- Jan 23, 2010
- 80
- ND
- Ford Bronco II
- Engine Type
- V8
- Engine Size
- 5.0
- 2WD / 4WD
- 4WD
- Total Lift
- 2" body. 1.5" coil spring spacers/rear block
I recently picked up a 1988 F250 4x4 7.3 idi diesel with 5 speed transmission, regular cab, long box. It needs some work to say the least. Dirty and broken all over but the engine runs pretty good and it's an XLT Lariat so its has all the options of the day, you know, power windows, locks and air conditioning! Of course, the air conditioning is one of things I need to fix as well.
I'm trying to get into running condition and it'll become my tow rig and dd if it does well.
I have another thread about the transmission issue (won't go into 4th gear).
Other issues that need attention:
Needs wheels and tires
Needs receiver hitch and seven way trailer connector so it'll work with my trailer with brakes.
A/C needs repair
Something wrong with front hub/axle, four wheel drive won't engage (haven't done much on this yet).
The seat is torn and the carpet is nasty so I'll be looking for a used bench seat but will probably pick up some brand new carpet from Rock Auto, seems to be reasonably priced.
I've already fixed the broken clutch and brake pedal assembly and a bunch of other little boring things.
I'll have to post a picture later, isn't working right from my phone right now.
A/C needs repair
