- Nov 12, 2018
- 513
- Alcoa, TN
- Engine Type
- 2.8 V6
- 2WD / 4WD
- 4WD
Hi Guys,
As of late when I cut off my Bronco with the 2.8 it will have a case of "dieseling".
It isn't every single time, but it is becoming more frequent.
Does anyone have any experience with this? I know it was a lot more common on carb'ed engines.
I did see where a fix could be an electric solenoid on the fuel line, or perhaps an electric fuel pump, but that was just a quick search.
From my understanding it happens from a hot spot in the engine that allows the gas to continue to ignite without the ignition system on, is there a way to isolate this?
I think the Bronco might be running warmer then I would like, but I need to confirm. I believe I'll install a 160 degree thermostat that I've had for a while (lower thermostat engine).
I do have a new two row radiator with a newer fan clutch, just seems to me it is operating a little warmer than maybe it should, but I'll have to get some temps and possibly check the tune to make sure I'm not running too lean.
Any other tips or things to check would be great.
Any advice @RonD or @19Walt93 ?
