2000 Explorer, Where to find the Door lock combination?
BillRod
Colorado Springs CO
95=4.9L Others=4.0L
Hi All
2000 Ford Explorer.
Where can I find the combination for the door locks?
Is it located anywhere in the truck or do I have to go to a locksmith?
Thanks
Bill
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
Are you talking about the keyless push button entry? If so I have heard that it is sometimes written on the inside of the "C" pillar trim from the factory. Sometimes......
PetesPonies
25
east coast
2.3l
It's written on the keyless entry brain. In my Lincolns, that was always in the trunk up under the package tray. On your explorer, I do not know where that is. I bet it's behind a panel in the rear area.
UrbanRedneckKid
17
Cass Co, Missouri
Take the cover off the left rear side panel. You should see your jack and tools.
If you look forward behind the panel there, you will see a module with a harness plugged into the back of it.
The code is in big bold numbers on the outside of it, facing the interior side of the truck. It'll be 5 digits.
You might be able to pull the panel out and read it. If not, get a small dentist's/ mechanic's mirror and a flashlight.
Put the code in the door to unlock the driver's door only, then you can push 3 to unlock all doors. Pushing the last 2 buttons will lock all doors.
Sent from my PG86100 using Tapatalk 2
