1991 rough running/ignition problem
k3eaxk3eax
1991, 2.3/manual
Engine suddenly started to run roughly. My timing light indicated no advance as the engine was revved,
Two digit codes and explanations from Ranger Station page with KOEO as follows:
14 --Ignition pickup erratic
18 Ignition tach signal erratic
88 Ignition---IDM, DPI or spout circuit fault
If you've worked through a similar problem, please share your experience.
Methinks the problem lies in the crank sensor circuit or in the ignition module circuit. I don't want to start "throwing parts at the problem". And so would like to eliminate the problem's source as being elsewhere.
Comments welcome ---HELP!
Al
been through
k3eaxk3eax
Problem solved by replacing ignition module.
Al
