1999 Supercab Turn Sign Circuit Dead
Tommy2u
Louisiana, USA
Ford Ranger XLT
3.0 Vflex
Turn signals stopped working. Checked fuses with key on, no power to fuses. So what is ahead of fuse panel on this circuit? I thought fuse panel was the first power source on this circuit.
To my understand power travels from fuse panel to turn signal switch on column, from the switch it goes to flasher relay, from flasher it goes to the lights... or am I mistaken?
Any suggestions please?
8,372
Welcome to TRS :)
Correct, there are no fuses for the light bulbs themselves, just the Flasher unit
Wiring diagram below
Fuse 10 in cab fuse box powers the turn signals but only with Key On
Fuse 21 in cab fuse box powers the 4-way flashers, but has 12volts all the time since its an emergency switch
See if 4-ways work, as said fuse 21, which is powered full time by fuse 1 in engine fuse box, which also powers starter circuit
4-ways use the same wires from turn signal stalk(multi-function switch) out to the 4 corners
But 4-way are always connected, turn signal activation requires mechanical switch inside the stalk to make and break contacts, so can wear out
There is just the one flasher unit that does both turn and 4-way, if it fails you can lose both, turn and 4-way, but............can also just lose one of these
So usually the first stop is the Flasher unit
The most common failure is the Multi-function switch as its the only "moving part" of the system besides the Flasher
Google: 1999 Ford Ranger - Diagnose and Repair Turn Signal Failure
Good video on where Flasher is located in a 1999 Ranger
He does get the fuses wrong, 3 and 7 are for TRAILER light wiring
10 and 21 are the correct fuses to check
Just FYI
1993-1999 Rangers have separate turn signal bulbs in the rear
1983-1992 and 2000-2011 Rangers do not, brake and turn share same bulb(filament)
Tommy2u
Louisiana, USA
Ford Ranger XLT
3.0 Vflex
Thanks so much for your insights and info. I figure it must be the flasher now since checking the fuses you mention are all powered and good. The blinker switch is all that's left. The head and tail lights work despite sharing bulbs with both the turn and hazard lights. She starts and goes as normal. Must be the blinker switch.
What did you mean by multifunction switch? Is that the flasher or something else? Thanks again.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,545
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Multifunction switch IS the turn signal switch.
Tommy2u
Louisiana, USA
Ford Ranger XLT
3.0 Vflex
Gotcha.. I'll get one and let ya know how it goes. Thanks again ;)
Tommy2u
Louisiana, USA
Ford Ranger XLT
3.0 Vflex
I finally got her fixed yesterday after being sold the wrong part and having to go back to the parts house 4 times to get this done. In the end I had to give 'them' the right part number; then all I got was an aftermarket cross reference without the side shields. ..Well it was half the cost of the dealer part so what can I say, it worked :rolleyes:
Hey, thanks again for the steer. You are appreciated.
