Wanted 15" Aluminum Wheels for 2010 Ranger
Danno1985
103
MKE, WI
stock
stock
stock
Looking for a set of either these:
or these:
My truck is minty so they'd have to be in good shape; I'm not interested if they're all chewed up or corroded. Looking for something I can pick up within an hour or two of Milwaukee, WI. Thanks!
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
BEWARE, there are 2 versions of that D twin spoke wheel.
early versions, like 2000+ will only fit over 11.25" rotors.
there are 2 later versions, 2010/2011 sport, that have an enlarged barrel to fit over 12" rotors.
they look almost identical, but if you have 12" front rotors only the later version will fit.
I see you have a 2wd Ranger, should have the smaller 11.25 rotors, right???
Danno1985
103
MKE, WI
stock
stock
stock
Believe so, but thanks for the heads-up, I’ll double check.
