2.3t into 1995 ranger
MRMDX
Auburn, Washington
I have a 1995 ranger currently with the stock 2.3, I have a 2.3t out of an 88 xr4ti with a full harness and La3 computer, what all wiring needs to be done to get it all working with the La3? Thanks, don't seeuch info for the 1995 and up
Mr_Lee
Windham Centre, Ontario, Canada
Ford Ranger XLT
L33 5.3 LS
5"
245/45zr17 & 275/40zr17
Drop the rod and pistons into the 1995 block. Tap the block with a 1/2" NPT tap for the oil drain. Bolt on the turbo. You want a 2.5L ECU, they have more tuning options and are plug and play for 95-97's. You want 42lb Green Top FoMoCo injectors and a 2005+ Focus slot maf and a custom intercooler setup. SCT Flash can tune it for you. You can keep the OBD-II and dual plugs and have your turbo too.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
I like that, that's way less fuss than trying to convert, nothing wrong with the LA3 but the OBDII stuff is more ingrained in the vehicle
