177CIOfPureLove
- Oct 25, 2007
- 2
- Bayville, NJ
- Ford
- Engine Size
- 2.9L
Alright, 89' ranger, 2.9 v-6, m5od, 2wd.
This truck has never ever let me down. I was leaving work (a little backround, a month or two ago sometimes sporatically the starter would not engage, everything else would go as normal, solinoid clicked and all that good stuff. Being at work and school i did not investigate it very much, because at the very worst i could always rollstart it, which wasnt often. It also always started when hot or warm after running) and the truck would not start on its own. roll started it out of the parking lot and drove away. the truck ran perfectly as it always has. Then about 400 yards away down the street the gauges and the battery light went nuts; then the engine stopped. Pushed it into a parking lot and checked what i could with my tools, voltage good, fuses good, everything works lights fuel pump relays ect. no starting it. Had to get it towed home. Got it home load tested the battery, its perfect. I find out that once you key the ignition to run, the block becomes positive. Ignition off everything is grounded. i took the starter, starter lead off and completely out of the car. bench tested starter, its working. the starter lead is great, no shorts or anything. I put it all back, and took a jumper cable to the positive on the battery right to the one lead for the starter, and it does not crank, but instead turns everything on, and ungrounds the block. my voltmeter showed the block go from 0.0 volts to 12. Also arcing is heard once you turn the key back from run. I ent out in the dark with the ho dclosed over my head, and i cannot see spark. It sounds like it is on top of the motor. This truck is my DD, and i cant use my moms van forever. Me and the truck have been through a lot...but my god it took me less time to put the motor and clutch, ect. into it a year ago......lol. I replaced the alt. and the solinoid. Any ideas or advise would be greatly appreciated. I am not sure the best way to continue, other than pulling the harnesses and checking each wire for flaw. Thank you so much everyone in advance.
