Bronco648
- May 23, 2019
- 102
- Chicago-land, Illinois
- XL
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3
- 2WD / 4WD
- 2WD
- Tire Size
- 15"
I'm in the process of tearing down and disposing of an old, tired 2.8 V6 out of an '85 RCLB. Previous owner says the engine leaked like crazy but wasn't blown. It turned freely, to a point; one cylinder has some surface rust on the bore (valves must have both been open).
Does anyone need/want anything?
I'm keeping the oil pan, oil pick-up screen/tube and the timing gear cover.
Everything else (block, pistons, rods, crank, cam, cam gear, main caps, main bolts, con-rod bolts/nuts, etc.) is up for grabs. I have limited space so this stuff isn't going to be around for too long (2 weeks max). I have no issue boxing stuff up and shipping (at your cost). Shipping isn't cheap these days so I understand if there's a reluctance to respond. If you're local to Chicago, we can meet up.
