My next step with the ranger is to get the steering and alignment worked out. The truck doesn't shake a whole lot, so I think the rotors aren't warped. However, in spite of that there is about a 10 to 20 degree play in the steering. The tires dont seem to be showing signs of wear from a bad ball joint causing them to wiggle when driving. Also when ive experienced bad ball joints in the past there is vibration from the tires, but im not really having a whole lot. The steering is pulling to the right and the wheel has to be turned to go straight. I need to put tires on it. Im thinking about 32s. Does anyone know of a kit for upper and lower ball joints and control arm ball joints? I feel like i should replace them just to be safe, since im puttimg over sized tires on and probably wider ones. Or the doorman part numbers? I think ill start with an alignment and greasing the joints but i think ill have to put a new steering box on.
