- May 15, 2021
- 3
- Age
- 27
- Madison, Ms
- Ford Bronco II
- Engine Type
- 2.9 V6
- Engine Size
- 2.9 V6
- 2WD / 4WD
- 2WD
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 235/75 - R15 A/T
Fixed, it was pickup coil inside Distributor. I replaced the whole distributor & reset timing, drives beautifully now.
I'll leave this article up for anyone who might have an similar problem
My truck has never ever not started on 1st revolution of crank. I was in a drive-thru line and I stalled it not paying attention to it being in 2nd. After that incident, I've went through the usual suspect parts replacing them. I've tried new Ignition control module, new Ignition coil, new ECC Relay, and painful process of tracing down every wire related to Ignition and all fusible links were good along with diodes. Only thing I haven't done is replace the ecu, does anyone know what might possibly be my no spark problem..
