2.9 Starter Bolts
Mhfco6
Firefighter
87
Virginia
Anyone know what size the starter mounting bolts are? Are they the same size as all the other motor to trans mounting bolts? They are missing on my project, someone took off starter and the bolts are awol.
lil_Blue_Ford
6,289
Butler, PA, USSA
4.9L
Don’t remember offhand, but I know they are metric
Mhfco6
Firefighter
87
Virginia
Head will turn with 1/2” or 13mm just need the pitch and length. All the others have a shoulder as well.
Josh B
1,988
Oklahoma
If nothing else get a handfull of bolts and start twisting until you find one that goes in easily and snugs down well
Mhfco6
Firefighter
87
Virginia
Smaller Through bolt, with a nut
Josh B
1,988
Oklahoma
Mine has one too :)
lil_Blue_Ford
6,289
Butler, PA, USSA
4.9L
If I had to guess, I’d say M12-1.75 and probably 40mm or so. If I get a chance I’ll poke under mine and see if I can get a better number. I could be incorrect.
Mhfco6
Firefighter
87
Virginia
I picked some up today. M10x1.50 by 40 did the trick!
Josh B
1,988
Oklahoma
I went by a local farm/ranch/hardware store recently and stocked up on different bolts, nuts and washers.
Figured if I ever used one of them it would pay for the trip.
