1989 2.3l issue
mattr87
roy, washington
2.9
I have a 1989 ranger 2.3 5speed 2wd, the problem I'm having is when I go to start it, it takes forever to fire and when it does it runs terrible (backfires alot dumps black smoke) but if i keep reving it up eventually runs perfect, but now it seems to just be getting worse, sometimes while i crank it over it's like the timing is to far advanced, I checked the timing marks and there good, replaced the fuel filter and put different dis module, coil packs and fuel pressure reg. I was thinking maybe crank sensor?
chilsam
chillicothe il
91 branger
300 six
Fuel pressure reg
pull the vacuum line off the reg and if fuel comes out the diaphragm is shot.
mattr87
roy, washington
2.9
I would check that if I could but It wont start now, has spark and after cranking for awhile the plugs were dry i haven't checked the fuel pressure with a gauge yet but i just pushed in the schrader valve and fuel came out but it seemed weak
chilsam
chillicothe il
91 branger
300 six
Ether
Will it fire with ether and no throttle:icon_confused:
