2.9 aluminum valve covers
stegomon
20
auburn/minot maine
fords and only
Ooooooo I like alot
Surrey
10
Vancouver, Canada
2.9
Passenger side wont clear a stock AC airbox I betcha...
edit - also doesn't say which years it works for. When they redesigned the heads for 88 they changed the mounting surface on them.
If Im not mistaken, 89-90 covers work on a 88 or older, but the 88s dont work on a newer engine. (I could be wrong, they might not be interchangeable at all.)
dave2575
Bay Area, Nor Cal
mostly 88
2.9
"BIGGER HAMMER!"
It looks like there might be an alternator issue as well. And I was wondering about the years, In the pic it looks like the bottom edge of the mounting surface is shaped more like an 88 or older, the 89 and newer valve covers clearly have a different mounting surface.
88 older
http://images1.carpartsdiscount.com/auto/archive/pictures/279114/600/1/P/7792530/ford_ranger_1990_valve_cover_gasket_set_oem_vs50312t.jpg
89 newer
http://images1.carpartsdiscount.com/auto/archive/pictures/272662/600/1/P/74206CC/ford_ranger_1990_valve_cover_gasket_set_oem_vs50368t.jpg
Also I saw these alloy valve covers and I dont know if they would also fit, anybody know about these?
http://www.ebay.co.uk/itm/Alloy-Valve-Covers-Panther-Kallista-Ford-V6-2-8i-2-9i-NEW-/390398192862?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ae58bacde
JoshT
1,782
Macon/Fort Valley, GA
Sorry meant to reply to this last weekend, but storms had my internet screwed up and then I forgot about it.
Car parts discount is wrong, parts dealers like using stock photos that may not actually be the part they are representing. In this case the photo in the second link is a stock photo, it's actually a 4.0L valve cover set and upper intake manifold gasket.
Unfortunately ...or maybe fortunately... Surrey is also wrong, but in the wrong way. Even if the heads changed slightly in 88 (I don't remember anything, but I see mentions bolt sizes) the valve covers, gaskets, and mount surface remained the same.
I vote for option 3. Many years ago I saw a set of finned aluminum valve covers for the 2.8L that said "Ford V6" in the top. They looked more like the traditional finned style rather than those low wide fins on what you posted. I would imigine that if they existed for the 2.8 they probably did for the 2.9 as well. If you watch the net and swap meets. From the ones you posted, I vote for the first set. The second set is clean, but you don't have a panther kallista and nobody looking under the hood will understand the markings. If you prefer with the second set I'd recommend trying to smooth out your stockers and paint them gloss black, you'd end up with about the same look for a lot less. I'm not sure that the second set would work anyway, they are intended for the 2.9i which used a different EFI system than we have here in the states and I'm not sure if they would clear our intake manifold.
Just a recommendation, but if you want to use a parts store for comparison I recommend Rock Auto. They use manufacturer's part number rather than in house numbers which makes it easier to compare. I've also found that lot more of their photos are of the actual part, and not just stock photos.
