2.9 and 4.0 OHV oil filter adapter seal part #'s
Junk Collector
Truck of Month
4,802
Rapid City SD
I had a heck of a time finding the right O rings for these so hopefully someone will find this information useful - FYI the adapter from the 4.0 will apparently bolt onto a 2.9 and vise versa, as per Ford anyway. You may be able to get away with reusing the green washer and big washer on either application - the little black one in the middle gets absolutely cooked and comes out broken every time. I think that's where leaks develop here.
The 2.9 info may apply to 2.8 adapters as well, I no longer have one to confirm but it appears to be the same or similar.
FYI you CAN replace these with the exhaust in place, it is not too bad on a 2.9 truck, 4.0 is a lot less fun. A stubby 3/4 or 19mm wrench is what you will need.
2.9 adapter uses one little O ring, one big O ring, and a copper washer.
Small O ring - Felpro 413 or equivalent
Big O ring - Mahle B32794 or Victor Reinz 711351400 - there are two listed for the 2.9, a thick one and a thin one. The thin one was what I needed, 2.45 IN I.D.; with .103 IN Width. Also available at hydraulic shops
Copper washer - NLA - just reuse what you have
4.0 adapter uses three O rings - two small ones and a big one
Small black O ring - Felpro 413 or equivalent
Green O ring - Ford only part - E9TZ-6749-A - nothing else will fit correctly that I have found, it is a metric half size supposedly.
Big O ring - Felpro 72884 or equivalent - the "thick" one that's listed for the 2.9 adapter fits here - 0.141 (in) Width; 2.482 (in) Inside Diameter
2.9 adapter & all its pieces:
4.0 adapter:
RobbieD
2.9l Mafia
3,466
Georgia
Great information; thank you for posting.
Your info looks to be perfect, especially with including the dimensions. GREAT pictures, too.
The oil filter adapter is a common leak point on Colognes often overlooked, and it's not too bad of a job to replace these seals. If you have the transmission out anyway, that's a great time to do it with the better access.
In case it's helpful, here is what I have on these which may give some cross referencing for other manufacturer's part numbers (and in my case I also have a 2.8 to maintain).
I can't garrauntee the accuracy of my notes, and the info is several years old so the prices are at that time, and not today's pricing. Looks like I pulled all of these part number off of RockAuto ("+ S" is "plus shipping"; "OOS" is "out of stock"). I've bought these from Rock, and also had my local mom-and-pop parts store order them. In fact, the mom-and-pop store found the green o-ring for me, delivered from the local Ford dealership.
alwaysFlOoReD
5,098
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
A note on copper washers. Heat them up red hot and drop into water. This will anneal the copper so its soft again. Over time the copper washer gets work hardened and may not seal properly if not annealed.
I learned this when I was doing a pre-apprentice course in diesel mechanics many years ago.
Junk Collector
Truck of Month
4,802
Rapid City SD
That's interesting, and good to know.
I'm not sure I would do that with this one unless I had a spare - I used a 3M finger disc to clean up mine and it appeared to be some other material that was copper plated. There were a couple small spots where the inner material was showing through. It's not leaking in any case.
