Update your thread with this new symptom. Maybe someone has a work-around that’ll help you get it running again.
Sent: Tuesday, May 11, 2010 9:44 AM
To:
Subject: Re: RE: Click on these links
I feel stupid. Auto Zone, Advanced, and Pep didn't have it. Oreilly does tho. $15. Thanks for the advice. I thought about gear being bad, but truck was starting no problem. I turned the key backward toward ACC (a little harder than normal) and the key cylinder quit working all together. I didn't feel anything give way or snap, I'm thinking it's the cylinder itself. No reasons the gear mechanism would have just broke while I was experiencing only a wierd elecrtical problem linked to the key cylinder. If I had left it alone, it was working fine. All I had to do once the truck was running was bump the key and the power came on to the radio and wipers. Now, I fiddled with the key switch/cylinder, it it won't actuate at all.
On May 11, 2010,
> wrote:
Auto Parts store.
I’ve never done work in the column, so I can only rely on the links.
I liked the last link, for the Mustang. Should be the same.
Might be worth a trip to the junkyard. It does sound like the gear is bad, not necessarily the switch. Wish I could be more help.
Sent: Tuesday, May 11, 2010 9:26 AM
To:
Subject: Re: Click on these links
Ok, my cylinder (while in the RUN position) was very touchy and the radio/wiper power was intermittent. A few times, just wiggling the key, cut the truck off. So, I took column covers off and tried to get the cylinder out. I turned it back to ACC, but then I had no actuation from the cylinder at all. The ruck won't start and the key cylinder does nothing but turn now. The key unlocks it, but it just turns to and fro without actuating the ignition switch on the column. I read all the links below and it sounds like it could be (and this is what I thnk) the cylinder itself. Or, according to the links below it could be a broken gear or a bad ignition switch. What do you think? Oh yeah, what is an AP store?
On May 11, 2010, > wrote:
http://www.therangerstation.com/foru...gnition+switch
http://www.mustangmonthly.com/howto/5657/index.html
I’d get the switch elsewhere. $75 is steep for a $20 part available at any AP store.
Sent: Tuesday, May 11, 2010 8:44 AM
To:
Subject: Re: RE: RE: copied some more for you
Good call, circuit breaker ok. There was a bad ground on the wiper motor. But, I figured out what the real problem was. When I cranked the truck yesterday, I saw the radio clock/light come on briefly. But while the truck was running, no clock light and no wipers. I wiggled the ignition key, viola! Wipers and radio. Bad ignition cylinder/switch. I removed column covers and took a look. Do you know the best way to pull the lock/ignition cylinder out? Does it have something to do with tunring the key and then pushing a pin or release of some kind? Or, do you have to take the column apart? All the junk yards I called want to sell the whole column and a can get the ignition from a dealer for $75.
Yes, continuity is closed.
These two circuits have G201 in common.
Ground 201 is located above the parking brake, looks like it’s pretty high up too, like 6-8” above the PB. About the same height as where the door harness splits out of the big harness.
That’s the first thing I’d check. Remove, sand it clean and reinstall that ground.
Sent: Monday, May 10, 2010 4:03 PM
To:
Subject: Re: RE: copied some more for you
You know, I have continuity on the old CB when it's in my hand; that's closed right? What is wierd was this. I first noticed that my radio was getting no power. I didn't check the wipers. Then the radio was intermittent (I fugured fuse was loose; so I checked them all). Anyway, it just so happens I changed my wiper blades the other day andfound out the wipers won't work. So, I put 2+2 together and it seems that for some reason the two problems are tied together. When I pulled the CB out, the radio works fine. I don't get it and I'm not sure why anything like that would happen. Would the wiper CB cause something like that in another system?
On May 10, 2010, > wrote:
I’d pull that CB and put a jumper in its place, see if that works, then fix whatever smokes.
…..actually, if you have an amp meter capability (most DMMs will read up to 10A), just put that in line instead of the CB; then you’ll KNOW how many amps it is pulling.
You could also monitor that CB and see if it is opening. Just need a regular volt meter for that (or a test lamp).
Sent: Monday, May 10, 2010 3:44 PM
To:
Subject: Re: copied some more for you
Yep, top of page 81-1 you sent me shows Fuse position 2, 6 am cb; as we discussed. I'm hoping it is just and not one of those protracted troubleshoots listed on the stuff you sent. Thanks.
