1991 Ford Ranger Extra Cab 3.0
Hal Golightly
Dose anyone know where I can get a replacement gas tank for my 1991 Ford Ranger Xtra Cab 3.0 or if not, does any know if any other year Ranger gas tank will fit my 1991 Ranger. Thanks in advance for any help. Hal
rusty ol ranger
2.9 Mafia-Don
7,843
Michigan
177 CID
8,385
Xtra cab will have a 20gal tank, 19.5gal, it can be listed as either
(regular cab had 17gal, 16.5gal)
If its plastic you may not find one and will have to repair what you have if possible
The plastic tanks are made by "Plastic Welding" the two halves of the tank together, upper and lower halves
So they can be repaired/patched the same way, yes its a thing a DIYer can do
Google: Plastic welding gas tank
rusty ol ranger
2.9 Mafia-Don
7,843
Michigan
177 CID
Wernt they all steel untill like 01?
Bgunner
1,122
Western Mass.
Ford/Ranger XLT
225/70/R15
8,385
Late 1980's was when most car makers went from steel to plastic
This is a good site to look for LOCAL used parts, use YOUR Zipcode
It will give you the option of what size tank after you hit the SEARCH button
In some areas/States used gas tanks can't be sold, same as used Cat Converters, I get the Cat converters but not used gas tanks :) that makes no sense to me
rusty ol ranger
2.9 Mafia-Don
7,843
Michigan
177 CID
pjtoledo
3,054
Toledo Ohio
Fords
3.0 2.3
what's your location, within a few miles?
ericbphoto
Overlander in development
TRS 25th Anniversary
16,867
Wellford, SC
3.0L
6"
rusty ol ranger
2.9 Mafia-Don
7,843
Michigan
177 CID
ericbphoto
16,867
Wellford, SC
3.0L
6"
RobbieD
2.9l Mafia
3,608
Georgia
Previous owners banged it on a Rick and dented the bottom
What did Rick do to deserve that? Was he one of the Ford design engineers?
ericbphoto
16,867
Wellford, SC
3.0L
6"
Junk Collector
Truck of Month
4,885
Rapid City SD
Junkyard tank will be your best bet if you want a plastic one. Pretty safe bet that a new metal one from '86 (I think that was the first year of super cabs?) to '88 would work but you will need the straps with it. Probably the sending unit too. Engine size is irrelevant, the wheelbase is the important part as the tanks were different lengths. 125" wheelbase is what you have.
You might be able to use one from a newer super cab truck too, 93/94 would be fairly safe. Not sure on 95 and up, there is a good chance that they would fit but some leg work to confirm that would be required on your end.
