15" wheel on a 2010 2wheel drive?
alain
Laval, Quebec, Canada
Mazda
Will older 15" aluminum wheels fit on a 2011 Ranger 2wd? 4.0 v6. Some one told me they won'r fit because of the rear disc?
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
that may very well be true. they had to change the wheel design when they went to discs from drum brakes in the rear. if your stock wheels are 16 inch, then it's even more doubtful that the 15 inch wheels you want will fit really. all you can do is try one on your rear axle and see if it clears or not. good luck to you.
4x4junkie
585
So. Calif (SFV)
2.9L V6
35x12.50R15
Should be no problem. 15s come stock on '10 2WDs.
