keaten
- Jul 22, 2023
- 4
- houston texas baytown
- ford ranger
- Engine Type
- 2.9 V6
- Engine Size
- 177 ci
- 2WD / 4WD
- 2WD
NEEDING HELP WITH CODES!!!
KOER
42 "SYS RICH"
13 "R" IDLE SPEED CONTROL MOTOR NOT CONTROLLING IDLE PROPERLY
25 "KNOCK SENSOR NOT TESTED"
KOEO
22 "MAP SENSOR OUT OF SELF TEST RANGE"
CONTINUOUS MEMORY CODES
122 "THROTTLE POSITION BELOW MINIMUM VOLTAGE"
any help is appreciated, i have replaced o2 sensor, map sensor, iac valve, iat sensor, tfi module, coil, spark plugs, wires. still getting bad gas milage, need pointers and forums to look at
KOER
42 "SYS RICH"
KOEO
