CHRISGOD10
- Mar 25, 2024
- 0
- Maine
- Ford Bronco 2
well i got a 1987 Bronco II with the Fm145 transmission and a 2.9L motor. The shifter on the transmission is broke and the only replacement I can find is a core shifter which is fine but the transmission needs and overhaul and from what I’ve seen it’s a pain in the butt plus parts don’t seem to be the easiest to find. I’ve seen a lot of people say to put a M5OD R1 my question is what are the options for vehicles/ years to pull one from? I know the Rangers used them up till then ended in 2011, cause I use one out of the the later years? And what all would I need to do to install it
also the motor needs a possible rebuild so im wondering if I could pull a 4.0l out of a new ranger and put that in if im already gonna have to pull the motor. What I’ve seen is you need just the engine itself, wiring harness and computer.
