1350 1354 difference
90rangersuper
Pittsville,WI
how can i tell the difference between a 1350 and 1354 t-case, going to the yard this weekend, looking for a manual 1354 t-case, need to know how to tell them apart
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The 1350 will have a slip yoke style front output, the 1354 will have fixed yoke on both ends.
1350:
1354:
Evan
5
Stevens Point, WI
4.0 OHV
There is also a tag that should identify the transfer case model.
90rangersuper
Pittsville,WI
thanks much, hopefully the yard will have a manual 1354, that would be sweet:icon_hornsup:
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
There is one 1350 that also has a fixed yoke, but are somewhat rare (they were used on some STX "Highrider" trucks). The yoke basically looks like an afterthought on the nose of the slip-yoke-style case (and uses a smaller u-joint), whereas the 1354 has the yoke in a more "normal" configuration (pictured above).
reginald fairfield
New Mexico
3.0 liter FF
Some advice, take hold each output shaft and try to turn them in different directions, make sure the chain has no slack in it. Also take out the fill plug and check the chain.
CheapThrillB2
May 2010 OTOTM
8
Western Michigan
1975-1995 Ford
FORD
soon 5.8L
adn good luck, where i live they are about impossible to find.
90rangersuper
Pittsville,WI
no luck on the 1354 find, i did find a 1350, dont want that though. Ill keep looking, the yard i went to is the only one around here that will let you in the yard to look.
CopyKat
8
Manitoba, Coldest place in Canada
There are no BIG strength differences between the 1350 and 1354. You could use a 1350 manual and use a front driveshaft from a TK5or FM145 trans. Just make sure it's got the big joint. Same joint size as the D35. Shouldn't have to trim the DS at all.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
The major difference is that all 1354s have fixed front outputs and most 1350s have slip front outputs. There are some 1350s that have a fixed front output however that came in the STX rangers.
I have one and am about to get another if your interested......
leumas12
San Jose, CA
2.9L V6
Dont mean to hijack the thread but would i be correct in assuming that the 1350 and 1354 are different patterns of bolts that run along the outside of the cases (where the case is split in half)?
leumas12
San Jose, CA
2.9L V6
great, thanks :icon_thumby:
Sam
Evan
5
Stevens Point, WI
4.0 OHV
Not only are they the same bolt battern, but the front plate is identical. You can run a 1350 front plate on a 1354.
