other things I’m forgetting.
Here’s my problem. Intermittently, when I try to start the truck, it starts, hesitates as though it’s missing on a cylinder, and then dies. When it does this, the blower motor inside doesn’t work. Sometimes this problem occurs happens while it’s already running and I’m driving. Here’s what it feels like when it happens while I’m driving:
The truck loses power, and the blower cuts out. When I come to a stop, it dies. When I try to start it up again, it starts, does the thing where it “misses” and then dies. I can get it to start again by fiddling with the climate controls, alternating between fan on, fan off, ac, and varied fan speeds.
This problem seems to correspond to the blower cutting out, which is why I think it must be electrical. What are your thoughts?
Ive already cleaned the MAF sensor, and the IAC valve. I tested the IAC by disconnecting the connector, and it died, which I understand means that it is doing its job.
Every time I do something that I think will solve the problem, it seems to run fine for a little while and then it comes back again. Any help would be much appreciated!
