1988 Ranger Shocks
StarRanger
Oregon
I have a 1988 Ranger XLT, extra cab, 2WD, 2.3, 4 cylinder. I'm wanting to upgrade my front and rear shocks just using standard length i.e. OEM lengths. I need help regarding what model years the same shocks will fit. I found in the Forum information that Ford used the same TIB (Twin I-Beam) front suspension in Rangers from 1983-1997. I'd like to upgrade to some Bilstein 24-022361 and 24-196277 front and rear shocks, but I see they are only listed to fit down to 1990. So, I am wondering since Ford used the same TIB from 83-97, why do many of the shock manufactures cut-off the year sometimes at 1990? What's the difference between shock lengths and fit from the years 83-97? Can I use any front and rear shocks for Rangers from 83-97? All responses are greatly appreciated. Thank you......
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
StarRanger
Oregon
Thank you Dave for your help. I'm not sure I understand your reply. To recap, my question is: Are the front and rear shocks (standard OEM length) all the same and interchangeable for 2WD Ranger's model years 1983-1997? I read Ford used the same TIB (Twin I-Beam) front-end system for those years. But I'm seeing conflicts when shopping for shocks. So I'm wondering if I can shop for any brand of (F&R) Ranger shocks as long as they are from the model years 1983-1997? And if not, why not, what did Ford change, especially if all the 83-97 Rangers had the same TIB front end ?
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
I understood what you were asking. I just don't know the answer. Someone will chime in though. Patience grasshopper.
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
My guess is a change in the mounting. Some manufacturers have a diagram and measurements of their shocks, and you can then see if it will fit yours.
