- Jul 15, 2008
- 4
- Age
- 36
- Sutersville Pa
- Ford
- Engine Size
- 3.0, 501, 7.3psd, 351c, 351w
Ok I'm pretty stumped with this one. The truck is a 2000 3.0 auto extended cab 4x4. I bought it tues. It fired right up and drove onto my trailer. It again fired right up when I unloaded it Weds. Now It won't start. It cranks over fine. Fuel pump runs. I have good pressure at the rail. I've changed the coil pack, the crank sensor and the cam sensor. All these parts I removed from an extra 99 3.0 I have that "ran all the way to the scene of the crash." I've got spark. It will NOT even try to fire on starting fluid. If I pump the gas like its and old carb vehicle it will try to fire almost like its outta time. I coughs out the intake but never actually fires. You can smell the raw fuel comming out the exhaust. I tried swapping computers with the one from the 99 but it wasn't any better. I also did the disconnect the battary for 5 min trick and nothing changed. I'm starting to thing it jumped a tooth on the timing chain but I find that hard to believe being it only has 134K on it and I was only moving it in my driveway. Any help or suggestions would be greatly appreciated.
