96Indyram
- May 3, 2013
- 15
- Clearwater Ks
- Ford
- Engine Size
- 2.8, 2.9
Bii is a 88 v6 5 speed manual 4x4. Bought it but had a slipping clutch so I never drove it far or fast. Basically on the trailer and into garage.
Just put in a new clutch kit. Went for a drive and all was fine. Put gas in it and aired up the tires. Heading for home doing 30 mph the shifter started shaking violently so I stop and check all mounts. Started driving again and all is good for a few miles then the shake comes back...then goes away.
All mounts are good, all bolts are tight.
Could it be the rear shafts cv joint (has plastic covers over them) going out...binding up..then working good again?
Or could it be something else?
I would hate to buy a new rear shaft if it's not the problem.
Thanks in advance for all help..
