2.9 ranger runs terrible
preston c
americia
ford ranger
No, it does not run the with the relays swapped. I’ve done the fuel pressure test while the truck was running and it tested to be great. I will check the leak test soon.
I will look at the wires near the battery and check their connection.
I’ve been tracing wires and found some under the distributor. They are yellow and red. Looks like they are connected to a connector going to the intake. so I guess I have a gas line leaking somewhere I’ll have to check that. I assume gas all over my connector would cause a bad connection and cause a problem.
thanks for all the help.
Terrys87
259
Anderson Mo.
preston c
americia
ford ranger
okay thank you!
franklin2
1,769
Virginia
Bronco II
Don't worry about the ECT code. You will get that one when you pull the codes and the engine is cold. Of course it's cold, it will not run.
rusty ol ranger
2.9 Mafia-Don
7,601
Michigan
177 CID
Thats a good point i didnt even think about.
preston c
americia
ford ranger
i got it to operating temps and the code still showed up.
franklin2
1,769
Virginia
Bronco II
Just making sure you know there are "right now" active codes and then there are memory codes.
preston c
americia
ford ranger
thank you, that could be it then
