ianthegreat
- Jun 3, 2009
- 2
- Houston, TX
- Ford
- Engine Size
- 2.0
Hey guys,
I've been lurking here for awhile -- finally signed up!
Pardon my lack of knowledge, I really don't know much about these carb engines. I'm learning.
Given it's age, the only thing I had to replace was the throttle cable after my purchase. The previous owner had replaced the distributor cap, the wiring, and the fuel pump.
Everything seemed to be running fine until last week when I started it and out of no where it starting idling low and eventually stalled. When applying the throttle it appears the issue isn't there. So unless I am giving the engine gas, it will stall at idle.
I was able to get home and popped the hood. I manually throttled the engine from the carb and it looked like even under load it was shaking a bit more than before. It may just be a placebo effect.
Anyways, I did a little bit of research and it seemed there could be several different issues. Vacuum leak (all original hoses/tubes), air/fuel mix from carb, catalytic conv clogged, etc...
Based on my description of the problem, could anyone lend some assistance?
Thank you!
Thank you!
