Sagerific95
- Apr 15, 2024
- Reaction score
- 1
- Location
- Connecticut
- Make / Model
- B4000
- Manual
Hey everyone, I’m a new member but I’ve been reading on this forum for years, I’m finally posting because I’ve run out of information to help me fix my truck…
So here’s the story. 3 years ago I purchased a 94’ B4000 SE, standard shift with high miles. The transmission was in the bed of the truck because 3rd gear was blown. I purchased a 1993 ranger 4.0 with a rotten frame from my buddy as a donor vehicle for my B4000, had less miles on it, ran fine and was a good candidate for an engine rebuild/ donor for my B4000.
The original engine had EGR,
The tube from the manifold to EGR valve was broken and the truck always ran terribly.
Fast forward to 2024, I rebuilt the 93’ engine completely with new bearings, and rings, with new aftermarket heads that are reinforced. As far as I can tell they are the older style larger chamber, however these heads were as cast and the chambers are pretty rough surfaces.
When I rebuilt the engine I used the 93’ intake manifold to get rid of the EGR as my truck does not need emissions where I live.
NOW HERES WHERE THE FUN BEGINS…
Every single sensor on the engine is new, including a Reman Dorman ECU for a 1993 from rock auto (capacitors were bad, I found out after reading about them on this forum), as well as injectors and here’s everything I know from trying to figure this out for 3 years:
- compression is fantastic in all cylinders, 185-190 psi across the board.
- tps setting is correct.
- fuel pressure is within spec, no fuel coming from FPR vacuum line.
- no vacuum leaks, smoke test confirmed.
- engine idle drops to +or- 550rpm when IAC is unplugged, engine does not stall.
- engine runs the same when MAF is unplugged.
- thermostat operates normal and is a 198F.
The only new but suspected to be bad components are the injectors, at the time of the rebuild I couldn’t afford the name brands and got a set for 80$ from Amazon.
Here’s what the problems are:
- the engine runs fine on choke mode.
- Once the engine is warm, the idle hunts and never stops hunting, sometimes it almost stalls as the rpm’s fall, but it always runs.
- Fuel mileage is about 11-13 mpg.
- No CEL ever.
- I HAVE to run 93oct fuel otherwise it detonates under load at highway speeds.
- On hot starts the engine misfires on 1 cylinder until I punch it and then it seems to go away.
- The engine always gets me where I need to go, but it always runs poorly. Gets bad Gas Mileage, and always idles like crap.
I know this was a long read, I appreciate anyone who has input. I’m an automotive mechanic, I’ve been out of the field for about 5 years, I work in aerospace now. I still have all my tools, a bit of knowledge and understanding. As we know there isn’t much communication from the ECU on these engines. I’m hoping somebody can help. It’s great to be here!
- No CEL ever.
