jkent
- Mar 12, 2013
- 0
- Wisconsin
- Ford
- Engine Size
- 4.0 OHV
I just completed the 1354m swap and was wondering if anyone knows how to make the indicator lights work in the dash with the 1354m. There is a two wire plug in the 1354m case which i assume is for the indictor lights.
With some searching i found the above but that was for a 95 Ranger with knob 4x4 engagment vs. my push button 4x4 engagment. Is it the same? Is it correct that all I need is the two wire harness that goes from the tcase to the firewall? plug and play? does anyine have pictures of where the harness attches on the firewall? Thank you!As for makign the lights work?
Look on your firewall near the big round firewall connector, in that
general area there will be a small two conductor connector, there will be a plain light blue wire and a light blue wire with a black stripe.
IF you can find ANY gen2 4x4 truck with a manual T-case the wire that runs to the MANUAL T-case is a seperate two wire "harness" that runs to the t-case position indicator switch and connects to that plug near the firewall connector.
That's all you generally need... just plug it in at both ends and tie it to
other wiring to keep it from getting tangled in the driveshaft...
AD
