Yes, +1 ^^^
When you turn on the key the EEC relay closes and powers the EEC(computer), the coil packs, and the fuel injectors.
Ford injectors only have 11-16ohms resistance, 0 ohms is no resistance, so if you pull off the injectors wire, key on, you will see 12volts on the Red wire and low or no volts on the other wire.
If you put the wires back on injector then you will see 12volts on Red wire and 12volts on the other wire because the 12volts is easily passing thru the low resistance in the injector to the other wire.
When you crank the engine, the Crank Position(CKP) sensor will send a timing pulse to the computer(1995 and up), the computer will then Ground and unGround the coils to send spark to the correct plugs and also Ground and unGround the fuel injectors to add fuel.
Cam Position sensor(CPS) is used to fine tune sequential fuel injection and spark timing once engine starts.
If CKP sensor or it's wiring was the problem then you would also have no spark, so a no start when you add fuel manually.
CPS wouldn't effect startup but will effect operation
'96 4cyl will have 4 separate Ground wires for the injectors, so a bad wire would cause a misfire but not a no start, 4 bad wires would be an extreme long shot
Just to confirm fuel pressure turn the key on and off while listening for the fuel pump to run for 2 seconds.
Fuel pump will turn on for 2 seconds each time key is turned on, it isn't quiet
If you can't hear it then that is the problem.
If you have fuel pressure at the fuel rail/injectors, then unplug the 3 wire connector on each coil pack(no spark) and crank the engine over a few times.
Pull out 1 spark plug and check it's tip, it should be wet with fuel
If it is dry then that confirms no injector pulse.
As tom said, a Noid light can also be used on a fuel injector to show if computer is Grounding it.
The injectors are only Grounded for a few milliseconds so a test light or digital volt meter won't work, and with an old analog meter(needle/gauge) you might see a slight pulsing while cranking engine IF there was grounding.
